Whenever I make a call from my Xperia L, after 2 or 3 seconds the Call timer shows up and starts increamenting. Without any dailing tone in the speakers. When I End the call (without making a successful call to anyone), the ring of the called person's phone alerts for a second and then stops.
Whenever I recieve a call the caller listens to my voice perfectly while i dont listen to anything..
This issue has freaked me out now. I've tried factory reset option and repair my phone option from PC companion but nothing helped. Should I claim the warrenty of the phone or is there any method by which this problem can be fixed by myself?
I'll be grateful if someone posts the solution of this solution. Thanks in advance
You could try to put in another or a new SIM card in your phone to see if there may be a SIM/network problem.
If you experience the same behavior you should follow the advice above and visit a service center. Please contact your local Xperia support team for more information:
Thank u for your helpful replies people!
Well I tried alot of things like repairing the OS from PC companion but nothing worked.
But 1 day later everything started working perfectly. I have no idea what just happened
Perhaps there was some temporary network issue or something. Glad to hear that it works know!
