Internal Speaker Problem
huthifh
I am having xperia t mobile.
some time i can't hear from my internal speaker of the phone when i am reciving calls.
when i switch to external speaker its works fine when i come back to internal i can't hear any thing.
any idea ?
15 REPLIES 15
shahz
Thankz....i tried the same way and its worked for me...but donno how long it will last...
shahz
Download "Xperia Diagnostics" from google play and test ear speaker but it wont work. Plugin earphone and remove then do the test again and repeat the same no. of times. It will start working
Vignesh46
I have had the internal speaker issue for more than 8 months, I have contacted local sony store and they informed me that when I use the phone my sweat has gone in and damaged the speakers and they have cleaned it for me however I had the same issue after 2 weeks and they did the same thing again. After this my xperia p was fine for a month after which the issue raised again and still persists, I thout I could be the only one with this issue however I see that there are many similar issues with xperia and wat is sony's response regarding this.
Even if anyone else have a similar issue and fixed it please do let me know how to fix this issue.
Thank you.
MrsB
I have the same issue, with the internal speaker. I yookvthe phone to my local service center, after 3 question the rep told me we need to replace a piece, and it will cost you $317 SGS, because is out of warranty :@
subashspm94
My Sony Xperia c internal speaker is not working. I use headset or loudspeaker to make or attend a call. How do I recover from this problem? Reply soon
AD16
MY Internal Speaker & EXTERNAL SPEAKER & VIBRITOR NOT WORKING ONLY EARPHONE WORKS WITH VERY LOW LEVEL& MY MICROPHONE WORKS ALSO VERY WEAK.
