I have Prepaid BSNL SIM (BSNL North). APN setting are correct. When I open chrome browser for any website, it displayed Wi-Fi and mobile data are turned off. The Mobile data in settings is in ON position.
Browser works well on Wi-Fi only.
Pl guide
Definitely apn settings are incorrect contact bsnl service center or try these settings(only change these)
connection name :BSNLNET
access point name(apn): bsnlnet
and try to set authentication normal if it does not work set to none
data bearer to GPRS or leave it to unspecified
You do not need to do manual settings. Just go to Settings>Xperia>Internet Settings and it will fetch it for you. But dude you need to have an Internet Plan for your mobile to work on Mobile Data :)
I do have Internet Plan. I tried for automatic setting through Xperia >Internet settings. The msg is <Select Operator> and shows only two operators 1. Cellone South 2. Cellone East. but Cellone North does not appear in options. I have selected Network mode as WCDMA(prefered)/GSM
APN settings
Name- bsnlnet
APN-bsnlnet
Proxy-Not set
Port-8080 (Earlier I set it as None)
Server- Not set
MMSC- Not set
MMS Proxy- Not set
MMS Port- Not set
MCC-404
MNC-34
Authentication Type- None
APN Type- default,*
APN protocol- IPv4
APN roaming protocol- IPv4
Bearer- Unspecified
Get in touch with the service personel of your network proviver. The'll set it up for you.
