HPM-85 and C510a Problem
Well I have this problme wih HPM-85 that keeps disconecting every time I press a key in the remote, sometimes I can make it to work a song or tow, but it then disconnects.
I hve the last update, and my fast port is fine. This doesn't seem to happen with other accesories, just with HPM-85 (that is new)... What can I do -.-
dirgas
HPM-85/82 or any other walkman accessories should work without problems but somehow must be paired in a clumsy manner. Volume scale is halved by default and voice dialling popup must be triggered via volume 'up' button just stalling on it. When headset connector (or adapter) is plugged in with upper pins first (as in diagonal) will result a double noise (first in left ear for Walkman OEM products) and volume rocker can be released after that. If this 'latter' method fails then down/lower combination is required first. Tested with hpm-64 (various headphones) on K800i/C510/Elm devices.
