i am having problem syncing contacts to google account. it says "google sync experiencing some problem please try later" but the sync is working fine on my other android device (samsung). expecting solution ASAP i am frustated as i have to do the contact updates on phone. while i prefer doing it on computer.
If this has been going on for a while I suggest that you try to run a software reinstall using SUS.
thanks for the reply. i think i found what causing this problem
this is happening after i create a new contact and store it my gmail contacts rather than storing it on phone contacts
i found it by trial and error. i cleared contact storage cache sync works fine.
just after creating a contact and tried to store in google account, the syncing fails.
no luck after software reinstall also.. syncing fails if i create a contact under google account
im facing exactly the same problem., Pl suggest an appropriate solution if you found one.
Thankyu
