Internal memory problem
Dani_283
So my phone says I have 600 mb of free space in my Internal memory. However, when you see the picture or whatever it is ( I wish i could post it here but I don't see an option) on the top when you enter settings-->storage you can clearly see that more than half of the line is free...Also when you combine all those different parts of your memory apps,pictures and videos,downloads etc it doesn't add up to more than 4 gb of used space. I'm really not sure what's the problem here but I've noticed this problem long time ago when I had 2 gb free. It's like something is draining my internal memory, god that sounds stupid but I really don't know. Oh and I use 16 gb sd card and always transfer anything if it can be transferred. And I clear the cache regularly, I have clean master but I'm not sure if that app is helping at all. Thanks
53 REPLIES 53
Kokinos
Now I just tried to do a manual backup to my SD card and to my mail, but it just stops at 50% like before.
That's very annoying!
zyxxyz
use XPERIA COMPANION
http://support.sonymobile.com/global-en/tools/xperia-companion/
do not worry too much.
copy your data files manually; check that all the apps keep their settings in cloud.
Hardy66
That's my experience as well ... even with manual backup it gets stuck forever at 50%.
It will work though if you disable backing up of app settings.
I'm using MyPhoneExplorer for many years now to backup and/or synchronise my contacts, calendar entries, SMS, call history, ... even across different phones.
But I have found no way to save app settings this way. Slightly_frowning_Face
donmercutio
Works a treat for me, so far.
With photos on the cloud. Contacts on google account and apps from play should be quite safe.
Why the back-up app should take up so much space is odd.
And previous poster would seem to be correct.  The storage count seems to get confused about apps on the SD card.
KMBahamas
Thank you so much
Hardy66
It looks like the problem with saving "Apps" is gone with version 23.5.A.1.291.
Now I can do a safety copy even with "Apps" enabled in the "save&restore" apps menu in a reasonable time. It doesn't get stuck any more at 50% and there is no excessive internal memory consumption any longer.
Nuno_sf
Thank Hardy,
You answer solved my problem too
Dani_283
Hey guys,can someone write me all the steps that I should do to solve the problem, I'm having a hard time figuring it all out
Hardy66
Hi Dani_283,
if you're refering to the high memory consumption of the backup app the steps are the following:
Go to "Settings", select "Backup & restore", choose "Automatic Backup", scroll down and deselect "Applications".
Go back to "Settings" and select "Apps". Press the 3 dots in the upper right corner and select "Show system". Now scroll down until you find an app called "Backup & restore" and select it. It will probably report a huge amount of internal storage used. Press on "Storage" and then press the button "Clear Data".
Please not that with software version 23.5.A.1.291 deselecting "Applications" is no longer necessary.
Dani_283
Thanks man but that seems to not be my problem, it freed 15Mb only.
I first started this topic but kinda gave up on solving the problem cause.I freed a little bit of space but now I'm having the same problem as before.
It's tge situation with internal storage showing that it's almost full but when I try to add the storage of apps,andriod system and all it should be about 10gb
