Hello Sony and other users
If updated my Neo last week from the stock firmware to 2.3.3 build 4.0.A.2.368.
After that I have issues with GPS signal (DOP). Programs like RunGPS, Google Maps and Navigon loses GPS signal exactly every 5 minutes für about 30 seconds. After that, the DOP is good again. Sometimes it helps to restart the phone, sometimes not. I've tried to find out if it depends, which programs are in the memory but nothing is really obvious.
The issue looks like this:
Yesterday I've updated to 2.3.4 4.0.2.A.0.42, but the issue is the same. I've read in another forum that sometimes an update of Googe maps could cause this problem. So I've deinstalled the last update of Goggle maps. Before that I had this issue, directly after that it was gone, but it came back although I did not install the update of googe maps again (Auto update was disabled).
Before the firmware updates I did not have this issues.
What can I do? Are there some log files, which can help? Any idea?
With this issue the GPS is not really usable. Is it possible to downgrade?
Thanks
Hello
I deinstalled all updates. And I cleared the cache of each program. What other "options" do you mean?
Problem still exists.
Bye
I changed to alogcat as logging tool and found that.
Exactly every 5min and exactly fitting to the DOP problem in RunGPS (see picture) I got this:
10-31 13:36:19.737 D/lib_locapi( 238): loc_event_cb: get loc event location server request, event = 1
10-31 13:36:19.737 D/lib_locapi( 238): loc_eng_agps_data_conn_failed
10-31 13:36:20.750 D/lib_locapi( 238): loc_eng_ioctl for ATL returned 1 (1 for success)
10-31 13:41:20.706 D/lib_locapi( 238): loc_event_cb: get loc event location server request, event = 1
10-31 13:41:20.706 D/lib_locapi( 238): loc_eng_agps_data_conn_failed
10-31 13:41:21.746 D/lib_locapi( 238): loc_eng_ioctl for ATL returned 1 (1 for success)
10-31 13:46:20.757 D/lib_locapi( 238): loc_event_cb: get loc event location server request, event = 1
10-31 13:46:20.757 D/lib_locapi( 238): loc_eng_agps_data_conn_failed
10-31 13:46:21.767 D/lib_locapi( 238): loc_eng_ioctl for ATL returned 1 (1 for success)
Look at the timestamp.
It doesn't matter if 3G is on or if I'm using Wifi.
In the settings (Standort&Sicherheit) "Drahtlosnetzwerke" was deactivated! The hint, that Google sends anonymous location data forced me to deactivate it.
If it works with this activated I will test later.
Hopefully anybody can give me a feedback.
Hello Sony!
This is a big problem!
Summary:
1. After a certain active time of the phone (1h-4h) in each program which uses GPS every five minutes the phone tries to get contact to the AGPS server and the following error occurs.
During this time (30sec) no GPS signal is available. The DOP is very high.
2. If the phone is in flight mode, the problem disappears. Again active, the problem is present again.
After reboot no problem, but after 1h-4h on time the problem occurs again.
3. The problem occurs since update to 2.3.3 and also in 2.3.4.
4. Every GPS program is affected. RunGPS, Navigon, Google Maps. Independend from each other.
5. Other Sony phones (Arc) from other users have the same problem since the newer updates.
6. Even after hard reset right from the beginning the problem exists. So it has nothing to do with other installed programs.
So please solve this issue. It is definitly a bug!
Please make a comment!
Please help!!!!!!!!!!!!!!!!!!!!!!!
Thanks
just out of curiosity, go to settings -> location & security -> what do you have selected?
Use wireless networks?
if you have this selected, did you allowed Google to collect anonymous location data?
use gps satellites?
I have exactly the same problem as you. I have the xperia mini pro (sk17i).
The gps signal lost every 5 minutes for 30 seconds.
This is definetely a software bug. It happend with android 2.3.3 and 2.3.4.
I bring the phone 2 times in 2 different sony ericsson service centers here in Greece, but they didn't fix it.
Sony please do something! Give as an advice please!
Yes, it looks like a software bug. The agps should remain off once gps has a fix. The agps just helps get a faster gps lock and is not needed once gps lock is aquired. The agps uses mobile phone towers to get a rough location and time.
Another possibility is interference from the phone temporarily signal blocking the gps satellite signal. This could still be fixed with software to coast past this interval and relock on the satellite signal.
Sony, what do you think?
Hello Sony responsibles
I know 3 Users now with three different phones (Neo, Arc, Mini Pro) in three different countries (Germany, Greece, Rumania) with the same problem.
Whats going on!!!!!!!!!!!!!!!
What can we do to help! What things do you need to solve the problem?
Is the problem known? Do you need some protocols?
Please answer Sony!!!!!!
I have a Xperia Ray in Australia with 2.3.4 and have exactly the same problem. GPS lost signal exactly every 5 minutes for about 30 secs.
Hi all, first of all - sorry for not posting earlier.
We've missed this thread for some unknown reason. Of course not our intention to ignore this.
I've created an internal escalation ticket on this to get it investigated and to get some answers/info.
As soon as I have something to tell, I will post this here in this thread.
Hello Markus
Escalation ticket sounds good to me.
It's maybe an Android native problem (also).
If you need some more logs or something tell us.
And if ICS is the solution do not hesitate to provide it ;-).
Bye
