Issue on Widget-Tipo
SONY_Rajesh
I am getting error "Unfortunately, Widgets has stopped", When I tried to open Widgets on my SONY Tipo ST21i. I have also checked for update, but no updates found on mobile. The widget is working using Next Launcher but not with Sony Xperia Home launcher.
Pl. advice soultion at earleist
Alexander1
First of all I suggest that you try to clear data for Xperia Home under settings > apps > all > Xperia Home > clear data. Restart your phone, remove the battery for a while. Put it back and try to add a widget again.
If the behavior persists, I would suggest that you try to boot your phone into safe mode to see if the problem may be related to any 3rd party app that you have installed in your phone:
If you get the same problem in safe mode, I suggest that you repair the phone software using PC Companion:
In PC Companion, press start on Support Zone > Start on Update the phone/tablet software > Press the blue link that says "Repair phone/tablet".
Before repairing the software in your device you may want to backup your information first. Check out this topic for more information on how to:
http://talk.sonymobile.com/t5/FAQ/Backup-amp-Transfer/m-p/407253#U407253
