GPS icon always on in top bar
Doomdrou
Hi all,
My problem is that a few hours after I boot my Xperia M4 Aqua, the GPS icon appears and is stuck at this position until I disable GPS completely or I restart the phone.
I'm starting to believe I have a defective unit, or is it something that can be solved easily?
Thanks for your help!
Tags (1)
19 REPLIES 19
Doomdrou
Did it. Problem continues.
I really think I have a defective unit. This can't simply be explained by bad software...
@Doomdrou
Contact your local Xperia care and keep us updated
GRADAN31
I see what you meant. I personally feels that it is a software issue.
I tried on mine using Google Maps. It requested me to turn on location service and I allowed. after exiting the application, the Location Service is still on at High Accuracy, even after 5 mins in sleep mode. I.e. it do not auto turn off like yours.
For me, the workaround is to maually turn it off, until Sony finds a better way to auto turn it off.
Doomdrou
So it's probably it. Problem is the PC Companion update is a lot buggier than the one I had originally on...
M4userr
Same problem here after pc companion update, any news?
Can I flash the old firmware? How?
thanks, i hope a early Sony update for this problem
IkhsanLPK
I have same problem on my xperia m4 aqua to. any solutuon?
DiTzev
I am experiencing same issue after an app that uses location service is used location icon will stay on until reboot or manually disable location.
DiTzev
Hi, again I would suggest clearing data of swarm app if you have it. For me it seems that's where the issue was. Now the icon is gone and if I log in swarm it gets stuck again!
Johnnysaint
I have the problem described. For me, the issue has only started in the last week or so. I've not recently installed a new app. I have a feeling that it started after updating a number of apps but I can't identify the problem app.
Any ideas?
Mwael
Guys..problem exists while gps is manually turned off, it happens whenever i open the gps and close it again, the icon then keep showing like an error , i have the same problem for many month.. Its very disappointing i didnt see any solution from sony on this..however issue was just solved after upgrading to the new software last week
