GPS Bluetooth Wifi problem
Gigi_Biru
Recently my Xperia C fell in the water and after that my phone wont turn on. so i dissamble the back part to dry it. after that, it turn on and everything is fine except GPS, Bluetooth and Wifi. Try repair my phone with xperia companion but the problem still the same. so i assume maybe the signal has broken. I try to buy the part onlinebut i dont know which one to buy. I'm not phone expert. So can anyone help me give me a link or the name of part i should buy ? I also fine in ebay but I'm not sure it is the correct one.
http://www.ebay.com/itm/WIFI-SIGNAL-ANTENNA-FLEX-CABLE-RIBBON-FOR-SONY-XPERIA-C-C2304-C2305-S39h-/17...
and my network sim signal works fine. Pls help.. Thank you
CameronT
Hi @Gigi_Biru,
I am sorry to hear about the issues you're having with your Xperia Slightly_frowning_Face
Based on the fact that the device got wet and the issues began after that, I would recommend you contact your Local support team to arrange an assessment and repair.
