Help needed, Xperia Sola shuts down after SIM Card is inserted.
kayjay
Hello guys. Help needed here.
I am a Xperia Sola MT27i user from Malaysia. I had been using this phone since October 2012 and it was performing well up to my needs.
Last night, when I was engaged to a phone call, my Xperia Sola shuts down automatically. I tried to restart the phone but once I key in my SIM Card passcode, the phone shuts down again. I repeatedly trying to switch on the phone but every single time I key in my SIM Card passcode, it shuts down.
Next, I removed the SIM Card and tried to switch on the phone and it was running perfectly FINE, without the SIM Card! I was able to connect to the WiFi, all apps running well, view photos and play music, just like how it was before.
Thus, I assumed that the phone is alright and again inserted the SIM Card and tried to start up the phone. Again the problem comes, once I entered my SIM Card passcode, the phone auto shuts down, without any warning or message, the screen just go blank. Tried for another 5 - 6 times but my attempts ended in vain.
To reconfirm, I took out the SIM Card and switch on the phone again and EVERYTHING is 100% fine!
In addition to this, i would like to make it clear that :
-my SIM Card works fine with other handphones and that
-inserting other SIM Cards into my Xperia Sola ended up with the same result.
Moreover, the Xperia Sola works perfectly fine WITHOUT a SIM Card.
it also works perfectly fine if
-I did not key in my SIM Card passcode and let it be in SIM Card LOCKED Mode.
-and perfectly fine in FLIGHT Mode
Please help. I am really anxious and frustrated regarding this issue.
12 REPLIES 12
cyberion
I'm having the same problem with my xperia sola. Can you elaborate more on how you make your phone did not shut down when sim card is inserted?
Any other facing the same issue? Please share how you solve it
mritunjayk477
I have also same problem. Please instruct me. how you solved this issue.
your suggetsion is really appriecated.
Thanks
Nikos0808
Still having the same problem too. Can't undestand how you fixed it!
thank's
