LED Notification
sau4u
LED Notification
Is it possible to adjust the brightness of the LED notification light.  Cannot seem to find an option on the phone to do so therefore not sure if its possible.
Jake-SonyXperia
Hi Sau4u,
Unfortunately there is no way to perform this task with any settings the handset has.
Although I do not believe this is possible, you may be able to find an application that may perform this task.
I apologise for any inconvenience this may cause.
What are your thoughts about this forum? Let us know by doing this short survey.
