I'll upload the firmware to my hosting account so check back tomorrow or later tonight and i'll have everything sorted for you
UK Generic firmware here Version C6903_14.4.A.0.157 Generic UK.ftf
Manual flashing - See guide here
You don't need to create a firmware as that's above but you will need the Flashtool program installed and the firmware above placed in the correct folder as directed then follow the guide on how to flash found about half way down
or you can use the full guide to download and create yourself the UK generic LP firmware for manual flashing, the same method is applied to all Xperia devices
hi again, I have followed your guide and have downloaded your firmware link, problem is my flashtool program cant find/see the firmware program, now on the guied the downloaded firmware has many file but this firmware i got only has 4 files inside, do i need to unzip it?
Follow the instructions on my post
/t5/Xperia-Z2/How-to-manually-update-downgrade-root-2014-Xperias/td-p/593459
You don't need to unpack the firmware from my post above - just download it and flash through flashtool
