is it ok to use charger with different power output for xperia z?
ivansatria
hi everyone, unfortunately i lost my original xperia z charger that came with the box, is it ok if i use another charger with different power output?
i know that the original charger ouput is 5V 1500mA. what if im using a charger with lower mA or higher mA? will it harm my phone?
thanks before.
Thommo
Genius
As long as the Voltage is 5V then you will be fine however depending on the Amps it may take longer or it may even charge slightly faster but I wouldn't exceed 1.5amps - You would do this at your own risk
