game lag and pause state
hi i am having the same problem with my xperia arc s which i recently bought, one week!! and yet as i start playing a game i got lag and game when to pause state, i have check my OS version which is the latest one. so i am still wondering where is this issue coming. can anyone help me on this?
Phone OS version : Gingerbread 2.3.4
Kernel version:2.6.32.9
Build:4.0.2.A.0.42
27 REPLIES 27
do you have a taskiller installed in your phone?
was the game from the market or is it an emulator?
are you running other heavy apps in the backgroun?
yes i got a task killer on, and this problem applies for all my games from market and other, games from emulator works fine
the problem might be the taskkiller, you don't need the taskiller, it was needed before but now a days, it's not necessary, it drains battery and makes the phone act up.
did this happened before the update?
it was already 2.3.4 when i bought the phone, is it necessary to use "chainfire 3D" to play these games? let me give a try uninstalling taskiller
nope same thing happening, i have just uninstall taskiller but same thing
you have to uninstall it -> turn off your phone -> take the battery out -> press and hold the power button for 5 seconds -> put the battery back on -> try again
ok it is working fine for now thanks for your help but was wondering why would taskiller bug all games
taskillers might stop some parts of the OS that are needed, or sometimes it stop certain extra permissions that a game needs or wants to use
don't forget to mark the correct and helpful answers
another suggestion
Make sure you backup everything
Use one of these links to download the
Backup & Restore app
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apk
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
How to install it
You need to
download IO File Manager
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
open your phonebook
on your computer
Apps
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
market my library.JPGmarket my library 02.JPGmarket my library 03.JPGmarket my library 04.JPG
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
or your SMS use
"backup & restore SMS"
or for your MMS use "Save MMS"
Call Logs
And for call logs this is great
