keyboard language changing doesnt work
hi a family member bought to me the phone in taiwan. before and after i have done the updates(to 6.0.A.3.73) i was tryin to change the keyboard language to hebrew and it didn't change anything it stays with the english and the chinese keyboard, and how can i cancel the chinese keyboard?
because it doesnt show any option to cancel the chinese keyboard...thanks
4 REPLIES 4
Hi, galco
I have a different Experia device, but this is probably similar.
1. In Settings - Language and keyboards, press on International keyboard, then Writing Languages. Make sure that English and Hebrew are selected.
2. Open any message, press on the message screen until a dialog box opens. Select Input Method, then choose International keyboard.
Then you can switch between languages from the special button marked EN. No problem with the right to left direction.
HTH
It is little bit diffrent here but I have found a diffrent solution...
I have download the multling keyboard app and chose in the multiling keyboard settings Hebrew  and it worked fine...but i wanted it to look like the default keyboard so i unselected multiling keyboard and it worked with the defualt language just fine.
Today i got my New Zylo and i connected him to the computer with the usb cabel, and i chose the opiton to update versoin, and its change the main language to english and i need that the fhone will be in hebrew, I tried to change the language in the seting that in the phone and it doesnt work, there is no hebrew language thair, can you help me please?
how can i type English, Chinese and Hebrew on a same message, i can't find the Hebrew keyboard even all throught i had mark (enable) Hebrew on language&keyboard setting------>writing language, selectes Hebrew. please
