My problem:
I suddenly froze screen Make a restart of the device By pressing the yellow button at the back After the device is shaken three times It prepared a device driver from the main operating button The device starts to boot process Then the word SONY show After that show the word android After this animated start screen But it immediately freezes Then the device returns to repeat the same steps Without interest
Try performing a system repair using PC Companion as this will often fix issues - This will factory reset your phone and erase all data
Thanks very much
I'm going to experiment
