Incoming call ring!
Incoming call ring!
Hello Everybody,
                              I have a new problem for the incoming call. My phone is work well until now. The phone doesn't ring and vibrate when incoming call. So, I restart my phone and I tried to call my phone but it's ringing vibrate the first time. Then the second time doesn't work anything. WTF? Anybody can hep? Angry_Face
29 REPLIES 29
Rocco1
Hello to you. Try going to Settings and choose Sound and Display. And you can check ringer volume and whether you want the phone to vibrate. And other things that you might have interest in. Hope this helps.
My phone is sometimes ringing and sometimes not. I have checked all settings, but sometimes only the display is getting on, there is no ringing or vibration. At other times, the phone's behaving normally during an incoming call.
I am more than satisfied with my phone, but this problem surfaced since yesterday. Its ringing in one call and silent in the next.
Any help anyone?
Any ideas????????????
Yeah! My problem is same to u. Sometimes it's riniging and sometimes not but notification (msg ringtone) works properly.   No one can help??????????????????????    Thinking_Face
sushidushi
I sometimes pick up my phone and accidentally hold the volume button on the side and put it in to silent mode by mistake.  Could you be doing the same...?
eeeks! I know this mode but I think when press the volume button, it still in vibrate. I dun press any button. The ringtone is sometimes happen not always but message tone is works well. And I've another issuses about battery these days. When I charging the phone, I think it is hotter than the last time. The temperature of phone is 46'C at charging time. Is it the normal? Our weather temperature is around 30'C. Then I think it is faster to go off and the charging time is long. A lot of problem in X10i!!!!!!!!!!!!!!!!!!!!!!!!!   I think my last SE W580i is better than it. Angry_Face
Most of the time I keep my phone on the working table. This problem I have noticed even before I have touched the phone before answering the call. So much so that I have given myself call from other number. Same problem- its ringing one call, vibrating in the next and utterly silent in the next. Of course, as said earlier, there is no definite pattern in this, but you get the idea I hope? Some internal wiring prob? I dont know, and I dont even know what those fools at Kolkata SE centre, India will do to get it right. If they keep the phone for review n repairing, I shall be utterly crippled.
Pls Help someone!!!!!!!!!
sushidushi
When you press the volume switch on the side, the volume decreases, then it goes to vibrate, and then it goes to silent with no vibration.  there is an icon at the top of the screen to tell you if it is on vibrate or completely silent.  But I don't know why it would ring sometimes and not at other times.
I don't know what temperature the battery should be when it charges, but 46C does seem rather hot! My battery started off dying quickly and then got better, but now it seems to be losing power more quickly again.  I don't think I usually have anything extra running in the background, though in my case I do sometimes forget to switch off the wifi when I go out.
Then might be it is a hardware prob. However, this is a big prob for me.
