That's a tricky question, why? battery life will vary in myriad ways
depending on the amount of running apps (background apps)
how poor is your network coverage
if you are using data all the time
if you have wifi on
if you play games
if you have the screen on quite often
go to settings > power management > battery > check the list, the screen should be on the top, also check the graph.
You should also check this other post
http://talk.sonymobile.com/t5/FAQ/Facing-problems-with-abnormal-battery-and-shutdown/m-p/320375#U320...
