Internal memory problem
Dani_283
So my phone says I have 600 mb of free space in my Internal memory. However, when you see the picture or whatever it is ( I wish i could post it here but I don't see an option) on the top when you enter settings-->storage you can clearly see that more than half of the line is free...Also when you combine all those different parts of your memory apps,pictures and videos,downloads etc it doesn't add up to more than 4 gb of used space. I'm really not sure what's the problem here but I've noticed this problem long time ago when I had 2 gb free. It's like something is draining my internal memory, god that sounds stupid but I really don't know. Oh and I use 16 gb sd card and always transfer anything if it can be transferred. And I clear the cache regularly, I have clean master but I'm not sure if that app is helping at all. Thanks
53 REPLIES 53
Dani_283
Hardy66
That's odd - in my Z3 Compact the sum fits almost perfectly with the number of free GB's displayed.
I'm a little bit running out of ideas now - except the well known suggestion to make a clean reinstall of the OS. But I guess you are as reluctant to wipe all your data this as I were in your situation.
If you are lucky to have a file browser app that is able to 1) show hidden files and 2) sort folders by the size of their contents you could manually look through the internal storage area and try to identify where the missing GB's are lost. (The "file commander" that came with your phone can do this, but only after upgrade to the pro version :smileysad:).
And don't be fooled by the two big files in the DCIM/.thumbnails folder, they use far less memory as they indicate.
Dani_283
Yup I tried that,I could do it again but I'm afraid I'll have to restore it to default
FernandoM76
Hi, I'll spare the sob stories and go straight to the point...
I know I can't use the SD card as intern memory (read previous posts), however,  I've got plenty of free space on yhe the SD card, and yet, the internal memory is constantly full.
This particular problem does not occur with my phone (Z3 COMPACT). I'm under the impression that external memory is seen to store personal files, rather than aid/extend the internal memory. If so, then I would appreciate if this subject could be considered for discussion for future firmware updates.
Thanks for the help! Slightly_smiling_Face
