instsllation problems
dramacox
I am trying to install apps apk. from my file commander but the install button is not working, i tried installing another file explorer fro playstore but all effort was in vain. i cant install any apk. apps collected through bluetooth. pls help
5 REPLIES 5
suyogpatil
umm did you check your settings for unknown sources go to settings>security>unknown sources -- enable the same then you can install third party files
Don't Forget to press Kudos If you find any post helpful.
Mark posts that answers the topic as Accepted Solution.
dramacox
thanks for the response, I have tried that several times but its still not working but am thinking if its because of recent updates to 4.2.2.
pls help me.
suyogpatil
Thats strange cause I am also using 4.2.2 only but able to install Third party softwares may be there is some problem while installing software I suggest repair it with SUS
Or with PC Companion (PCC)
Please keep in mind to backup your phone data if possible
I hope this will solve the problem
JakeSully
are you trying to install any kind of app that requires root? if so that could be reason why install button is locked since it requires root without root it cannot install.
dramacox
Thanks all for your contribution.
Its been resovled.
it was because i install an apps that requires the brightness or apps lock (animal xbattery etc)
i just uninstall it and everything its fine. thanks D.
