issue with screen mirroring function
l0neli_m0nki
My z5 premium cant screen mirror to my bravia today , my phone and TV just showing preparing and after minutes the TV shows nothing the phone gives me the notification saying that 'screen mirroring session disconnect'  , it worked well today before . I can confirm that theres no problem with my TV for I can screen mirror with my another phone .
14 REPLIES 14
@l0neli_m0nki
What if you restart the router
John-BR
Hi @l0neli_m0nki
Welcome to the community.
Under what kind of circumstances does it drop out? Just intermittently, when you are using a particular app, when the screen goes to sleep? Any further info can help.
l0neli_m0nki
This function worked well days ago until yesterday  the TV screen began to lag and drop frames very often just like it has a very poor downlink connection , finnaly it disconnected after that I cant screen mirror any more. Immediately I tried  my another phone , it can screen mirror without  problems  .
Just now , I have restarted the router two times , every time I can screen mirror to TV for the first attempt , and for the rest it fails saying that '.... device is not ready or does not support HDCP ' , meanwhile the TV screen showing a full black screen with the title 'xperia z5 premium_xxx screen mirroring' and in less than 1 second the TV  turns back to the normal state (obviously , the phone connected to the TV and immediately it disconnected ).
After I browse this forum , I doubt that this is an error inherit from the early xperia devices .
Any ideas ?
John-BR
What happens if you restart the phone into safe mode?
l0neli_m0nki
In safemode  , I get the same result . On the phone : connecting , preparing screen mirroring , screen mirroring session disconnect , end .
John-BR
In that case try a software repair on the handset.
Here's how to run the repair on PC Companion:
  2. Phone Software Update.
  3. Start.
  4. Repair Phone
  5. Continue
  6. Accept data removal
  7. Next
  8. Wait for prepare
  9. Select Phone
And Bridge for Mac:
  2. On the Main Window select "Xperia > Repair Xperia Device".
  3. Ensure the phone is charged and select "Ok" in the following window.
  5. Wait until the initialising step is finished the continue as below.
  1. Follow the connection steps that appear, ensuring that you are holding the relevant button down before during and after the connection phase until the update/repair begins.
You will want to start these processes with the phone powered off and disconnected from the PC.
l0neli_m0nki
After I repair my phone , will it erase my data ?
John-BR
You will want to back everything us before running the repair. Here are some options on how to do that: http://talk.sonymobile.com/t5/FAQ/Backup-amp-Transfer/m-p/407253#U407253
l0neli_m0nki
Lastly , I would rather flash a fresh firmware using flashtool  without wiping data . Additionally , I would tell you that my xperia Z(c6602) occasionally  comes out the HDCP error , everytime when I re-flash the firmware using XZDualRecovery  without wiping data  , most time  it fixs this error and everything stay still in the phone . For now , there is no recovery for the locked bootloader on  z5 , so I will  try to re-flash it using the flashtool .
