Hi, had a search of the SP forum but can't see anything like this.
When writing - either text, internet search etc. I seem to get some lagging, so I'll start typing and there will be a momentary pause and the screen will freeze for a second and then if I've typed quickly it'll all seem to catch up with itself - sometimes the word won't be right cause the spell check only picks up the 2nd half of the word (after the lag/freeze). i.e. If I type internet, I could be typing the "I" then the "n" and I'll start pressing the "t" and "e" but it's stopped after the "n", the dictionary will then only pick up from "t" - so it'll spell check "ternet".
I hope that makes sense? and I've explained it well enough, it's quite frustrating, I don't type as quick as some people so to get the lag/freeze is quite annoying and I have to spend time getting rid of wrong (half) words.
I'm using the xperia keyboard and haven't installed any third party keyboard apps or anything like that.
Any help you can give would be great.
thanks
I've had a look at my RAM and it was running at about 60% - 65% - is this ok? I did stop some of the apps that were unnecessary but didn't really change much - maybe another 1 or 2% extra. I've not had a chance to do the keyboard thing yet, but I'll do that next.
The lag happens when on charge and off charge - no specific times, probably happens nearly every time I write, whether that's a text or twitter etc.
Only have the original charger that it came with - don't have any other ones so can rule that out - thanks.
Will try the keyboard thing and report back.
Thank you for your help
