I want to develop using Xperia S, but hang in adb configuration...
I'm using Windows 7 Home Premium. Installed Android SDK, and running. Installed PC Companion 2.1, running ok.
When connect using USB my Xperia S, with "USB DEBUG" activated, an error installing driver "SEMC HSUSB Device" appear (no driver, at all).
I've tried *ALL* (reinstall PC Companion, reinstall Windows Media Player, deleting MtpApp data, tried several drivers from different sources, ...).
None!
Using "adb devices", no devices appear. Never.
Please, help me!
4 REPLIES 4
Petter
Enthusiast
Try these drivers on the following link out and see if it works! Let me know. Slightly_smiling_Face
http://developer.sonymobile.com/wportal/devworld/downloads/download/xperiasxperianxdrivers
I had already tried that solution. It did not work. The problem, I think, is that "PC Companion", when connected in "USB DEBUG", does not recognize the phone, so no drivers installed or anything.
When connecting the phone, the message "SEMC HSUSB Device" appears in the device manager with exclamation mark. The phone is not recognized, and if I try to use the drivers of the pack, get the message that no drivers for that controller.
Ah, my windows is x64.
Has anyone been able to use this phone for programming with Eclipse?
Thanks in advance.
PD: I've tried also to add to Google USB driver ("android_winusb.inf"):
; SonyEricsson
%SingleAdbInterface%        = USB_Install, USB\VID_0FCE&PID_0DDE
%CompositeAdbInterface%     = USB_Install, USB\VID_0FCE&PID_0DDE&MI_01
%SingleBootLoaderInterface% = USB_Install, USB\VID_0FCE&PID_0DDE
But the problem continues. I can install the driver (forcing), but in "adb" doesn't appear.
PPD: May be PID=5169 in "USB DEBUG" mode? Changing "PID_0DDE" with "PID_5169", the dirver is detected, but with red alert. The phone is recognized, but "adb devices" doesn't show it 😞
HELP!!!! I bought this phone thinking in Android developing. I tried a simple HTC Wildfire, and in 5 minutes the developer system was "on". With the Xperia S in 2 days nothing. Maybe I'll must return it, and buy a Samsung instead...
PPPD: Tested in another two computers with Windows XP SP3, and in one of them *worked* (at the first try, and with the drivers installed by PC Companion)! Cleraly, it's a drivers issue.
PPPPD: Another try: I've uninstalled *ALL* Sony software. With "pnputil" I've deleted *ALL* Sony drivers references in the system. Reinstalled PC Companion (last web version 2.10.065), reset, installed phone in "normal" mode. All ok. Reset, put phone in "USB DEBUG" mode. Plugin. PC Companion search for drivers an *ERROR* (as usual): "SEMC HSUSB Device" appears in the device manager with exclamation mark. Tried to update with the Sony web drivers. A message says that already the best drivers.
Run out of ideas to continue.
Problem solved: I'm returning the phone and buy another from another company with better support.
I have same problem when I connect my phone to computer, Windows XP SP3.
I have written and call Sony Support with the ticket no. 93100411, 93110345, 93111991, 93133525 !
I have followed also to download file : Xperia_S_Xperia_NX_Xperia_acro_HD_drivers.zip, try to reconnect, restart the phone from totaly turn off, even reinstall my Windows XP SP3 ! but it is also same.
Do i have to return back my phone to the shop like Hergest, do not I ?
