how can you know if the battery is 100% Full(not 100% charging)
Feratus
what is your way to know if your battery is already 100% full( not 100% charging) without looking at settings>power management>battery over and over again? when my phone was still on GB, i remember that when i am charging my phone, the thunder icon in the battery will be gone if the battery is 100% full already, but after the ICS upgrade, the thunder icon is still there even if the battery is already at 100% full, so i have to check my battery at settings>power management>battery over and over again. just want to ask, what is the easiest way of knowing that the battery is 100% full already? im aware of apps on google playstore but i dont want to install them, just want to know a way just by the phone's original features(like what ive said that when it was still on GB that the thunder icon is disappearing) thank you very much in advance.
14 REPLIES 14
Talal
When battery charging is shown as 100 %, just unplug the charger as it is fully charged. Going over and over again to ''settings>power management>battery'' to check status just indicates OCD. So, Pease do not do it. Slightly_smiling_Face
Feratus
but it shows that it is still charging even if it is in 100%. i dont have OCD, im just checking it over and over again because it shows that it is still charging, but if it shows that it is full then i wont check it again.
Talal
Use ''Battery'' application instead. I personally use it in my cellphone as well. It does not consume much resources. Therefore, it will not slow down mobile phone. You can enable notifications or its widget on home screen to give a quick and easy look at battery stats.
Feratus
bump.
jatinrungta
Enthusiast
What you can do is charge in Of mode and then you will know when its not charging
Feratus
what is of mode? hmm by the way, im asking how to know if the battery is already 100% full without checking in settings, my phone has no problem with charging, it is always charging normally.
ghencea-RO
There are apps who tell you about it. 2 hrs (socket not USB) should do it completely if you don't use it during the charging, let's say 2:10 h to be sure if you don't have a battery notifier app. 100% appears after 1:30-1:40 hrs.
jatinrungta
Enthusiast
I know that from off mode I mean that turnoff your phone and recharge will always Show info correctly
Feratus
thanks for the info, but is there a way to know if it is turned on? because i always charge while im texting so thats why i like an easy way to know if my phone is already 100% full without looking in settings. thanks in advance.
