Front camera problem e4g
kisiel
Hi, i have a problem with front camera. Well my e4g is acting like it hasn't one. When I turn on camera it's always the regular, better one and there's no icon that could switch to the front camera. All the apps that use the front camera aren't working too. I've tried to clear cameras data, I've tried to turn off all google apps (ok google too) with no effects. Please help
2 REPLIES 2
Thommo
Genius
Try performing a system repair using PC Companion as this will often fix issues - This will factory reset your phone and erase all data so best to backup before you begin
Thommo
Genius
If that fails then I'm sorry to hear this but you would need to either return your device to the place of purchase or contact Xperia care and have your device inspected http://www.sonymobile.com/global-en/support/contact-us/
