I decided to update my software on my xperia x10... so i tried to open my pc companion and remembered why i hadnt updated it before ... because the pc companion will not work! so i downloaded the pc companion again and guess what, it doesnt work.
It downloads fine and then when i try to run it, it says "you must close all programs and restart your computer before running this program". so i do this and try again and it still says "you must close all programs and restart your computer before running this program".
I have spent the last three hours resarting my computer making sure all my programs were shut.
PLEASE HELP ME!!!!!!!!!!!
For me, that works. I can access the files on the phone's memory card. No errors in Device Manager.
Actually, that was all I wanted. I really thought you needed the file manager in PC Companion to access the files, like it was with my old P1i phone.
It is still annoying that PC Companion won't install, but when the time comes to upgrade my phone I hope the problem will be solved. (Actually, the chances are quite high I will choose another brand next time.)
@ Thomas.S - I’m sorry to hear that but glad that you have got file transfer sorted. Please be aware that I have tested this with the same operating system without problem. This indicates that there is a third party software confliction or security restriction on the PC that is interfering with the installation. Given the almost infinite different configurations you could potentially have on your PC this become difficult for us to tell you exactly where the issue lies and I apologise for any inconvenience this may cause.
@ jennar 1991 - If this is a work PC that you are trying to install the application on, the likely issue is that you will not have the correct administrator rights to perform this installation. Can you confirm this?
One more thing, older versions of PC Companion installed and worked fine. It is only the latest version which does not install properly.
During my struggles to update to the latest version, I made an un-install followed by a successful install of an older version which I found online. I used that version for some weeks, until one day I was explicitely told by a pop-up window that I had to upgrade to the latest version. Which did not install.
Hello,
I have the same issue, so my PC Companion sync is not working for the last weeks. When could we expect a new version of PC Companion from SonyEricsson, that solves the issue within the 2.01.231 version?
/Roger
Tomas.S
The uninstall of the PC Companion succedded, however I got the same error messages when trying to install v2.01.217.
Which version did you succeed to install? Could you please supply a download link to the older version of PC Companion that you used?
Thanks,
Roger
I think I used version 2.01.187, but I am not certain. I just googled for another version number and found a site which provided older versions. I do not remember where it was.
But the thing is, the PC Companion update manager (or the PC Companion itself?) recently did not allow me use this version anymore. It would not start, there was only a message that I need to upgrade in order to use it.
Yes. I have to upgrade my Xperia M to Android 4.3 and I face the same issue. What pisses me off and further disappoints me are all bugs and issues I faced using Sony PCC. First up, it was unable to upgrade due to Windows Firewall, despite the fact it was disabled. I tried removing PCC and downloading it again since this helped to upfrade my old Xperia Play. When I try to install, I get the same error message. This is the last time I buy an Xperia smartphone off Sony, due to their in competence when it comes to eradicating issues. I'm surprised no Sony official replied to this.
Hope Sony's Cyber Shot cameras are better than this garbage!
