Hi rahulkapadiya1,
Welcome to the community,
In regards to the hearing aid option, I can advise that this is for the hearing impaired, it allows hearing aids to connect to the device, supplying them with the ability to hear on calls.
In regards to the Gmail sync, was this happening prior or only just started?
I hope this helps.
It was working great before but when I deleted the Google account and re sign in, this problem occurred
Can you try the safemode mode boot as suggest above and let us know how you get on?
here are the instructions on how a Software repair is done.
1. Before you start you have to download the PC Companion software from PC Companion
and install it on your PC.
4. Phone Software Update.
5. Start.
6. Repair Phone
7. Continue
8. Accept data removal
9. Next
10. Wait for prepare
11. Select Phone
12. Follow the connection steps
