phone frezzes and ics not so ics
Can you please explain your problem a bit more detailed?
When does it freeze? What are you trying to do when it does?
yes sir, there is a problem with ICS update.. I would like to give a specific example. While playing Stick cricket in Android 2.3.4 there was no problem at all.. now i.e after updating, it gets struck. Hardly there is no changes in the user interface except. The only noticable changes is that there is increase in the no. of bugs. And the screenshot option is removed
One more thing is, even after deleting the photo, it's thumbnail is not deleted
this is the major problem in Gallery.. So much of lag
I'm telling my friends not to update for ICS.
I request you to please fix this problem and release a new update. I'm waiting for your positive response. thank you
First of all, the screenshot option was not removed. Just press the power button and volume down button at the same time.
Try to go to Settings > Backup & reset > Factory data reset. Backup all data on the phone memory before you do this though since it will be wiped.
Start with this and see if any of the other problems remains afterwards.
that screenshot thing really didnt work
Try again, press both the power button and the volume down button. Hold them pressed for a second or two and you will get the screenshot.
thanks a lot Markus. I got that screenshot thing.
SERIOUS PROBLEM!!!!!!!! Touch screen is not at all working.. Plz help me markus.. plzzzzzzzzzzzz
try a test on your touch screen..
*#*#7378423#*#*
call option..
HELP!
Before the transition of my phone is very smooth but when i upgrade it to 4.0.3 or ICS it became laggy even though i didnt have application opened.. is it because of my RAM???
if its in RAM could you advice some application to clean my RAM
-Thanks
