As the title says - 'How do I enter the unlock code' on my CK13i?
I have been issued with the code from my network provider, but cannot seem to enter it into the phone.
Any help would be gratefully received.
Thanks all,
Cake.
Have you inserted the SIM card from another network, that the phone doesn't normally accept? In some cases, you need to remove the SIM card altogether.
Hi Dr_Chris,
Thanks for the swift reply. I have tried inserting the new sim card and turning on the phone. It says something like 'insert sim card' - emergencies only (or something similar). I try to enter the code, but it allows a max of 6 numbers. It does this with the correct sim in or the wrong one (also without a sim).
Hope that kinda makes sense, been a looooong day.
Thanks,
Cake
http://support.gsmliberty.net/index.php?_m=knowledgebase&_a=viewarticle&kbarticleid=60 Try the instructions on this page, under other SE phones at the bottom, and see if that works.
Nice 1 Dr,
I can get to the submenu, the number i have been given seems to sork in the SPCK menu, but the phone still stays 'wrong sim'. Will i need the 'network' code, cause i have tried the one i have in the network submenu and it says wrong code. tried it twice, 3 left.
Making progress here, thanks.
Cake
Not quite with you here, but it may be that your network provider has given you the wrong code.In any case, you should contact them to make sure and also ask them for precise instructions on how to enter the code, because this is a very recent model.Let me know what happens.
Chris
Thanks Chris,
I'm waiting for a call from them (hopefully tomorrow). I'll post the result when i know something.
Been a great help mate, appreciate it.
Cake
Let us know how you get along.
Your carrier should provide you with the correct instructions here. Hope they can help you.
Thanks all, phone is now unlocked. The instructions at the bottom of this page worked a charm. Thanks for the link Dr_chris. The problem I had wasn't helped when Virgin gave me the wrong unlock code.
Thanks again,
Cake
Unlocking a CK13i:
1- Switch ON your phone with or with no Sim card.
2- Press left on the multi-direction hat switch (sorry guys, probably a correct word somewhere).
3- Press the * (star) button twice.
4- Press left on the multi-direction hat switch again.
5- Personalize menu should appear.
6- Select NCK
7- Dial in NCK Unlock Code
8- Hit OK and hopefully Bob is your mother's brother.
No problem, glad it's now sorted.
