There are other threads on he same topic, use the search bar and you will find answers, the phone will get hot the more you use it, if you have intrussive apps such as taskillers task managers antivirus etc it will heat up your phone faster same if you are syncing your phone or if you have your data on or wifi on, that's NORMAL.
As far as the screen, if there's something covering the proximity sensor it will create this issues, it could be grime it could be a screen protector it could be a protective case, etc.
If Your phone is just warm its ok but its really hot so go to service station.
And Your Say about display goes of it is a proximity sensor, During call cover sensor and get display off & remove fingure from sensor display on, This Sensor is near front facing Camera.
And Don't forgot to click kudos.
Im also faceing same heat problem, bluish camera issue, and battery draining problem
Heating problem also persists in my mobile. But can't blame considering i was using it for internet for half-an-hour continuously. And the blue tinge is probably because you haven't removed your camera slip (blue colour) that comes with your camera to protect the camera surface during packaging.
@sonyxperiam wrote:
I have a battery problem, when I fully charged at ngt morning the battery shows 50%, but imnot use the phone that time..and also the bluish in my camera always make me trouble..
