got a little issue with the configuration of the front camera, the deal is that in the normal camera I can use the whole screen.. but in the front one it closes into a smaller square, and not the whole screen like the normal one, how I can change this setting?
Thanks!
The front camera uses 4:3 aspect ratio which means that you will see black bars on each side of the picture since the display is widescreen. There's no setting to change this.
