Home Screen pane
rom00
Home Screen pane
hellow someone can help me because my xperia Z3 compact, home screen pane was different as before. please advise, how can i return it same as before.
Please have a look into the Picture below,
Left Side Before and right side present;
please have a look into the screen pane
left side is like a 3D and rigth side is like 2D same as normal image.
please advise, thanks.
beforenow
8 REPLIES 8
Hampus
I'm not completely sure what you mean. Do you mean that the right screenshot is more flat in the design? In the latest software version, it's a different design. I think that you have updated the phone to the latest version and thereby, why it looks differently.
profile.country.RO.title
_alexdon_
Is the same thing this user is talking about?
/t5/Xperia-Home/How-to-enable-the-3D-Cube-effect/m-p/909058#M99
alexdon
Thommo
Genius
i guess that thread answered this one also - It was changed after updates
rom00
Yes the rigth screen shot is more flat .. What should i do? Please advise
_alexdon_
Why haven't you read what Hampus said? This is after some updates,most probably UI designers opted for it.
alexdon
Hampus
@rom00 Unfortunately, it's not possible to go back or change any setting to get the old design. Perhaps you can look at Google Play store for a third party launcher which may change the design.
RohitTech
It depends on what xperia default themes you have applied currently. Also there are animation settings.
Go into Developer options and you will find Transition animation scale along with other similar options. Tweak it to suit your needs.
Also select the default first xperia theme.
rom00
Mr.rohittech, i did all what you said but still nothing happen.. I need is to return back the 3d transition of my home screen page. Anyway thank you for all concerns, hopefully I get the solution..
