Hello Sonymobile.
My Sony Xperia Z1 turned itself off two days ago when I was making a phone call and not running other apps (40% of battery charge at the time), the phone just shut down and I could feel an extremely weird heat afterwards. I left it to cool down a little bit which it took a few minutes, then plugged it in the wall charger. Two days now and the only sign I have been seeing is the RED LED blinking...Nothing more.
PLEASE NOTE THE FOLLOWING:
*1: I tried to do the hard resest combo (power button + volume up button) as suggested in many forums = no sign of life
*2: I tried to do the fix update via Sony PC Companion but unfortunately I can't get my device recognized as I supposed it should have 50 % + of charge which I assume the phone doesn't have it and that is because it won't charge at all!
*3: I tried to leave it connected to the wall charger for the whole day = no signal of life...
Now I have a dead phone...What do I do with it? Please HELP!
If you press and hold the volume down button and plug it into the computer whilst holding that button, do you get a solid green notification light?
Hello Sam, I tried that as well but all I keep seeing is the red light.
Ok, in this case it looks like you will not be able to run a software repair as it will not connect in Flash mode so I can only advise you to speak with your local Xperia Care team regarding having an assessment arranged.
