HEADPHONE PROBLEM
ceasar47
HEADPHONE PROBLEM
When I listen to the songs on headphone all are ok.But when I remove them,phone speaker output does not come.It behaves like the headphone still be plugged in.After 3 to 4 try(i.e. headphones connect disconect) it comes into normal state i.e. mobile after headphone disconnect.What to do????:smileycry:Slightly_frowning_Face
5 REPLIES 5
Samuel1
Hero
Seems like something is wrong indeed. Have you tried repairing the software via PC Companion to see if it's related to the software.
If not, try it! http://www.sonymobile.com/update
If the problem still persists after the repair, send the phone in to a service center for a check, since it might be related to the headset connector.
ceasar47
when I connect my phone with pc companion it says I am already up to date....Is any other procedure....for cure....PLS help!!!!!:smileyplain:
Samuel1
Hero
Yes, try the repair phone option instead of update. A repair will re-install the current software in the phone.
ceasar47
pls guide me to find repair option in pc companion......I canot find it...
Samuel1
Hero
Click Support Zone > Update phone. When you get the message telling you that the phone already is updated you have a link to the repair option. I only have PC C installed in Swedish but it should look the same no matter what language you use
