I updated to 205 but still overheats
3Lions
I updated to 205 and all appeared fine for a few days
However when I use Walkman or an app that plays radio/TV it still overheats ๐Ÿ˜ž
The battery drain hasn't happened though. I've turned all the power save options off and still get it.
Anyone got any advice? I've even factory resented too!
5 REPLIES 5
shahi
overheating is available yet ! less than before but exists yet . do (force stops in settings) some apps like Line , mobogenie and ... that are open in running apps and close recent apps can help you , but overall overheating is available
Bee-Ant
As for me, the overheating and battery drain issue occur when connected to a WiFi network. Otherwise, it's just fine.
My advice is:
(1) Disable all apps that you don't use
(2) Avoid using 3G network unless it's really necessary
(3) Root your phone, and then underclock the processor to 1026 MHz
Point 3 is optional. But it's recommended.
3Lions
I've done everyhitng people mention apart form root my phone so may try that next...
its just starnge how its over heating for different things for different people
i.e. my friend has same phone and he uses bluetooth and it overheats still on 205
but when I use bluetooth it does not
3Lions
It seems pretty poor that I have to disable wi-fi / 3g as much as possible
I mean whats the point in having the phone then?
renatocaster
It's curious...because i don't have any problems with overheats with my XSP. I had overheats in my old Xperia J, but in SP not.
