I have wt19i (4.0.4) Live with walkman, When I move some songs from one location to other location in memory card walkman shows me two entry of the song one older which walkman can not play as file is moved, and other is new one, same thing happens when I delete a song using File explorer or pc.
Please tell me how to make my walkman automatically remove broken entry from the library list, just like it makes a new one when I save or download a new song.
I would advise backing up everything from the memory card and formatting it. There may be some corrupt files on the card causing this ghosting of deleted files.
settings > apps > all > walkman > clear everything > restart your phone
I did as you suggested, Clear Data, of walkman and walkman widget .. restart my phone, Turn on my walkman and again I am getting the same list with a lots of missing tracks entries...
are you certain that the tracks aren't somewhere in your SD card, perhaps the download folder or another folder?
Yeah,
- I downloaded some songs - walkman made there entries in the list.
- Then I move the songs to 'music' folder after listning and selecting my choice and deleted others.
- Then again when I saw the list I got two entries of the songs which I had moved (one which plays the song well and one 'old' which says' can't play the track)
- I tried to delete the wrong entry .. and it is still there, I tried deleting good entry It get deleted with my song as well.
Restart -- No change.
how did you transfer the songs from one folder to another? file manager? did you copy/paste or just copy the files? also try a different music player, it might be an SD card issue.
Using file manager..
I cut-paste some files, and delete others.
and I am getting this issue .. I did try deleting using PC also and I am facing the same problem.. Now my Library list has lot's of broken entries
try a different music player and also test your SD card on another phone.
