HI!
I forgot my screen lock code and i haven't got MyXperia. What can i do to use my mobile?
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 80% battery.
Thanks. I will do this!
It doesn't works. I pressed power and volume up button but its only turned on.
For xperia ray,just make sure to turn it off.
can you write me easy steps?
i found my code!!! thx help but i dont need now
Good.
