Google Sky Map shows wrong directions
viktanwar
I observed that Google Sky Map points in wrong directions.
The behaviour is different in landscape and portrait mode i.e. If the phone is portrait then East and West are interchanged and if landscape then North / South are interchange.
Compass application points to correct directions.
Any guess, Google Sky Map is showing version 1.6.1.
39 REPLIES 39
htc magic, android 2.2.1
everything works as it should.
Flashed my Xperia Mini Pro with CyanogenMod 7.1, compass apps work fine now. 😛
viktanwar
It confirms that the problem is software glitch needing some attention. I'll wait till the next update from SE to 2.3.4.
Btw can u confirm having got video call facility over 3g by this mod.
Anyone have 2.3.4 yet (mini pro) and can try Google Sky Maps in landscape... seeing if it rotates the right way?
Thanks
Slightly_smiling_Face
i have a mini pro and the 2.3.4 Update has not fixed the issue
maybe i have to switch to cyanogen mod
Updated my mini pro to 2.3.4. Now Google sky map is working perfectly OK.
So basically I have a 50/50 chance of it fixing the problem!! lol
Although I did have the exact issue you described so hopefully it will be all good....
viktanwar
Thank You @ Johan-SEAnswers
Update to 2.3.4 just today and the Google Sky Map is correctly pointing.
All good here too ... thanks Johan-SEAnswers for passing it on.
Gamal
(in my case, at least)
before:
ak897xmagnetic_axis_map = 0,1,2
ak897xmagnetic_axis_sign = -1,-1,1
after:
ak897xmagnetic_axis_sign = -1,-1,-1
  • (not rooting required, but only works for this app) now that sky map is open source, you could modify PlainSmootherModelAdaptor.java:line 53 at package com.google.android.stardroid.util.smoothers
before:
      // The z direction for the mag magneticField sensor is in the opposite
      // direction to that for accelerometer.
      // TODO(johntaylor): this might not be the best place to reverse this.
      magneticValues.z = -values[2];
after:
      magneticValues.z = values[2];
