Google PlayStore Problem after update ?..
Hi All,
After Updating to Android ICS im not able to download any app from Playstore it gives error such as " Could not be downloaded due to an error (927)?..
Need suggestion how to get rid of this error?..
19 REPLIES 19
check if your data plan is working.
also settings -> applications -> manage applications -> all -> play (market) clear data and uninstall update
Its helping but im still not able to connect to internet though i have active data pack ?..
Should i try and repair phone through PC Companion ?..
you need either a data plan or wifi
settings -> xperia/sony ericsson -> internt settings
according to ur suggestion i uninstalled the update but now im not able to connect to internet as it says no connection .. i have checkd all settings and settings are connect ..  i tried to repair phone through PC Companion but it was giving error Server Overloaded how i can i repair it again ?..
I reinstalled the ICS update then to not able to download apps from google Market get error with error number 495. I have uninstalled the update for Market then too its not working fine. Please suggest a workaround or should i downgrade from Service centre ?...
if u cant access ur data.. go to mobile network settings>access point names>see if ur apn is entered.
if u know ur apn enter it or else get ur apn from your mobile network provider.or try through the setup guide already provided in the phone..
Then uninstall the google play in your phone and try downloading google play from third party site{by typing google play free download in google search}..
i hope this works.. if it doesnot then try repairing ur phone through your pc companion .or sony update service.
neo1
how to reset the google play account, i don't need to see the history of all the apps i used since i registered with the market, as i have many and many apps from there.
open your browser and go to
time.gov
does it work? if it doesn't then your data plan is the issue.
Markus1
Leader
Doesn't seem to be possible. I just logged in at play.google.com and had a look around. Couldn't find any such feature to clear this list. You should ask Google about this if you want to take it further.
