I use xperia neo. I use 16gb external memory card. I use a lot of apps. I moved them to memory card. But the problem is internal memory is low and it prevents me to install extra apps. Why the internal memory is low??? How can i fix the problem? Please help me out.
try installing pandora, if it's on your internal memory you can add the widget to your homescreen, now move Pandora to the SD card, the widget will disappear and you won't be able to re-add it, unless you move the app back to the internal memory
