Hello!
I just bought a Sony STH30 Stereo Headset for my Xperia Z1.
But when pressing the "Volume down" button on my headset, the key is hold for 5 to 10 seconds.
This only happens on the Xperia Z1, it's working fine on other phones.
It also works pretty fine when changing the volume of an active call - it only happens when trying to lower the volume of the phone or music.
Greetings from germany,
Daniel
Hi, I have exactly the same problem, the STH-30 head set is compatible with the Xperia Z1 compact according to the Sony website but it simply doesn't work. This is simply a lie.
Finally there is absolutely no headset with a volume control compatible with the xperia,even their own Sony products!
Sony's staff nothing to reply??
i bought three of these headphones and only one worked. please fix this.
i have the same problem with my zenfone 5, 3 key is notworking, when i press pause/play my music player is pause and don't play again until i'm reset my phone, as the same volume up / down is nerver work, but it's work fine on samsung, sony devices ( i'm not try on Xperia Z1 )
Please tell me another way to use the three button, i have try "Headset Button Controller" app, "Smart key " app by Sony, but all is missing something like this:
- 1 click play / pause button to play / pause: OK
- 2 click play / pause button to next : OK
- 3 click play / pause button to previous : OK
- Volume Up / Down key : not working.
Please advices.
thanks.
I have the same problems with sth30 and sony z1 compact. When i press down volume headset keys freezes. Reattaching and if not using volume down working good. Who can help. I can't return headset (i win it from sony mobile ukraine as a prize)
Hey!
I have the same exact problem with my Degauss Labs 'Dual Driver' 3 button 3,5mm headphones. Pressing the volume up, works OK, the main middle button works OK, but pushing the volume down button results in one click or a concecutive long press. Very frustrating.
I've tried uninstalling smart connect, reboot and test; reinstalling smart connect and retrying. No luck. The headphones work on a Z3 and most other android phones I've tried it with.
Has anyone resolved this issue? Could it be hardware related, like a loose connection or broken component?
Update:
Tried the headset in another z1 Compact, and it works fine. Decided it's a hardware problem, since full reinstall didn't help.
Sent it to repairs, where they replaced the audio jack and side keyflex. Got it back, and the problem still persists.
