Front facing camera
jadena
Front facing camera
When trying to use the front facing camera the screen is black. All camera options still work and the photo takes but everything is black. Anyone had a similar issue or know how to fix this. Thanks
3 REPLIES 3
profile.country.RO.title
_alexdon_
Settings-apps-all-camera,force stop and clear data. See how it is.
alexdon
jadena
Just tried and no joy.
_alexdon_
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
alexdon
