Upgraded my Xperia Ray to ICS last night and when I went to test the face unlock, it only prompted to take a picture with the rear camera.
Also the phone camera shows the same screen, without the icon to switch to the rear camera.
Where can I enable my front camera again?
Try repairing using update service or PC Companion.
This should work. I just tried it out with the Xperia ray next to me.
Do what TechGC suggested and repair the software with PC Companion. Should hopefully fix it.
I had also found same problem. On touch to Camera icon, Message "Unfortunately, Camera has stopped" is appeared.
Actually I updated Ginger Bread OS to ICS OS 8 months ago, and before problem occurs my Xperia Ray was working absolutely fine. But after 8 months, real issue was faced.
I'm software engineer and so, just tried to udpate software by PC companion and even with Sony's service update from my system. But camera was working first 2-3 times and then, same issue was realized and stopped functioning for camera.
When I contacted Sony's authorized service center, he guessed it may be issue of ICS updates as it may not compitible with any of hardware of this phone (Xperia Ray) and resulted into hardware failure.
At same time I argued that it was working till 8 months and after suddenly stopped, they replied that it may be faced with bubbles(software compatibility issue that cause to error) and 95% will work for old original OS (Ginger Bread) as sony didnot care for future release of Android OS while making handset when Gigner Bread OS was making Boom.
And Yes, my Xperia Ray is working fine with Ginger Bread OS. So this will indicate point to Sony, if handset of Xperia Ray (2011 Xperia Series) phone is not compatibile then why they are sounding loudly that they are releasing ICS os for all 2011 series Xperia Phone?
And why, they are not caring while own development on ICS to make comaptible of all 2001 Xperia series phone?
Should it be release on the cost of valuable customers? this is simple question to SONY who are giving promise for satisfaction result of their brands!!
I test this function and the 4.0.4 (4.1.B.0.587) is working OK.
Maybe it is a hardware fault.
Try to test front of the camera in the camera application.
It's not the problem (eg a country India) :
Yes Veresova,
I tried with well known Camera 360 application as alternative to inbuilt Camera application. But still there was same issue.
In Inbuilt Camera application, I disappointed for log generation as Camera was interrupted to run and this was not caught by inbuilt Crash Monitor application in ICS 4.0.4. Hence, generated log could not be seen for inbuilt camera.
But Camera 360 application is good enought to at least send feedback with generated log. Please review following log of Camera 360, if you can mean to reach any idea what may happened:
================Cell input parameter for Camera 360===================
Your cell-phone parameter is as follows:
TimeZone : Asia/Calcutta
Language: English
CountryCode : IN
Model:ST18i
SDK Ver:15
Virsion:4.0.4
CPU Info:Processor : ARMv7 Processor rev 2 (v7l)
BogoMIPS : 681.57
Features : swp half thumb fastmult vfp edsp neon vfpv3
CPU implementer : 0x51
CPU architecture: 7
CPU variant : 0x1
CPU part : 0x00f
CPU revision : 2
Hardware : mogami
Revision : 0000
Serial : 0000000000000000
Memory Info:
Total Available Memory :137240k
Total Available Memory :134M
In low memory situation:false
MemTotal: 348272 kB
MemFree: 12536 kB
Buffers: 4044 kB
Cached: 124572 kB
SwapCached: 2276 kB
Active: 151604 kB
Inactive: 139188 kB
Active(anon): 85924 kB
Inactive(anon): 87896 kB
Active(file): 65680 kB
Inactive(file): 51292 kB
Unevictable: 11040 kB
Mlocked: 10620 kB
SwapTotal: 61432 kB
SwapFree: 55340 kB
Dirty: 236 kB
Writeback: 0 kB
AnonPages: 171516 kB
Mapped: 82636 kB
Shmem: 11216 kB
Slab: 11624 kB
SReclaimable: 3956 kB
SUnreclaim: 7668 kB
KernelStack: 4952 kB
PageTables: 8076 kB
NFS_Unstable: 0 kB
Bounce: 0 kB
WritebackTmp: 0 kB
CommitLimit: 235568 kB
Committed_AS: 4161976 kB
VmallocTotal: 524288 kB
VmallocUsed: 147520 kB
VmallocChunk: 331648 kB
Camera Info:
null__Settings: none
====================== Camera 360 LOG file =========================
--------- beginning of /dev/log/system
04-01 18:50:04.693 I/ActivityManager( 289): No longer want com.sonyericsson.android.socialphonebook (pid 656): hidden #16
04-01 18:50:04.753 I/ActivityManager( 289): No longer want com.sonyericsson.provider.voipcalllog (pid 721): hidden #16
04-01 18:50:05.113 I/ActivityManager( 289): Start proc com.sonyericsson.updatecenter for broadcast com.sonyericsson.updatecenter/.launcher.UpdateCenterLauncher: pid=1096 uid=10115 gids={3003, 2001, 1015}
04-01 18:50:05.163 D/PhoneStatusBar( 366): disable: < expand* icons alerts ticker system_info back home recent clock >
04-01 18:50:05.283 I/ActivityManager( 289): Start proc com.google.android.gsf.login for service com.google.android.gsf.login/com.google.android.gsf.loginservice.GoogleLoginService: pid=1110 uid=10066 gids={3003, 1015, 1007, 2001, 3006}
04-01 18:50:05.513 I/ActivityManager( 289): Start proc com.sonyericsson.crashmonitor for broadcast com.sonyericsson.crashmonitor/.Trigger: pid=1122 uid=10122 gids={1007, 1015}
04-01 18:50:05.513 I/ActivityManager( 289): No longer want com.yahoo.mobile.client.android.im (pid 748): hidden #16
04-01 18:50:05.633 I/ActivityManager( 289): No longer want com.google.android.talk (pid 770): hidden #16
04-01 18:50:05.733 I/ActivityManager( 289): Start proc com.android.vending for broadcast com.android.vending/com.google.android.finsky.receivers.BootCompletedReceiver: pid=1139 uid=10095 gids={3003, 1015}
04-01 18:50:05.843 I/ActivityManager( 289): Start proc com.sonyericsson.android.bootinfo:remote for service com.sonyericsson.android.bootinfo/.MiscTaService: pid=1155 uid=1000 gids={1015, 3002, 3001, 3003, 3007}
04-01 18:50:06.133 I/ActivityManager( 289): No longer want com.sonyericsson.setupwizard (pid 481): hidden #16
04-01 18:50:06.443 I/WindowManager( 289): WIN DEATH: Window{2c0959d0 vStudio.Android.Camera360/vStudio.Android.Camera360.GPhotoMain paused=true}
04-01 18:50:06.443 I/ActivityManager( 289): Process vStudio.Android.Camera360 (pid 885) has died.
04-01 18:50:06.453 I/WindowManager( 289): WIN DEATH: Window{2c18afa8 vStudio.Android.Camera360/vStudio.Android.Camera360.GPhotoMain paused=true}
04-01 18:50:06.493 W/InputManagerService( 289): Got RemoteException sending setActive(false) notification to pid 885 uid 10135
04-01 18:50:07.793 I/ActivityManager( 289): Start proc com.yahoo.mobile.client.android.im for broadcast com.yahoo.mobile.client.android.im/com.yahoo.messenger.android.receiver.StartupBroadcastReceiver: pid=1197 uid=10134 gids={3003, 1015, 1007}
04-01 18:50:07.793 I/ActivityManager( 289): No longer want com.google.android.onetimeinitializer (pid 819): hidden #16
04-01 18:50:09.373 I/ActivityManager( 289): START {act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 cmp=com.sonyericsson.android.camera/.CameraActivity bnds=[238,433][351,592]} from pid 556
04-01 18:50:09.483 I/ActivityManager( 289): Start proc com.sonyericsson.android.camera for activity com.sonyericsson.android.camera/.CameraActivity: pid=1213 uid=10007 gids={1006, 1015}
04-01 18:50:09.603 I/ActivityManager( 289): Config changed: {1.0 404mcc24mnc en_IN layoutdir=0 sw320dp w569dp h294dp nrml long land finger -keyb/v/h -nav/h theme=ComponentInfo{com.sonyericsson.defaultruntimethemes/com.sonyericsson.defaultruntimethemes.BlueThemeService} s.5}
04-01 18:50:10.543 E/AndroidRuntime( 1213): FATAL EXCEPTION: main
04-01 18:50:10.543 E/AndroidRuntime( 1213): java.lang.ExceptionInInitializerError
04-01 18:50:10.543 E/AndroidRuntime( 1213): at com.sonyericsson.android.camera.CameraActivity.onCreate(CameraActivity.java:428)
04-01 18:50:10.543 E/AndroidRuntime( 1213): at android.app.Activity.performCreate(Activity.java:4465)
04-01 18:50:10.543 E/AndroidRuntime( 1213): at android.app.Instrumentation.callActivityOnCreate(Instrumentation.java:1049)
04-01 18:50:10.543 E/AndroidRuntime( 1213): at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:1931)
04-01 18:50:10.543 E/AndroidRuntime( 1213): at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:1992)
04-01 18:50:10.543 E/AndroidRuntime( 1213): at android.app.ActivityThread.access$600(ActivityThread.java:127)
04-01 18:50:10.543 E/AndroidRuntime( 1213): at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1158)
04-01 18:50:10.543 E/AndroidRuntime( 1213): at android.os.Handler.dispatchMessage(Handler.java:99)
04-01 18:50:10.543 E/AndroidRuntime( 1213): at android.os.Looper.loop(Looper.java:137)
04-01 18:50:10.543 E/AndroidRuntime( 1213): at android.app.ActivityThread.main(ActivityThread.java:4441)
04-01 18:50:10.543 E/AndroidRuntime( 1213): at java.lang.reflect.Method.invokeNative(Native Method)
04-01 18:50:10.543 E/AndroidRuntime( 1213): at java.lang.reflect.Method.invoke(Method.java:511)
04-01 18:50:10.543 E/AndroidRuntime( 1213): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:784)
04-01 18:50:10.543 E/AndroidRuntime( 1213): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:551)
04-01 18:50:10.543 E/AndroidRuntime( 1213): at dalvik.system.NativeStart.main(Native Method)
04-01 18:50:10.543 E/AndroidRuntime( 1213): Caused by: java.lang.RuntimeException: Fail to get camera info
04-01 18:50:10.543 E/AndroidRuntime( 1213): at android.hardware.Camera.getCameraInfo(Native Method)
04-01 18:50:10.543 E/AndroidRuntime( 1213): at com.sonyericsson.android.camera.device.CameraDevice.setCameraInfo(CameraDevice.java:320)
04-01 18:50:10.543 E/AndroidRuntime( 1213): ... 15 more
04-01 18:50:10.563 W/ActivityManager( 289): Force finishing activity com.sonyericsson.android.camera/.CameraActivity
04-01 18:50:10.813 I/ActivityManager( 289): Start proc com.google.android.apps.uploader for broadcast com.google.android.apps.uploader/.ConnectivityBroadcastReceiver: pid=1237 uid=10042 gids={3003}
04-01 18:50:11.103 W/ActivityManager( 289): Activity pause timeout for ActivityRecord{2c1f7808 com.sonyericsson.android.camera/.CameraActivity}
04-01 18:50:11.133 I/ActivityManager( 289): Config changed: {1.0 404mcc24mnc en_IN layoutdir=0 sw320dp w320dp h544dp nrml long port finger -keyb/v/h -nav/h theme=ComponentInfo{com.sonyericsson.defaultruntimethemes/com.sonyericsson.defaultruntimethemes.BlueThemeService} s.6}
04-01 18:50:11.583 I/ActivityManager( 289): No longer want com.google.android.apps.genie.geniewidget (pid 862): hidden #16
04-01 18:50:11.593 I/ActivityManager( 289): No longer want com.android.exchange (pid 795): hidden #17
04-01 18:50:11.693 I/ActivityManager( 289): Start proc com.sonyericsson.gallery for broadcast com.sonyericsson.gallery/.cache.BootReceiver: pid=1256 uid=10113 gids={1015, 3003}
04-01 18:50:12.393 I/ActivityManager( 289): Process com.sonyericsson.android.camera (pid 1213) has died.
04-01 18:50:12.393 W/InputManagerService( 289): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@2bec1d20
04-01 18:50:13.213 I/ActivityManager( 289): Start proc com.sonyericsson.capabilities for broadcast com.sonyericsson.capabilities/.DefCapUpdaterReceiver: pid=1281 uid=10123 gids={1023, 1015}
04-01 18:50:13.313 I/ActivityManager( 289): Start proc com.sonyericsson.secureclockservice for broadcast com.sonyericsson.secureclockservice/.SecureClockTimeChangeReceiver: pid=1298 uid=10024 gids={3003}
04-01 18:50:13.413 I/ActivityManager( 289): Start proc com.android.calendar for broadcast com.android.calendar/.widget.CalendarAppWidgetService$CalendarFactory: pid=1312 uid=10054 gids={3003, 1015}
04-01 18:50:13.553 I/ActivityManager( 289): No longer want com.dsi.ant.service.socket (pid 924): hidden #16
04-01 18:50:13.583 I/ActivityManager( 289): Start proc com.sonyericsson.android.server.dormant for broadcast com.sonyericsson.android.server.dormant/.SimOperatorReadyReceiver: pid=1328 uid=1000 gids={1015, 3002, 3001, 3003, 3007}
04-01 18:50:13.653 I/ActivityManager( 289): No longer want com.android.email (pid 838): hidden #16
04-01 18:50:13.973 I/ActivityManager( 289): Start proc com.google.android.talk for broadcast com.google.android.talk/.McsConnectionStartedReceiver: pid=1346 uid=10000 gids={3003, 1015, 1006, 3002}
04-01 18:50:14.173 I/ActivityManager( 289): Start proc com.android.gallery3d for broadcast com.android.gallery3d/.app.PackagesMonitor: pid=1365 uid=10064 gids={3003, 1015}
04-01 18:50:14.243 I/ActivityManager( 289): No longer want com.google.android.partnersetup (pid 905): hidden #16
04-01 18:50:14.473 I/ActivityManager( 289): No longer want com.google.android.apps.maps:FriendService (pid 968): hidden #16
04-01 18:50:14.493 I/ActivityManager( 289): Start proc com.google.android.googlequicksearchbox for broadcast com.google.android.googlequicksearchbox/.SourceUpdateReceiver: pid=1383 uid=10080 gids={3003}
04-01 18:50:14.783 I/ActivityManager( 289): No longer want com.android.providers.calendar (pid 952): hidden #16
04-01 18:50:14.893 I/ActivityManager( 289): Start proc com.google.android.apps.maps:LocationFriendService for broadcast com.google.android.apps.maps/com.google.googlenav.friend.reporting.LocationReportingIntentReceiver: pid=1397 uid=10089 gids={3003, 1015}
04-01 18:50:16.123 I/ActivityManager( 289): START {flg=0x10000000 cmp=com.google.android.apps.maps/com.google.googlenav.login.AndroidLoginActivitySdk5 (has extras)} from pid 1397
04-01 18:50:16.243 I/ActivityManager( 289): Start proc com.google.android.apps.maps for activity com.google.android.apps.maps/com.google.googlenav.login.AndroidLoginActivitySdk5: pid=1417 uid=10089 gids={3003, 1015}
04-01 18:50:16.293 I/ActivityManager( 289): Config changed: {1.0 404mcc24mnc en_IN layoutdir=0 sw320dp w569dp h294dp nrml long land finger -keyb/v/h -nav/h theme=ComponentInfo{com.sonyericsson.defaultruntimethemes/com.sonyericsson.defaultruntimethemes.BlueThemeService} s.7}
04-01 18:50:16.503 I/ActivityManager( 289): Start proc com.sonyericsson.widget.togglewidgets for broadcast com.sonyericsson.widget.togglewidgets/.SoundWidget2: pid=1432 uid=10011 gids={3001, 3002}
04-01 18:50:16.543 I/ActivityManager( 289): Start proc com.android.providers.calendar for content provider com.android.providers.calendar/.CalendarProvider2: pid=1442 uid=10083 gids={3003, 1015}
04-01 18:50:16.623 I/ActivityManager( 289): No longer want com.sonyericsson.extras.liveware (pid 1015): hidden #16
04-01 18:50:17.013 I/ActivityManager( 289): Start proc com.sonyericsson.statusswitch for broadcast com.sonyericsson.statusswitch/.StatusAppWidget: pid=1457 uid=10038 gids={3002, 3001}
04-01 18:50:17.013 I/ActivityManager( 289): No longer want com.sonyericsson.r2r.client (pid 1043): hidden #16
04-01 18:50:17.703 I/ActivityManager( 289): Config changed: {1.0 404mcc24mnc en_IN layoutdir=0 sw320dp w320dp h544dp nrml long port finger -keyb/v/h -nav/h theme=ComponentInfo{com.sonyericsson.defaultruntimethemes/com.sonyericsson.defaultruntimethemes.BlueThemeService} s.8}
04-01 18:50:18.213 I/ActivityManager( 289): No longer want com.google.android.gsf.login (pid 1110): hidden #16
04-01 18:50:18.323 I/ActivityManager( 289): No longer want com.google.android.apps.uploader (pid 1237): hidden #16
04-01 18:50:18.583 I/ActivityManager( 289): No longer want com.sonyericsson.secureclockservice (pid 1298): hidden #16
04-01 18:50:18.593 I/ActivityManager( 289): No longer want com.sonyericsson.capabilities (pid 1281): hidden #16
04-01 18:50:21.523 W/ActivityManager( 289): Activity destroy timeout for ActivityRecord{2c1f7808 com.sonyericsson.android.camera/.CameraActivity}
04-01 18:50:24.433 I/ActivityManager( 289): START {act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 cmp=com.android.settings/.Settings bnds=[125,274][238,433]} from pid 556
04-01 18:50:24.733 I/ActivityManager( 289): Start proc com.android.settings for activity com.android.settings/.Settings: pid=1483 uid=1000 gids={1015, 3002, 3001, 3003, 3007}
04-01 18:50:24.963 I/ActivityManager( 289): Start proc com.google.android.gsf.login for service com.google.android.gsf.login/com.google.android.gsf.loginservice.GoogleLoginService: pid=1495 uid=10066 gids={3003, 1015, 1007, 2001, 3006}
04-01 18:50:25.193 I/ActivityManager( 289): No longer want com.sonyericsson.android.server.dormant (pid 1328): hidden #16
04-01 18:50:26.883 I/ActivityManager( 289): START {act=android.intent.action.MAIN cmp=com.android.settings/.SubSettings (has extras)} from pid 1483
04-01 18:50:28.343 I/ActivityManager( 289): START {act=android.intent.action.MAIN cmp=com.android.phone/.Settings} from pid 1483
04-01 18:50:28.703 W/InputManagerService( 289): Starting input on non-focused client com.android.internal.view.IInputMethodClient$Stub$Proxy@2c14ba10 (uid=1000 pid=1483)
04-01 18:50:31.413 W/InputManagerService( 289): Starting input on non-focused client com.android.internal.view.IInputMethodClient$Stub$Proxy@2c06fc28 (uid=1001 pid=458)
04-01 18:50:36.263 I/ActivityManager( 289): START {cmp=com.sonyericsson.settings/.ApplicationSettingsActivity} from pid 1483
04-01 18:50:36.513 I/ActivityManager( 289): Start proc com.sonyericsson.settings for activity com.sonyericsson.settings/.ApplicationSettingsActivity: pid=1520 uid=10022 gids={}
04-01 18:50:36.933 W/InputManagerService( 289): Starting input on non-focused client com.android.internal.view.IInputMethodClient$Stub$Proxy@2c14ba10 (uid=1000 pid=1483)
04-01 18:50:38.293 I/ActivityManager( 289): START {act=com.sonyericsson.intent.action.GET_PREFERENCE cmp=com.sonyericsson.r2r.client/.main.ui.StartedByUserActivity} from pid 1520
04-01 18:50:38.333 I/ActivityManager( 289): Start proc com.sonyericsson.r2r.client for activity com.sonyericsson.r2r.client/.main.ui.StartedByUserActivity: pid=1533 uid=10100 gids={3003, 1015}
04-01 18:50:38.403 W/InputManagerService( 289): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@2bf4b9e8
04-01 18:50:38.443 E/NotificationService( 289): Ignoring notification with icon==0: Notification(contentView=null vibrate=null,sound=null,defaults=0x0,flags=0x62)
04-01 18:50:38.453 I/ActivityManager( 289): START {flg=0x10800000 cmp=com.sonyericsson.r2r.client/.main.ui.CostConfirmationActivity} from pid 1533
04-01 18:50:38.843 I/ActivityManager( 289): No longer want com.sonyericsson.android.bootinfo:remote (pid 1155): hidden #16
04-01 18:50:39.563 W/InputManagerService( 289): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@2c0c15b8
04-01 18:50:40.593 W/InputManagerService( 289): Starting input on non-focused client com.android.internal.view.IInputMethodClient$Stub$Proxy@2c200228 (uid=10022 pid=1520)
04-01 18:50:44.913 D/ConnectivityService( 289): ConnectivityChange for mobile: CONNECTED/CONNECTED
04-01 18:50:44.923 E/ConnectivityService( 289): no dns provided for mobile - using 8.8.8.8
04-01 18:50:44.923 E/ConnectivityService( 289): exception setting default dns interface: java.lang.IllegalStateException: Error communicating with native daemon to set dns for interface
04-01 18:50:44.973 D/NetworkPolicy( 289): applying policy NetworkPolicy[NetworkTemplate: matchRule=MOBILE_ALL, subscriberId=valid]: cycleDay=1, warningBytes=2147483648, limitBytes=-1, lastSnooze=-1 to ifaces [null]
04-01 18:50:47.493 D/ConnectivityService( 289): ConnectivityChange for mobile: DISCONNECTED/DISCONNECTED
04-01 18:50:47.493 D/ConnectivityService( 289): Attempting to switch to wifi
04-01 18:50:47.493 D/ConnectivityService( 289): Attempting to switch to BLUETOOTH_TETHER
04-01 18:50:48.003 I/ActivityManager( 289): Start proc com.google.android.apps.uploader for broadcast com.google.android.apps.uploader/.ConnectivityBroadcastReceiver: pid=1564 uid=10042 gids={3003}
04-01 18:50:48.123 I/ActivityManager( 289): No longer want com.google.android.talk (pid 1346): hidden #16
04-01 18:50:48.143 I/ActivityManager( 289): Start proc com.facebook.katana for broadcast com.facebook.katana/.binding.UploadManagerConnectivity: pid=1584 uid=10105 gids={3003, 1015}
04-01 18:50:49.253 I/ActivityManager( 289): Start proc com.sonyericsson.androidapp.fbmusiclike for broadcast com.sonyericsson.androidapp.fbmusiclike/.facebook.AvailabilityChangeReceiver: pid=1607 uid=10117 gids={3003}
04-01 18:50:49.423 I/ActivityManager( 289): Start proc vStudio.Android.Camera360 for broadcast vStudio.Android.Camera360/org.pinguo.cloudshare.service.CloudShareServiceReceiver: pid=1622 uid=10135 gids={1006, 3003, 1007, 1015}
04-01 18:50:49.443 I/ActivityManager( 289): No longer want com.google.android.apps.maps:LocationFriendService (pid 1397): hidden #16
04-01 18:50:49.633 I/ActivityManager( 289): No longer want com.sonyericsson.widget.togglewidgets (pid 1432): hidden #16
04-01 18:50:49.881 V/BackupManagerService( 289): Running a device init
04-01 18:50:49.883 W/BackupManagerService( 289): Requested unavailable transport: com.google.android.backup.BackupTransportService
04-01 18:50:49.883 E/BackupManagerService( 289): Requested init for com.google.android.backup.BackupTransportService but not found
04-01 18:50:55.383 D/ConnectivityService( 289): ConnectivityChange for mobile: CONNECTED/CONNECTED
04-01 18:50:55.713 D/NetworkPolicy( 289): applying policy NetworkPolicy[NetworkTemplate: matchRule=MOBILE_ALL, subscriberId=valid]: cycleDay=1, warningBytes=2147483648, limitBytes=-1, lastSnooze=-1 to ifaces [rmnet0]
04-01 18:50:58.573 I/ActivityManager( 289): No longer want com.sonyericsson.statusswitch (pid 1457): hidden #16
04-01 18:51:01.423 I/ActivityManager( 289): Start proc com.android.defcontainer for service com.android.defcontainer/.DefaultContainerService: pid=1679 uid=10121 gids={1015, 2001}
04-01 18:51:01.613 W/ActivityManager( 289): No content provider found for permission revoke: file:///data/data/com.android.providers.downloads/cache/downloadfile.apk
04-01 18:51:02.143 W/ActivityManager( 289): No content provider found for permission revoke: file:///data/data/com.android.providers.downloads/cache/downloadfile.apk
04-01 18:51:02.953 I/ActivityManager( 289): Start proc com.google.android.partnersetup for broadcast com.google.android.partnersetup/.GservicesChangedReceiver: pid=1696 uid=10072 gids={3003}
04-01 18:51:02.973 I/ActivityManager( 289): START {flg=0x10040000 cmp=com.google.android.gsf/.update.SystemUpdateInstallDialog} from pid 498
04-01 18:51:03.203 I/ActivityManager( 289): START {flg=0x10040000 cmp=com.google.android.gsf/.update.SystemUpdateDownloadDialog} from pid 498
04-01 18:51:03.313 I/ActivityManager( 289): Start proc com.google.android.voicesearch for broadcast com.google.android.voicesearch/.GservicesBroadcastReceiver: pid=1713 uid=10118 gids={3002, 3003, 1015}
04-01 18:51:05.223 I/ActivityManager( 289): No longer want com.android.providers.calendar (pid 1442): hidden #16
04-01 18:51:05.233 I/ActivityManager( 289): No longer want com.google.android.gm (pid 1073): hidden #17
04-01 18:51:06.473 D/ConnectivityService( 289): ConnectivityChange for mobile: DISCONNECTED/DISCONNECTED
04-01 18:51:06.473 D/ConnectivityService( 289): Attempting to switch to wifi
04-01 18:51:06.473 D/ConnectivityService( 289): Attempting to switch to BLUETOOTH_TETHER
04-01 18:51:06.473 E/ConnectivityService( 289): Exception trying to remove a route: java.lang.IllegalStateException: Unable to communicate with native dameon to add routes - com.android.server.NativeDaemonConnectorException: Cmd {interface route remove rmnet0 default 100.65.31.254 32 0.0.0.0} failed with code 400 : {Failed to remove route from default table (No such process)}
04-01 18:51:06.473 E/ConnectivityService( 289): Exception trying to remove a route: java.lang.IllegalStateException: Unable to communicate with native dameon to add routes - com.android.server.NativeDaemonConnectorException: Cmd {interface route remove rmnet0 default 0.0.0.0 0 100.65.31.254} failed with code 400 : {Failed to remove route from default table (No such process)}
04-01 18:51:06.473 D/ConnectivityService( 289): resetConnections(rmnet0, 3)
04-01 18:51:06.833 I/ActivityManager( 289): Force stopping package com.surpax.ledflashlight.panel uid=10136
04-01 18:51:07.053 W/PackageManager( 289): Unknown permission android.permission.ADD_SYSTEM_SERVICE in package com.android.phone
04-01 18:51:07.053 W/PackageManager( 289): Unknown permission com.sonyericsson.permission.CUSTOMIZATION in package com.sonyericsson.androidapp.retaildemo
04-01 18:51:07.053 W/PackageManager( 289): Not granting permission android.permission.CLEAR_APP_USER_DATA to package com.sonyericsson.androidapp.retaildemo (protectionLevel=2 flags=0xbe45)
04-01 18:51:07.053 W/PackageManager( 289): Unknown permission com.sonyericsson.facebook.permission.AUTHORIZE_SERVICE in package com.sonyericsson.facebook.proxylogin
04-01 18:51:07.053 W/PackageManager( 289): Unknown permission com.android.vending.billing.IBillingAccountService.BIND2 in package com.google.android.gsf.login
04-01 18:51:07.053 W/PackageManager( 289): Unknown permission com.sonyericsson.permission.CONTACTS_PICK_CONVERSATIONS_TARGET in package com.sonyericsson.conversations
04-01 18:51:07.053 W/PackageManager( 289): Unknown permission com.sonyericsson.permission.ACCESS_PROTECTED_CONTACTS in package com.sonyericsson.conversations
04-01 18:51:07.053 W/PackageManager( 289): Not granting permission android.permission.SEND_DOWNLOAD_COMPLETED_INTENTS to package com.android.browser (protectionLevel=2 flags=0x9be45)
04-01 18:51:07.073 W/PackageManager( 289): Unknown permission com.sonyericsson.permission.CUSTOMIZATION in package com.sonyericsson.textinput.uxp
04-01 18:51:07.073 W/PackageManager( 289): Unknown permission com.sonyericsson.android.permission.FACERECOGNITION_SERVICE in package com.sonyericsson.android.camera3d
04-01 18:51:07.073 W/PackageManager( 289): Unknown permission android.permission.INTERACT_ACROSS_USERS in package com.google.android.gms
04-01 18:51:07.073 I/PackageManager( 289): Un-granting permission android.permission.DUMP from package com.google.android.gms (protectionLevel=3 flags=0x28be44)
04-01 18:51:07.073 W/PackageManager( 289): Unknown permission android.permission.READ_EXTERNAL_STORAGE in package com.google.android.gms
04-01 18:51:07.073 W/PackageManager( 289): Unknown permission com.sonyericsson.facebook.permission.AUTHORIZE_SERVICE in package com.sonyericsson.appshare
04-01 18:51:07.073 W/PackageManager( 289): Unknown permission android.permission.READ_OWNER_DATA in package com.google.android.setupwizard
04-01 18:51:07.073 W/PackageManager( 289): Unknown permission android.permission.WRITE_OWNER_DATA in package com.google.android.setupwizard
04-01 18:51:07.073 W/PackageManager( 289): Unknown permission com.android.launcher.permission.READ_SETTINGS in package com.android.settings
04-01 18:51:07.073 W/PackageManager( 289): Unknown permission com.android.launcher.permission.WRITE_SETTINGS in package com.android.settings
04-01 18:51:07.073 W/PackageManager( 289): Unknown permission com.sonyericsson.facebook.permission.AUTHORIZE_SERVICE in package com.sonyericsson.gallery
04-01 18:51:07.073 W/PackageManager( 289): Not granting permission com.google.android.gm.permission.READ_GMAIL to package com.sonyericsson.music (protectionLevel=2 flags=0x8be45)
04-01 18:51:07.073 W/PackageManager( 289): Unknown permission android.permission.ACCESS_LOCATION in package com.sonyericsson.android.servicemenu
04-01 18:51:07.073 W/PackageManager( 289): Unknown permission android.permission.ACCESS_GPS in package com.sonyericsson.android.servicemenu
04-01 18:51:07.083 W/PackageManager( 289): Unknown permission android.permission.ACCESS_WAKE_LOCK in package com.sonyericsson.android.servicemenu
04-01 18:51:07.083 W/PackageManager( 289): Unknown permission com.sonyericsson.servicemenu.permission.ACCESS_SERVICE_MENU in package com.sonyericsson.android.servicemenu
04-01 18:51:07.083 W/PackageManager( 289): Unknown permission com.android.providers.im.permission.READ_ONLY in package com.google.android.apps.maps
04-01 18:51:07.083 W/PackageManager( 289): Not granting permission android.permission.BROADCAST_SMS to package com.wsandroid.suite (protectionLevel=2 flags=0x28be04)
04-01 18:51:07.083 W/PackageManager( 289): Not granting permission android.permission.WRITE_SECURE_SETTINGS to package com.wsandroid.suite (protectionLevel=3 flags=0x28be04)
04-01 18:51:07.083 W/PackageManager( 289): Not granting permission android.permission.CONTROL_LOCATION_UPDATES to package com.wsandroid.suite (protectionLevel=3 flags=0x28be04)
04-01 18:51:07.083 W/PackageManager( 289): Unknown permission android.permission.ACCESS_COARSE_UPDATES in package com.wsandroid.suite
04-01 18:51:07.083 W/PackageManager( 289): Unknown permission android.permission.RAISED_THREAD_PRIORITY in package com.wsandroid.suite
04-01 18:51:07.083 W/PackageManager( 289): Not granting permission android.permission.DELETE_PACKAGES to package com.wsandroid.suite (protectionLevel=3 flags=0x28be04)
04-01 18:51:07.083 W/PackageManager( 289): Unknown permission com.sonyericsson.permission.CUSTOMIZATION in package com.sonyericsson.android.pobox
04-01 18:51:07.083 W/PackageManager( 289): Unknown permission com.sonyericsson.playnowstore.v1.permission.INSTALL_APPLICATION in package de.arvatomobile.sonyericsson.playnow.android
04-01 18:51:07.083 W/PackageManager( 289): Unknown permission com.sonyericsson.facebook.permission.AUTHORIZE_SERVICE in package com.sonyericsson.androidapp.fbcalendarsync
04-01 18:51:07.083 W/PackageManager( 289): Unknown permission com.android.launcher.permission.READ_SETTINGS in package com.google.android.onetimeinitializer
04-01 18:51:07.083 W/PackageManager( 289): Unknown permission com.android.launcher.permission.WRITE_SETTINGS in package com.google.android.onetimeinitializer
04-01 18:51:07.083 W/PackageManager( 289): Unknown permission android.permission.ACCESS_COARSE_UPDATES in package vStudio.Android.Camera360
04-01 18:51:07.083 W/PackageManager( 289): Unknown permission com.google.android.apps.googlevoice.permission.AUTO_SEND in package com.google.android.voicesearch
04-01 18:51:07.083 W/PackageManager( 289): Not granting permission android.permission.DEVICE_POWER to package com.sonyericsson.android.socialphonebook (protectionLevel=2 flags=0x8be45)
04-01 18:51:07.083 W/PackageManager( 289): Not granting permission android.permission.ACCESS_DRM to package com.sonyericsson.android.socialphonebook (protectionLevel=2 flags=0x8be45)
04-01 18:51:07.083 W/PackageManager( 289): Unknown permission com.android.email.permission.ACCESS_GAL_PROVIDER in package com.sonyericsson.android.socialphonebook
04-01 18:51:07.083 W/PackageManager( 289): Not granting permission com.sonyericsson.permission.CONVERSATIONS_SETTINGS_PROVIDER to package com.sonyericsson.android.socialphonebook (protectionLevel=2 flags=0x8be45)
04-01 18:51:07.083 W/PackageManager( 289): Unknown permission com.google.android.providers.gmail.permission.READ_GMAIL in package com.mobisystems.office
04-01 18:51:07.083 W/PackageManager( 289): Not granting permission android.permission.WRITE_SECURE_SETTINGS to package com.whatsapp (protectionLevel=3 flags=0x20be44)
04-01 18:51:07.083 W/PackageManager( 289): Unknown permission com.sonyericsson.permission.HANDOVER_SERVICE in package com.sonyericsson.infiniteview
04-01 18:51:07.083 W/PackageManager( 289): Unknown permission com.sonyericsson.permission.CONTACTS_PICK_CONVERSATIONS_TARGET in package com.sonyericsson.infiniteview
04-01 18:51:07.083 W/PackageManager( 289): Unknown permission com.sonyericsson.permission.RENREN in package com.sonyericsson.infiniteview
04-01 18:51:07.083 W/PackageManager( 289): Unknown permission com.sonyericsson.permission.USERAGENT in package com.sonyericsson.trackid3.client
04-01 18:51:07.083 W/PackageManager( 289): Unknown permission com.sonyericsson.permission.CUSTOMIZATION in package com.sonyericsson.trackid3.client
04-01 18:51:07.083 W/PackageManager( 289): Unknown permission android.permission.ADD_ACCOUNTS in package com.yahoo.mobile.client.android.im
04-01 18:51:07.083 W/PackageManager( 289): Not granting permission android.permission.WRITE_SECURE_SETTINGS to package com.yahoo.mobile.client.android.im (protectionLevel=3 flags=0xbe44)
04-01 18:51:07.093 W/PackageManager( 289): Not granting permission com.google.android.gm.permission.READ_GMAIL to package com.google.android.apps.uploader (protectionLevel=2 flags=0x8be45)
04-01 18:51:07.093 W/PackageManager( 289): Not granting permission android.permission.INSTALL_PACKAGES to package com.apkinstall (protectionLevel=3 flags=0xbe44)
04-01 18:51:07.093 W/PackageManager( 289): Unknown permission com.sonyericsson.timescape.permission.TIMESCAPE_SETTINGS in package com.sonyericsson.setupwizard
04-01 18:51:07.093 W/PackageManager( 289): Unknown permission com.sonyericsson.shutdownservice.permission.SHUTDOWNSERVICE in package com.sonyericsson.setupwizard
04-01 18:51:07.093 W/PackageManager( 289): Unknown permission com.sonyericsson.permission.CUSTOMIZATION in package com.sonyericsson.setupwizard
04-01 18:51:07.093 W/PackageManager( 289): Unknown permission com.sonyericsson.timescape.permission.TIMESCAPE_SETTINGS in package com.sonyericsson.settings
04-01 18:51:07.093 W/PackageManager( 289): Unknown permission com.sonyericsson.android.permission.SEMC_PLUGIN_ACCESS in package com.sonyericsson.solsplayer
04-01 18:51:07.093 W/PackageManager( 289): Unknown permission android.permission.READ_EXTERNAL_STORAGE in package com.android.vending
04-01 18:51:07.093 W/PackageManager( 289): Not granting permission android.permission.SEND_DOWNLOAD_COMPLETED_INTENTS to package com.android.vending (protectionLevel=2 flags=0xabec5)
04-01 18:51:07.093 W/PackageManager( 289): Not granting permission android.permission.SEND_SMS_NO_CONFIRMATION to package com.android.vending (protectionLevel=3 flags=0xabec5)
04-01 18:51:07.093 W/PackageManager( 289): Not granting permission android.permission.PACKAGE_USAGE_STATS to package com.android.vending (protectionLevel=3 flags=0xabec5)
04-01 18:51:07.103 W/PackageManager( 289): Not granting permission android.permission.PACKAGE_VERIFICATION_AGENT to package com.android.vending (protectionLevel=3 flags=0xabec5)
04-01 18:51:07.103 W/PackageManager( 289): Unknown permission android.permission.MANAGE_USERS in package com.android.vending
04-01 18:51:07.103 W/PackageManager( 289): Unknown permission android.permission.INTERACT_ACROSS_USERS in package com.android.vending
04-01 18:51:07.103 W/PackageManager( 289): Unknown permission com.sonyericsson.permission.PICKER in package com.sonyericsson.sync.ui
04-01 18:51:07.103 W/PackageManager( 289): Unknown permission com.sonyericsson.permission.CUSTOMIZATION in package com.sonyericsson.android.support
04-01 18:51:07.103 W/PackageManager( 289): Unknown permission android.permission.READ_OWNER_DATA in package com.sonyericsson.android.support
04-01 18:51:07.103 W/PackageManager( 289): Unknown permission com.sonyericsson.permission.IDD in package com.sonyericsson.crashmonitor
04-01 18:51:07.103 W/PackageManager( 289): Unknown permission com.sonyericsson.permission.IDD_PRIVATE in package com.sonyericsson.crashmonitor
04-01 18:51:07.103 W/PackageManager( 289): Unknown permission android.Manifest.permission.READ_LOGS in package com.sonyericsson.crashmonitor
04-01 18:51:07.103 W/PackageManager( 289): Unknown permission com.sonyericsson.crashmonitor.permission.CRASHMONITORHELPER in package com.sonyericsson.crashmonitor
04-01 18:51:07.103 W/PackageManager( 289): Not granting permission android.permission.DEVICE_POWER to package com.android.deskclock (protectionLevel=2 flags=0x8be45)
04-01 18:51:07.103 W/PackageManager( 289): Not granting permission android.permission.DEVICE_POWER to package com.android.facelock (protectionLevel=2 flags=0x8be45)
04-01 18:51:07.103 W/PackageManager( 289): Unknown permission andriod.permission.MANAGE_USB in package com.sonyericsson.usbux
04-01 18:51:07.103 W/PackageManager( 289): Not granting permission android.permission.DEVICE_POWER to package com.surpax.ledflashlight.panel (protectionLevel=2 flags=0x8be44)
04-01 18:51:07.103 W/PackageManager( 289): Unknown permission android.permission.READ_EXTERNAL_STORAGE in package com.surpax.ledflashlight.panel
04-01 18:51:07.283 I/ActivityManager( 289): Start proc com.sonyericsson.music for broadcast com.sonyericsson.music/.infinite.PackageChangedReceiver: pid=1735 uid=10002 gids={1015, 3002, 3003}
04-01 18:51:07.513 D/BackupManagerService( 289): Received broadcast Intent { act=android.intent.action.PACKAGE_ADDED dat=package:com.surpax.ledflashlight.panel flg=0x10000010 (has extras) }
04-01 18:51:07.573 I/ActivityManager( 289): Start proc com.svox.pico for broadcast com.svox.pico/.VoiceDataInstallerReceiver: pid=1749 uid=10052 gids={1015}
04-01 18:51:07.603 I/ActivityManager( 289): No longer want com.google.android.apps.maps (pid 1417): hidden #16
04-01 18:51:07.693 V/BackupManagerService( 289): addPackageParticipantsLocked: #1
04-01 18:51:07.723 I/ActivityManager( 289): Start proc com.sonyericsson.eventstream for broadcast com.sonyericsson.eventstream/.EventStreamReceiver: pid=1761 uid=10056 gids={3003}
04-01 18:51:07.723 I/ActivityManager( 289): No longer want com.android.calendar (pid 1312): hidden #16
04-01 18:51:07.913 I/ActivityManager( 289): Start proc com.google.android.apps.maps for broadcast com.google.android.apps.maps/com.google.android.location.internal.NlpPackageUpdateReceiver: pid=1777 uid=10089 gids={3003, 1015}
04-01 18:51:07.963 I/ActivityManager( 289): No longer want com.sonyericsson.gallery (pid 1256): hidden #16
04-01 18:51:08.483 I/ActivityManager( 289): No longer want android.process.acore (pid 1060): hidden #16
04-01 18:51:08.513 I/ActivityManager( 289): Start proc com.sonyericsson.extras.liveware for broadcast com.sonyericsson.extras.liveware/.aef.service.InstallEventReceiver: pid=1795 uid=10094 gids={3002, 3001}
04-01 18:51:08.703 W/ActivityManager( 289): Exception when sending broadcast to ComponentInfo{com.android.providers.contacts/com.android.providers.contacts.PackageIntentReceiver}
04-01 18:51:08.703 W/ActivityManager( 289): android.os.TransactionTooLargeException
04-01 18:51:08.703 W/ActivityManager( 289): at android.os.BinderProxy.transact(Native Method)
04-01 18:51:08.703 W/ActivityManager( 289): at android.app.ApplicationThreadProxy.scheduleReceiver(ApplicationThreadNative.java:727)
04-01 18:51:08.703 W/ActivityManager( 289): at com.android.server.am.ActivityManagerService.processCurBroadcastLocked(ActivityManagerService.java:12845)
04-01 18:51:08.703 W/ActivityManager( 289): at com.android.server.am.ActivityManagerService.processNextBroadcast(ActivityManagerService.java:13244)
04-01 18:51:08.703 W/ActivityManager( 289): at com.android.server.am.ActivityManagerService.finishReceiver(ActivityManagerService.java:12684)
04-01 18:51:08.703 W/ActivityManager( 289): at android.app.ActivityManagerNative.onTransact(ActivityManagerNative.java:336)
04-01 18:51:08.703 W/ActivityManager( 289): at com.android.server.am.ActivityManagerService.onTransact(ActivityManagerService.java:1577)
04-01 18:51:08.703 W/ActivityManager( 289): at android.os.Binder.execTransact(Binder.java:338)
04-01 18:51:08.703 W/ActivityManager( 289): at dalvik.system.NativeStart.run(Native Method)
04-01 18:51:08.743 I/ActivityManager( 289): Start proc android.process.acore for broadcast com.android.providers.contacts/.PackageIntentReceiver: pid=1809 uid=10055 gids={3003, 1015}
04-01 18:51:09.093 I/ActivityManager( 289): No longer want com.sonyericsson.settings (pid 1520): hidden #16
04-01 18:51:12.153 I/ActivityManager( 289): No longer want com.google.android.gsf.login (pid 1495): hidden #16
04-01 18:51:14.333 D/ConnectivityService( 289): ConnectivityChange for mobile: CONNECTED/CONNECTED
04-01 18:51:14.373 D/NetworkPolicy( 289): applying policy NetworkPolicy[NetworkTemplate: matchRule=MOBILE_ALL, subscriberId=valid]: cycleDay=1, warningBytes=2147483648, limitBytes=-1, lastSnooze=-1 to ifaces [rmnet0]
--------- beginning of /dev/log/main
04-01 18:51:17.723 D/R2R ( 1533): [com.sonyericsson.r2r.client.accounts.APNSwitchObserver] woke up.
04-01 18:51:17.723 D/R2R ( 1533): [com.sonyericsson.r2r.client.network.Network] isNetworkUp() : network state: CONNECTED
04-01 18:51:17.723 D/R2R ( 1533): [com.sonyericsson.r2r.client.accounts.APNSwitchObserver] Going to sleep for 1000 ms.
04-01 18:51:18.723 D/R2R ( 1533): [com.sonyericsson.r2r.client.accounts.APNSwitchObserver] woke up.
04-01 18:51:18.723 D/R2R ( 1533): [com.sonyericsson.r2r.client.network.Network] isNetworkUp() : network state: CONNECTED
04-01 18:51:18.723 D/R2R ( 1533): [com.sonyericsson.r2r.client.accounts.APNSwitchObserver] Total wait time for APN switch: 14016, network determined to be up? true
04-01 18:51:18.723 D/R2R ( 1533): [com.sonyericsson.r2r.client.main.R2RService] Accounts set, setting preference accounts-set to true
04-01 18:51:18.743 D/R2R ( 1533): [com.sonyericsson.r2r.client.notifications.NotificationHandler] Broadcasting R2R done intent (action: 'com.sonyericsson.r2r.client.intent.action.ACTION_R2R_DONE') with result code: 'r2r-success'
04-01 18:51:18.753 D/R2R ( 1533): [com.sonyericsson.r2r.client.main.R2RService] Settings successfully downloaded.
04-01 18:51:18.753 D/R2R ( 1533): [com.sonyericsson.r2r.client.main.R2RService] postEvent() event: EVENT_STOP_SERVICE
04-01 18:51:18.753 D/R2R ( 1533): [com.sonyericsson.r2r.client.main.R2RService] handleEvent() event:[EVENT_STOP_SERVICE] in state:[STATE_IDLE]
04-01 18:51:18.753 D/R2R ( 1533): [com.sonyericsson.r2r.client.main.R2RService] StopService(), startId: 1
04-01 18:51:18.763 I/ActivityManager( 289): Start proc com.sonyericsson.setupwizard for broadcast com.sonyericsson.setupwizard/.components.ReadyToRunReceiver: pid=1846 uid=1000 gids={1015, 3002, 3001, 3003, 3007}
04-01 18:51:18.773 I/ActivityManager( 289): No longer want com.google.android.voicesearch (pid 1713): hidden #16
04-01 18:51:18.783 D/R2R ( 1533): [com.sonyericsson.r2r.client.main.R2RService] R2R service is stopped: true
04-01 18:51:18.873 D/ReadyToRunReceiver( 1846): onReceive
04-01 18:51:18.883 D/dalvikvm( 136): GC_EXPLICIT freed 37K, 4% free 8809K/9091K, paused 2ms+11ms
04-01 18:51:18.913 D/dalvikvm( 366): GC_CONCURRENT freed 446K, 28% free 10205K/14087K, paused 2ms+3ms
04-01 18:51:18.913 D/ReadyToRunReceiver( 1846): result: r2r-success
04-01 18:51:18.913 I/ActivityManager( 289): No longer want com.sonyericsson.music (pid 1735): hidden #16
04-01 18:51:18.953 D/dalvikvm( 136): GC_EXPLICIT freed <1K, 4% free 8809K/9091K, paused 2ms+2ms
04-01 18:51:19.013 D/dalvikvm( 136): GC_EXPLICIT freed <1K, 4% free 8809K/9091K, paused 4ms+2ms
04-01 18:51:19.013 D/dalvikvm( 366): GC_CONCURRENT freed 408K, 28% free 10229K/14087K, paused 2ms+3ms
04-01 18:51:19.123 D/dalvikvm( 366): GC_CONCURRENT freed 507K, 28% free 10218K/14087K, paused 2ms+4ms
04-01 18:51:21.303 D/dalvikvm( 1003): GC_CONCURRENT freed 384K, 5% free 9135K/9607K, paused 2ms+4ms
04-01 18:51:22.483 I/AudioHardwareMSM7X30( 152): Routing audio to Speakerphone
04-01 18:51:22.483 I/AudioHardwareMSM7X30( 152): Change routing audio to speaker for xLOUD
04-01 18:51:22.493 I/ActivityManager( 289): START {act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10000000 pkg=com.surpax.ledflashlight.panel cmp=com.surpax.ledflashlight.panel/com.surpax.ledflashlight.FlashlightActivity bnds=[96,216][480,312]} from pid -1
04-01 18:51:22.503 D/AudioHardwareMSM7X30( 152): value of device and enable is 32 1
04-01 18:51:22.513 D/kernel ( 144): [ 123.937988] [msm7x30.c:msm_device_put] device xloud_speaker_stereo_rx set 1
04-01 18:51:22.513 D/kernel ( 144): [ 123.938018] [msm7x30.c:msm_device_put] device freq =48000
04-01 18:51:22.513 D/kernel ( 144): [ 123.941284] [adsp.c:msm_adsp_get] module AFETASK has been registered
04-01 18:51:22.513 D/kernel ( 144): [ 123.941314] [adsp.c:msm_adsp_enable] enable 'AFETASK'state[0] id[17227119]
04-01 18:51:22.523 D/kernel ( 144): [ 123.946258] [adsp.c:adsp_rtos_mtoa_cb] rpc event=0, proc_id=2, module=17227119, image=0
04-01 18:51:22.523 D/kernel ( 144): [ 123.946258] [adsp.c:adsp_rtos_mtoa_cb] module AFETASK: READY
04-01 18:51:22.583 D/kernel ( 144): [ 124.003936] msm_snddev_poweramp_on: power on amplifier
04-01 18:51:22.583 D/kernel ( 144): [ 124.004028] [adsp.c:msm_adsp_get] module AUDPPTASK has been registered
04-01 18:51:22.583 D/kernel ( 144): [ 124.004028] [adsp.c:msm_adsp_enable] enable 'AUDPPTASK'state[0] id[17227122]
04-01 18:51:22.583 D/kernel ( 144): [ 124.008514] [adsp.c:adsp_rtos_mtoa_cb] rpc event=0, proc_id=2, module=17227122, image=0
04-01 18:51:22.583 D/kernel ( 144): [ 124.008544] [adsp.c:adsp_rtos_mtoa_cb] module AUDPPTASK: READY
04-01 18:51:22.583 D/kernel ( 144): [ 124.012695] [audpp.c:audpp_dsp_event] ENABLE
04-01 18:51:22.583 W/KeyguardViewMediator( 289): verifyUnlock called when not externally disabled
04-01 18:51:22.593 D/kernel ( 144): [ 124.017059] [adsp.c:msm_adsp_write] AUDPPTASK command took 65 attempts: rc 0
04-01 18:51:22.613 I/ActivityManager( 289): Start proc com.surpax.ledflashlight.panel for activity com.surpax.ledflashlight.panel/com.surpax.ledflashlight.FlashlightActivity: pid=1862 uid=10136 gids={1006, 3003, 1015}
04-01 18:51:22.643 I/dalvikvm( 1862): Turning on JNI app bug workarounds for target SDK version 4...
04-01 18:51:22.793 D/dalvikvm( 366): GC_CONCURRENT freed 600K, 29% free 10093K/14087K, paused 1ms+13ms
04-01 18:51:22.873 D/SurfaceFlinger( 135): Release buffer at 0x78b30
04-01 18:51:22.933 D/FlurryAgent( 1862): Initializing Flurry session
04-01 18:51:22.943 D/FlurryAgent( 1862): New session
04-01 18:51:22.943 W/Settings( 1862): Setting android_id has moved from android.provider.Settings.System to android.provider.Settings.Secure, returning read-only value.
04-01 18:51:22.943 D/SurfaceFlinger( 135): Release buffer at 0x70148
04-01 18:51:22.953 I/FlurryAgent( 1862): Agent cache file doesn't exist.
04-01 18:51:22.983 I/FlurryAgent( 1862): Fetching IMEI: [B@2be4f480
04-01 18:51:22.983 D/FlurryAgent( 1862): generating report
04-01 18:51:22.983 I/FlurryAgent( 1862): Sent IMEI: [118, 33, 32, -76, 115, 63, 16, -37, 33, -116, -49, -44, -33, -99, 77, 62, -49, -118, -68, 98]
04-01 18:51:22.983 D/FlurryAgent( 1862): Sending report to: http://data.flurry.com/aap.do
04-01 18:51:23.013 D/dalvikvm( 1862): GC_CONCURRENT freed 358K, 5% free 8956K/9351K, paused 2ms+5ms
04-01 18:51:23.093 W/System.err( 1862): java.io.FileNotFoundException: /data/data/com.surpax.ledflashlight.panel/files/HSRemoteConfig.plist: open failed: ENOENT (No such file or directory)
04-01 18:51:23.093 W/System.err( 1862): at libcore.io.IoBridge.open(IoBridge.java:419)
04-01 18:51:23.093 W/System.err( 1862): at java.io.FileInputStream.
04-01 18:51:23.093 W/System.err( 1862): at android.app.ContextImpl.openFileInput(ContextImpl.java:610)
04-01 18:51:23.093 W/System.err( 1862): at android.content.ContextWrapper.openFileInput(ContextWrapper.java:159)
04-01 18:51:23.093 W/System.err( 1862): at com.ihs.f.d.b(Unknown Source)
04-01 18:51:23.093 W/System.err( 1862): at com.ihs.e.a.c.a(Unknown Source)
04-01 18:51:23.093 W/System.err( 1862): at com.ihs.b.a.a.d(Unknown Source)
04-01 18:51:23.093 W/System.err( 1862): at com.ihs.apps.framework.sub.a.d(Unknown Source)
04-01 18:51:23.093 W/System.err( 1862): at com.ihs.b.a.a.update(Unknown Source)
04-01 18:51:23.093 W/System.err( 1862): at java.util.Observable.notifyObservers(Observable.java:138)
04-01 18:51:23.093 W/System.err( 1862): at com.ihs.session.a.b(Unknown Source)
04-01 18:51:23.093 W/System.err( 1862): at com.ihs.session.a.addObserver(Unknown Source)
04-01 18:51:23.093 W/System.err( 1862): at com.surpax.ledflashlight.FlashlightActivity.onCreate(Unknown Source)
04-01 18:51:23.093 W/System.err( 1862): at android.app.Activity.performCreate(Activity.java:4465)
04-01 18:51:23.093 W/System.err( 1862): at android.app.Instrumentation.callActivityOnCreate(Instrumentation.java:1049)
04-01 18:51:23.093 W/System.err( 1862): at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:1931)
04-01 18:51:23.103 W/System.err( 1862): at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:1992)
04-01 18:51:23.103 W/System.err( 1862): at android.app.ActivityThread.access$600(ActivityThread.java:127)
04-01 18:51:23.113 W/System.err( 1862): at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1158)
04-01 18:51:23.113 W/System.err( 1862): at android.os.Handler.dispatchMessage(Handler.java:99)
04-01 18:51:23.113 W/System.err( 1862): at android.os.Looper.loop(Looper.java:137)
04-01 18:51:23.113 W/System.err( 1862): at android.app.ActivityThread.main(ActivityThread.java:4441)
04-01 18:51:23.113 W/System.err( 1862): at java.lang.reflect.Method.invokeNative(Native Method)
04-01 18:51:23.113 W/System.err( 1862): at java.lang.reflect.Method.invoke(Method.java:511)
04-01 18:51:23.113 W/System.err( 1862): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:784)
04-01 18:51:23.113 W/System.err( 1862): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:551)
04-01 18:51:23.113 W/System.err( 1862): at dalvik.system.NativeStart.main(Native Method)
04-01 18:51:23.113 W/System.err( 1862): Caused by: libcore.io.ErrnoException: open failed: ENOENT (No such file or directory)
04-01 18:51:23.113 W/System.err( 1862): at libcore.io.Posix.open(Native Method)
04-01 18:51:23.113 W/System.err( 1862): at libcore.io.BlockGuardOs.open(BlockGuardOs.java:110)
04-01 18:51:23.113 W/System.err( 1862): at libcore.io.IoBridge.open(IoBridge.java:403)
04-01 18:51:23.113 W/System.err( 1862): ... 26 more
04-01 18:51:23.133 D/FlurryAgent( 1862): Event count incremented: App_Opened
04-01 18:51:23.133 D/FlurryAgent( 1862): Logged event: App_Opened
04-01 18:51:23.133 I/TapjoyLog( 1862): enableLogging: true
04-01 18:51:23.133 I/TapjoyConnect( 1862): deviceID: 358343044968628
04-01 18:51:23.133 I/TapjoyConnect( 1862): ANDROID SDK VERSION: 15
04-01 18:51:23.133 I/TapjoyConnect( 1862): Metadata successfully loaded
04-01 18:51:23.133 I/TapjoyConnect( 1862): APP_ID = [ef0eb7cf-3a72-419f-9b59-bcfbbad427dc]
04-01 18:51:23.133 I/TapjoyConnect( 1862): ANDROID_ID: [741c9889fa4bb846]
04-01 18:51:23.133 I/TapjoyConnect( 1862): CLIENT_PACKAGE = [com.surpax.ledflashlight.panel]
04-01 18:51:23.133 I/TapjoyConnect( 1862): deviceID: [358343044968628]
04-01 18:51:23.133 I/TapjoyConnect( 1862): deviceName: [ST18i]
04-01 18:51:23.133 I/TapjoyConnect( 1862): deviceManufacturer: [Sony Ericsson]
04-01 18:51:23.133 I/TapjoyConnect( 1862): deviceType: [android]
04-01 18:51:23.133 I/TapjoyConnect( 1862): libraryVersion: [8.1.2]
04-01 18:51:23.133 I/TapjoyConnect( 1862): deviceOSVersion: [4.0.4]
04-01 18:51:23.133 I/TapjoyConnect( 1862): COUNTRY_CODE: [IN]
04-01 18:51:23.133 I/TapjoyConnect( 1862): LANGUAGE_CODE: [en]
04-01 18:51:23.133 I/TapjoyConnect( 1862): density: [240]
04-01 18:51:23.133 I/TapjoyConnect( 1862): screen_layout: [2]
04-01 18:51:23.133 I/TapjoyConnect( 1862): carrier_name: [IDEA]
04-01 18:51:23.133 I/TapjoyConnect( 1862): carrier_country_code: [in]
04-01 18:51:23.133 I/TapjoyConnect( 1862): mobile_country_code: [40424]
04-01 18:51:23.133 I/TapjoyConnect( 1862): referralURL: []
04-01 18:51:23.143 I/TapjoyConnect( 1862): connectivity: 0
04-01 18:51:23.143 I/TapjoyConnect( 1862): connection_type: mobile
04-01 18:51:23.143 I/TapjoyUtil( 1862): SHA256: ef0eb7cf-3a72-419f-9b59-bcfbbad427dc:358343044968628:1364822483:V2oURbIVB5j1Nv9R3l94
04-01 18:51:23.143 I/TapjoyConnect( 1862): URL parameters: app_id=ef0eb7cf-3a72-419f-9b59-bcfbbad427dc&android_id=741c9889fa4bb846&udid=358343044968628&device_name=ST18i&device_manufacturer=Sony%20Ericsson&device_type=android&os_version=4.0.4&country_code=IN&language_code=en&app_version=1.0.2&library_version=8.1.2&platform=android&display_multiplier=1.0&carrier_name=IDEA&carrier_country_code=in&mobile_country_code=40424&screen_density=240&screen_layout_size=2&connection_type=mobile×tamp=1364822483&verifier=60ddbe5ad7fe18280a4e9f17cced24e39b812dff9ff1db885d81ecc60c3788b4
04-01 18:51:23.153 I/TapjoyConnect( 1862): starting connect call...
04-01 18:51:23.173 I/TapjoyConnect( 1862): connectivity: 0
04-01 18:51:23.173 I/TapjoyConnect( 1862): connection_type: mobile
04-01 18:51:23.173 I/TapjoyUtil( 1862): SHA256: ef0eb7cf-3a72-419f-9b59-bcfbbad427dc:358343044968628:1364822483:V2oURbIVB5j1Nv9R3l94
04-01 18:51:23.173 I/TapjoyURLConnection( 1862): baseURL: https://ws.tapjoyads.com/connect?
04-01 18:51:23.173 I/TapjoyURLConnection( 1862): requestURL: https://ws.tapjoyads.com/connect?app_id=ef0eb7cf-3a72-419f-9b59-bcfbbad427dc&android_id=741c9889fa4b...
04-01 18:51:23.203 D/Surpax App( 1862): soundManager constructor
04-01 18:51:23.203 D/flashlightactivity( 1862): load sound resource now.....
04-01 18:51:23.203 E/CMarlinMediator( 137): Error : MarlinMediator Failed to get TrustedTime
04-01 18:51:23.243 D/dalvikvm( 1862): GC_CONCURRENT freed 367K, 5% free 9139K/9543K, paused 4ms+3ms
04-01 18:51:23.253 D/Surpax App( 1862): screen height is:854, width is:480
04-01 18:51:23.283 E/CMarlinMediator( 137): Error : MarlinMediator Failed to get TrustedTime
04-01 18:51:23.283 D/dalvikvm( 1862): GC_FOR_ALLOC freed 20K, 5% free 9128K/9543K, paused 17ms
04-01 18:51:23.293 I/dalvikvm-heap( 1862): Grow heap (frag case) to 10.513MB for 1639696-byte allocation
04-01 18:51:23.343 E/CMarlinMediator( 137): Error : MarlinMediator Failed to get TrustedTime
04-01 18:51:23.353 D/dalvikvm( 1862): GC_FOR_ALLOC freed <1K, 5% free 10729K/11207K, paused 29ms
04-01 18:51:23.403 D/FlashLightActivity_Test( 1862): background bmps's width is:480, height is:854
04-01 18:51:23.433 I/ActivityManager( 289): Start proc com.google.android.gsf.login for service com.google.android.gsf.login/com.google.android.gsf.loginservice.GoogleLoginService: pid=1926 uid=10066 gids={3003, 1015, 1007, 2001, 3006}
04-01 18:51:23.473 D/dalvikvm( 1862): GC_CONCURRENT freed 3K, 4% free 10919K/11271K, paused 2ms+2ms
04-01 18:51:23.523 D/dalvikvm( 1862): GC_FOR_ALLOC freed 3K, 4% free 11070K/11463K, paused 27ms
04-01 18:51:23.523 I/dalvikvm-heap( 1862): Grow heap (frag case) to 11.768MB for 966416-byte allocation
04-01 18:51:23.603 I/ActivityManager( 289): No longer want com.svox.pico (pid 1749): hidden #16
04-01 18:51:23.613 D/dalvikvm( 1862): GC_CONCURRENT freed 1K, 4% free 12013K/12423K, paused 2ms+3ms
04-01 18:51:23.613 D/flashlight manager( 1862): system sdk version is:15
04-01 18:51:23.613 D/flashlight manager( 1862): mobile manufacture is:Sony Ericsson
04-01 18:51:23.613 D/flashlight manager( 1862): mobile brand is:SEMC
04-01 18:51:23.613 D/flashlight manager( 1862): mobile model is:ST18i
04-01 18:51:23.613 D/flashlight manager( 1862): loadDevice index is 0
04-01 18:51:23.633 W/System.err( 1862): java.lang.NullPointerException
04-01 18:51:23.633 W/System.err( 1862): at com.ihs.c.a.h.f(Unknown Source)
04-01 18:51:23.633 W/System.err( 1862): at com.ihs.c.a.h.a(Unknown Source)
04-01 18:51:23.633 W/System.err( 1862): at com.ihs.c.a.d.b(Unknown Source)
04-01 18:51:23.633 W/System.err( 1862): at com.surpax.b.a.c.a(Unknown Source)
04-01 18:51:23.633 W/System.err( 1862): at com.surpax.ledflashlight.FlashlightActivity.onStart(Unknown Source)
04-01 18:51:23.633 W/System.err( 1862): at android.app.Instrumentation.callActivityOnStart(Instrumentation.java:1133)
04-01 18:51:23.633 W/System.err( 1862): at android.app.Activity.performStart(Activity.java:4475)
04-01 18:51:23.633 W/System.err( 1862): at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:1940)
04-01 18:51:23.633 W/System.err( 1862): at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:1992)
04-01 18:51:23.633 W/System.err( 1862): at android.app.ActivityThread.access$600(ActivityThread.java:127)
04-01 18:51:23.633 W/System.err( 1862): at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1158)
04-01 18:51:23.633 W/System.err( 1862): at android.os.Handler.dispatchMessage(Handler.java:99)
04-01 18:51:23.633 W/System.err( 1862): at android.os.Looper.loop(Looper.java:137)
04-01 18:51:23.633 W/System.err( 1862): at android.app.ActivityThread.main(ActivityThread.java:4441)
04-01 18:51:23.633 W/System.err( 1862): at java.lang.reflect.Method.invokeNative(Native Method)
04-01 18:51:23.633 W/System.err( 1862): at java.lang.reflect.Method.invoke(Method.java:511)
04-01 18:51:23.633 W/System.err( 1862): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:784)
04-01 18:51:23.633 W/System.err( 1862): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:551)
04-01 18:51:23.633 W/System.err( 1862): at dalvik.system.NativeStart.main(Native Method)
04-01 18:51:23.633 D/flashlight manager( 1862): try to use flash_mode_on mark
04-01 18:51:23.643 D/AndroidRuntime( 1862): Shutting down VM
04-01 18:51:23.643 W/dalvikvm( 1862): threadid=1: thread exiting with uncaught exception (group=0x2b542210)
04-01 18:51:23.643 W/System.err( 1862): java.lang.RuntimeException: Unable to start activity ComponentInfo{com.surpax.ledflashlight.panel/com.surpax.ledflashlight.FlashlightActivity}: java.lang.NullPointerException
04-01 18:51:23.643 W/System.err( 1862): at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:1967)
04-01 18:51:23.643 W/System.err( 1862): at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:1992)
04-01 18:51:23.643 W/System.err( 1862): at android.app.ActivityThread.access$600(ActivityThread.java:127)
04-01 18:51:23.643 W/System.err( 1862): at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1158)
04-01 18:51:23.643 W/System.err( 1862): at android.os.Handler.dispatchMessage(Handler.java:99)
04-01 18:51:23.643 W/System.err( 1862): at android.os.Looper.loop(Looper.java:137)
04-01 18:51:23.643 W/System.err( 1862): at android.app.ActivityThread.main(ActivityThread.java:4441)
04-01 18:51:23.643 W/System.err( 1862): at java.lang.reflect.Method.invokeNative(Native Method)
04-01 18:51:23.643 W/System.err( 1862): at java.lang.reflect.Method.invoke(Method.java:511)
04-01 18:51:23.643 W/System.err( 1862): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:784)
04-01 18:51:23.643 W/System.err( 1862): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:551)
04-01 18:51:23.643 W/System.err( 1862): at dalvik.system.NativeStart.main(Native Method)
04-01 18:51:23.643 W/System.err( 1862): Caused by: java.lang.NullPointerException
04-01 18:51:23.643 W/System.err( 1862): at com.ihs.c.a.f.f(Unknown Source)
04-01 18:51:23.643 W/System.err( 1862): at com.ihs.c.a.f.a(Unknown Source)
04-01 18:51:23.643 W/System.err( 1862): at com.ihs.c.a.d.b(Unknown Source)
04-01 18:51:23.643 W/System.err( 1862): at com.surpax.b.a.c.a(Unknown Source)
04-01 18:51:23.643 W/System.err( 1862): at com.surpax.ledflashlight.FlashlightActivity.onStart(Unknown Source)
04-01 18:51:23.643 W/System.err( 1862): at android.app.Instrumentation.callActivityOnStart(Instrumentation.java:1133)
04-01 18:51:23.643 W/System.err( 1862): at android.app.Activity.performStart(Activity.java:4475)
04-01 18:51:23.643 W/System.err( 1862): at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:1940)
04-01 18:51:23.643 W/System.err( 1862): ... 11 more
04-01 18:51:23.643 D/FlurryAgent( 1862): Error logged: uncaught
04-01 18:51:23.643 D/FlurryAgent( 1862): Ending session
04-01 18:51:23.643 E/AndroidRuntime( 1862): FATAL EXCEPTION: main
04-01 18:51:23.643 E/AndroidRuntime( 1862): java.lang.RuntimeException: Unable to start activity ComponentInfo{com.surpax.ledflashlight.panel/com.surpax.ledflashlight.FlashlightActivity}: java.lang.NullPointerException
04-01 18:51:23.643 E/AndroidRuntime( 1862): at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:1967)
04-01 18:51:23.643 E/AndroidRuntime( 1862): at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:1992)
04-01 18:51:23.643 E/AndroidRuntime( 1862): at android.app.ActivityThread.access$600(ActivityThread.java:127)
04-01 18:51:23.643 E/AndroidRuntime( 1862): at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1158)
04-01 18:51:23.643 E/AndroidRuntime( 1862): at android.os.Handler.dispatchMessage(Handler.java:99)
04-01 18:51:23.643 E/AndroidRuntime( 1862): at android.os.Looper.loop(Looper.java:137)
04-01 18:51:23.643 E/AndroidRuntime( 1862): at android.app.ActivityThread.main(ActivityThread.java:4441)
04-01 18:51:23.643 E/AndroidRuntime( 1862): at java.lang.reflect.Method.invokeNative(Native Method)
04-01 18:51:23.643 E/AndroidRuntime( 1862): at java.lang.reflect.Method.invoke(Method.java:511)
04-01 18:51:23.643 E/AndroidRuntime( 1862): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:784)
04-01 18:51:23.643 E/AndroidRuntime( 1862): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:551)
04-01 18:51:23.643 E/AndroidRuntime( 1862): at dalvik.system.NativeStart.main(Native Method)
04-01 18:51:23.643 E/AndroidRuntime( 1862): Caused by: java.lang.NullPointerException
04-01 18:51:23.643 E/AndroidRuntime( 1862): at com.ihs.c.a.f.f(Unknown Source)
04-01 18:51:23.643 E/AndroidRuntime( 1862): at com.ihs.c.a.f.a(Unknown Source)
04-01 18:51:23.643 E/AndroidRuntime( 1862): at com.ihs.c.a.d.b(Unknown Source)
04-01 18:51:23.643 E/AndroidRuntime( 1862): at com.surpax.b.a.c.a(Unknown Source)
04-01 18:51:23.643 E/AndroidRuntime( 1862): at com.surpax.ledflashlight.FlashlightActivity.onStart(Unknown Source)
04-01 18:51:23.643 E/AndroidRuntime( 1862): at android.app.Instrumentation.callActivityOnStart(Instrumentation.java:1133)
04-01 18:51:23.643 E/AndroidRuntime( 1862): at android.app.Activity.performStart(Activity.java:4475)
04-01 18:51:23.643 E/AndroidRuntime( 1862): at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:1940)
04-01 18:51:23.643 E/AndroidRuntime( 1862): ... 11 more
04-01 18:51:23.653 W/ActivityManager( 289): Force finishing activity com.surpax.ledflashlight.panel/com.surpax.ledflashlight.FlashlightActivity
04-01 18:51:23.663 W/ActivityManager( 289): Force finishing activity com.android.settings/.Settings
04-01 18:51:23.673 D/dalvikvm( 1139): GC_CONCURRENT freed 833K, 9% free 9442K/10375K, paused 2ms+3ms
04-01 18:51:23.783 D/dalvikvm( 498): GC_CONCURRENT freed 606K, 7% free 9503K/10183K, paused 2ms+4ms
04-01 18:51:23.833 I/ActivityManager( 289): No longer want com.android.settings (pid 1483): hidden #16
04-01 18:51:23.843 I/WindowManager( 289): WIN DEATH: Window{2c142990 com.android.settings/com.android.settings.Settings paused=true}
04-01 18:51:24.173 W/ActivityManager( 289): Activity pause timeout for ActivityRecord{2c1ea0a0 com.surpax.ledflashlight.panel/com.surpax.ledflashlight.FlashlightActivity}
04-01 18:51:24.193 D/FlurryAgent( 1862): Report successful
04-01 18:51:24.193 D/FlurryAgent( 1862): Processing report response
04-01 18:51:24.193 D/FlurryAgent( 1862): Done sending agent report
04-01 18:51:24.303 W/System.err( 1862): java.io.FileNotFoundException: /data/data/com.surpax.ledflashlight.panel/files/HSMessageAlerts.plist: open failed: ENOENT (No such file or directory)
04-01 18:51:24.313 W/System.err( 1862): at libcore.io.IoBridge.open(IoBridge.java:419)
04-01 18:51:24.313 W/System.err( 1862): at java.io.FileInputStream.
04-01 18:51:24.313 W/System.err( 1862): at android.app.ContextImpl.openFileInput(ContextImpl.java:610)
04-01 18:51:24.313 W/System.err( 1862): at android.content.ContextWrapper.openFileInput(ContextWrapper.java:159)
04-01 18:51:24.313 W/System.err( 1862): at com.ihs.f.d.b(Unknown Source)
04-01 18:51:24.313 W/System.err( 1862): at com.ihs.alerts.f.a(Unknown Source)
04-01 18:51:24.313 W/System.err( 1862): at com.ihs.alerts.a.a(Unknown Source)
04-01 18:51:24.313 W/System.err( 1862): at com.ihs.e.a.a.a(Unknown Source)
04-01 18:51:24.313 W/System.err( 1862): at com.ihs.e.a.h.run(Unknown Source)
04-01 18:51:24.313 W/System.err( 1862): Caused by: libcore.io.ErrnoException: open failed: ENOENT (No such file or directory)
04-01 18:51:24.313 W/System.err( 1862): at libcore.io.Posix.open(Native Method)
04-01 18:51:24.313 W/System.err( 1862): at libcore.io.BlockGuardOs.open(BlockGuardOs.java:110)
04-01 18:51:24.313 W/System.err( 1862): at libcore.io.IoBridge.open(IoBridge.java:403)
04-01 18:51:24.313 W/System.err( 1862): ... 9 more
04-01 18:51:24.313 W/System.err( 1862): java.io.FileNotFoundException: HSMessageAlerts.plist
04-01 18:51:24.313 W/System.err( 1862): at android.content.res.AssetManager.openAsset(Native Method)
04-01 18:51:24.313 W/System.err( 1862): at android.content.res.AssetManager.open(AssetManager.java:315)
04-01 18:51:24.313 W/System.err( 1862): at android.content.res.AssetManager.open(AssetManager.java:289)
04-01 18:51:24.413 I/ActivityManager( 289): No longer want com.sonyericsson.eventstream (pid 1761): hidden #16
04-01 18:51:24.493 D/dalvikvm( 1139): GC_CONCURRENT freed 104K, 7% free 9741K/10375K, paused 3ms+3ms
04-01 18:51:24.513 I/GTalkService/c( 498): [AndroidEndpoint@736526096] connect: acct=1000001, state=CONNECTING
04-01 18:51:24.513 I/GTalkService/c( 498): [GTalkConnection@736422024] connect: acct=1, state=CONNECTING
04-01 18:51:24.813 D/dalvikvm( 1139): GC_CONCURRENT freed 260K, 5% free 9918K/10375K, paused 2ms+3ms
04-01 18:51:25.013 V/kernel ( 144): [ 126.433044] rmnet0: no IPv6 routers present
04-01 18:51:25.103 D/dalvikvm( 1862): GC_CONCURRENT freed 646K, 6% free 12396K/13127K, paused 2ms+3ms
04-01 18:51:25.603 D/AudioHardwareMSM7X30( 152): AudioStreamOutMSM72xx::standby()
04-01 18:51:25.603 D/AudioHardwareMSM7X30( 152): updateDeviceInfo: E rx_device 32 and tx_device 13
04-01 18:51:25.603 D/AudioHardwareMSM7X30( 152): No active voicecall/playback, disabling cur_rx 32
04-01 18:51:25.603 D/AudioHardwareMSM7X30( 152): value of device and enable is 32 0
04-01 18:51:25.613 D/kernel ( 144): [ 127.042236] [msm7x30.c:msm_device_put] device xloud_speaker_stereo_rx set 0
04-01 18:51:25.613 D/AudioHardwareMSM7X30( 152): No active voicecall/recording, disabling cur_tx 13
04-01 18:51:25.613 D/AudioHardwareMSM7X30( 152): value of device and enable is 13 0
04-01 18:51:25.613 D/AudioHardwareMSM7X30( 152): updateDeviceInfo: X cur_rx 32 cur_tx 13
04-01 18:51:25.623 D/kernel ( 144): [ 127.043518] msm_snddev_poweramp_off: power off amplifier
04-01 18:51:25.623 D/kernel ( 144): [ 127.046447] [adsp.c:msm_adsp_put] closing module AFETASK
04-01 18:51:25.623 D/kernel ( 144): [ 127.046905] [msm7x30.c:msm_device_put] device speaker_mono_tx set 0
04-01 18:51:25.623 D/kernel ( 144): [ 127.047088] [audpp.c:audpp_dsp_event] DISABLE
04-01 18:51:25.623 D/kernel ( 144): [ 127.047149] [audpp.c:audpp_disable] Received CFG_MSG_DISABLE from ADSP
04-01 18:51:25.623 D/kernel ( 144): [ 127.047210] [adsp.c:msm_adsp_disable] disable interrupt
04-01 18:51:25.623 D/kernel ( 144): [ 127.047241] [adsp.c:msm_adsp_put] closing module AUDPPTASK
04-01 18:51:25.743 I/Process ( 1862): Sending signal. PID: 1862 SIG: 9
04-01 18:51:25.753 D/dalvikvm( 1139): GC_CONCURRENT freed 883K, 9% free 9512K/10439K, paused 2ms+4ms
04-01 18:51:25.763 I/AudioHardwareMSM7X30( 152): Routing audio to Speakerphone
04-01 18:51:25.763 I/AudioHardwareMSM7X30( 152): Change routing audio to speaker for xLOUD
04-01 18:51:25.763 I/ActivityManager( 289): Process com.surpax.ledflashlight.panel (pid 1862) has died.
04-01 18:51:25.783 W/InputManagerService( 289): Got RemoteException sending setActive(false) notification to pid 1483 uid 1000
04-01 18:51:25.793 D/AudioHardwareMSM7X30( 152): value of device and enable is 32 1
04-01 18:51:25.803 D/kernel ( 144): [ 127.225311] [msm7x30.c:msm_device_put] device xloud_speaker_stereo_rx set 1
04-01 18:51:25.803 D/kernel ( 144): [ 127.225311] [msm7x30.c:msm_device_put] device freq =48000
04-01 18:51:25.803 D/kernel ( 144): [ 127.229309] [adsp.c:msm_adsp_get] module AFETASK has been registered
04-01 18:51:25.803 D/kernel ( 144): [ 127.229339] [adsp.c:msm_adsp_enable] enable 'AFETASK'state[0] id[17227119]
04-01 18:51:25.813 D/kernel ( 144): [ 127.235626] [adsp.c:adsp_rtos_mtoa_cb] rpc event=0, proc_id=2, module=17227119, image=0
04-01 18:51:25.813 D/kernel ( 144): [ 127.235656] [adsp.c:adsp_rtos_mtoa_cb] module AFETASK: READY
04-01 18:51:25.873 D/kernel ( 144): [ 127.294006] msm_snddev_poweramp_on: power on amplifier
04-01 18:51:25.873 D/kernel ( 144): [ 127.294067] [adsp.c:msm_adsp_get] module AUDPPTASK has been registered
04-01 18:51:25.873 D/kernel ( 144): [ 127.294097] [adsp.c:msm_adsp_enable] enable 'AUDPPTASK'state[0] id[17227122]
04-01 18:51:25.873 D/kernel ( 144): [ 127.295257] [adsp.c:adsp_rtos_mtoa_cb] rpc event=0, proc_id=2, module=17227122, image=0
04-01 18:51:25.873 D/kernel ( 144): [ 127.295288] [adsp.c:adsp_rtos_mtoa_cb] module AUDPPTASK: READY
04-01 18:51:25.873 D/kernel ( 144): [ 127.299407] [audpp.c:audpp_dsp_event] ENABLE
04-01 18:51:25.883 D/kernel ( 144): [ 127.304901] [adsp.c:msm_adsp_write] AUDPPTASK command took 59 attempts: rc 0
04-01 18:51:26.033 D/SurfaceFlinger( 135): Release buffer at 0x78b30
04-01 18:51:26.403 D/dalvikvm( 498): GC_CONCURRENT freed 435K, 8% free 9457K/10183K, paused 3ms+4ms
04-01 18:51:26.743 D/Finsky ( 1139): [1] 5.onFinished: Installation state replication succeeded.
04-01 18:51:27.233 D/dalvikvm( 556): GC_CONCURRENT freed 1432K, 12% free 17923K/20295K, paused 2ms+6ms
04-01 18:51:27.283 D/ConnectivityService( 289): handleInetConditionHoldEnd: net=0, condition=100, published condition=0
04-01 18:51:27.543 D/dalvikvm( 498): GC_EXPLICIT freed 92K, 8% free 9427K/10183K, paused 10ms+82ms
04-01 18:51:27.643 D/dalvikvm( 556): GC_FOR_ALLOC freed 3305K, 22% free 15980K/20295K, paused 31ms
04-01 18:51:27.783 I/ActivityManager( 289): Start proc com.google.android.talk for broadcast com.google.android.talk/.ConnectionStateOnlineReceiver: pid=1949 uid=10000 gids={3003, 1015, 1006, 3002}
04-01 18:51:27.953 I/ActivityThread( 1949): Pub com.google.android.talk.SuggestionProvider: com.google.android.talk.SuggestionsProvider
04-01 18:51:27.993 D/CustomizationProvider( 467): openFile -- START uri=content://com.sonyericsson.provider.customization/settings/com.android.providers.contacts
04-01 18:51:27.993 I/CustomizationProvider( 467): No configuration file: /system/etc/customization/settings/com/android/providers/contacts/custom_settings.xml
04-01 18:51:28.003 W/SemcSettingsParser( 1809): No customization file exists.
04-01 18:51:28.003 E/SemcSettingsParser( 1809): key not found. key=[brand]
04-01 18:51:28.003 E/SemcSettingsParser( 1809): key not found. key=[group-visible]
04-01 18:51:28.063 D/dalvikvm( 1949): GC_CONCURRENT freed 118K, 3% free 9154K/9351K, paused 3ms+3ms
04-01 18:51:28.063 D/vclib:CallStateClient( 1949): startListening
04-01 18:51:28.313 E/SemcSettingsParser( 1809): key not found. key=[brand]
04-01 18:51:28.313 E/SemcSettingsParser( 1809): key not found. key=[group-visible]
04-01 18:51:28.473 E/SemcSettingsParser( 1809): key not found. key=[brand]
04-01 18:51:28.473 E/SemcSettingsParser( 1809): key not found. key=[group-visible]
04-01 18:51:28.893 D/AudioHardwareMSM7X30( 152): AudioStreamOutMSM72xx::standby()
04-01 18:51:28.893 D/AudioHardwareMSM7X30( 152): updateDeviceInfo: E rx_device 32 and tx_device 13
04-01 18:51:28.893 D/AudioHardwareMSM7X30( 152): No active voicecall/playback, disabling cur_rx 32
04-01 18:51:28.893 D/AudioHardwareMSM7X30( 152): value of device and enable is 32 0
04-01 18:51:28.903 D/kernel ( 144): [ 130.328887] [msm7x30.c:msm_device_put] device xloud_speaker_stereo_rx set 0
04-01 18:51:28.903 D/kernel ( 144): [ 130.329803] msm_snddev_poweramp_off: power off amplifier
04-01 18:51:28.903 D/AudioHardwareMSM7X30( 152): No active voicecall/recording, disabling cur_tx 13
04-01 18:51:28.903 D/AudioHardwareMSM7X30( 152): value of device and enable is 13 0
04-01 18:51:28.903 D/AudioHardwareMSM7X30( 152): updateDeviceInfo: X cur_rx 32 cur_tx 13
04-01 18:51:28.903 I/AudioHardwareMSM7X30( 152): Routing audio to Speakerphone
04-01 18:51:28.903 I/AudioHardwareMSM7X30( 152): Change routing audio to speaker for xLOUD
04-01 18:51:28.903 I/ActivityManager( 289): START {act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 cmp=com.surpax.ledflashlight.panel/com.surpax.ledflashlight.FlashlightActivity bnds=[12,433][125,592]} from pid 556
04-01 18:51:28.913 D/kernel ( 144): [ 130.334533] [adsp.c:msm_adsp_put] closing module AFETASK
04-01 18:51:28.913 D/kernel ( 144): [ 130.334930] [msm7x30.c:msm_device_put] device speaker_mono_tx set 0
04-01 18:51:28.913 D/kernel ( 144): [ 130.335083] [audpp.c:audpp_dsp_event] DISABLE
04-01 18:51:28.913 D/kernel ( 144): [ 130.335144] [audpp.c:audpp_disable] Received CFG_MSG_DISABLE from ADSP
04-01 18:51:28.913 D/kernel ( 144): [ 130.335205] [adsp.c:msm_adsp_disable] disable interrupt
04-01 18:51:28.913 D/kernel ( 144): [ 130.335235] [adsp.c:msm_adsp_put] closing module AUDPPTASK
04-01 18:51:28.933 D/AudioHardwareMSM7X30( 152): value of device and enable is 32 1
04-01 18:51:28.943 D/kernel ( 144): [ 130.370544] [msm7x30.c:msm_device_put] device xloud_speaker_stereo_rx set 1
04-01 18:51:28.943 D/kernel ( 144): [ 130.370544] [msm7x30.c:msm_device_put] device freq =48000
04-01 18:51:28.953 D/kernel ( 144): [ 130.373870] [adsp.c:msm_adsp_get] module AFETASK has been registered
04-01 18:51:28.953 D/kernel ( 144): [ 130.373901] [adsp.c:msm_adsp_enable] enable 'AFETASK'state[0] id[17227119]
04-01 18:51:28.953 D/kernel ( 144): [ 130.378601] [adsp.c:adsp_rtos_mtoa_cb] rpc event=0, proc_id=2, module=17227119, image=0
04-01 18:51:28.953 D/kernel ( 144): [ 130.378601] [adsp.c:adsp_rtos_mtoa_cb] module AFETASK: READY
04-01 18:51:28.993 I/ActivityManager( 289): Start proc com.surpax.ledflashlight.panel for activity com.surpax.ledflashlight.panel/com.surpax.ledflashlight.FlashlightActivity: pid=1973 uid=10136 gids={1006, 3003, 1015}
04-01 18:51:29.013 D/kernel ( 144): [ 130.434265] msm_snddev_poweramp_on: power on amplifier
04-01 18:51:29.013 D/kernel ( 144): [ 130.434356] [adsp.c:msm_adsp_get] module AUDPPTASK has been registered
04-01 18:51:29.013 D/kernel ( 144): [ 130.434356] [adsp.c:msm_adsp_enable] enable 'AUDPPTASK'state[0] id[17227122]
04-01 18:51:29.013 D/kernel ( 144): [ 130.435455] [adsp.c:adsp_rtos_mtoa_cb] rpc event=0, proc_id=2, module=17227122, image=0
04-01 18:51:29.013 D/kernel ( 144): [ 130.435455] [adsp.c:adsp_rtos_mtoa_cb] module AUDPPTASK: READY
04-01 18:51:29.013 D/kernel ( 144): [ 130.439575] [audpp.c:audpp_dsp_event] ENABLE
04-01 18:51:29.023 D/kernel ( 144): [ 130.450592] [adsp.c:msm_adsp_write] AUDPPTASK command took 69 attempts: rc 0
04-01 18:51:29.023 I/dalvikvm( 1973): Turning on JNI app bug workarounds for target SDK version 4...
04-01 18:51:29.043 W/ResourceType( 289): Skipping entry 0x7f040010 in package table 0 because it is not complex!
04-01 18:51:29.053 W/ResourceType( 289): Skipping entry 0x7f04003d in package table 0 because it is not complex!
04-01 18:51:29.173 D/dalvikvm( 1973): GC_CONCURRENT freed 369K, 5% free 8938K/9351K, paused 2ms+2ms
04-01 18:51:29.193 D/FlurryAgent( 1973): Initializing Flurry session
04-01 18:51:29.193 D/FlurryAgent( 1973): New session
04-01 18:51:29.203 W/Settings( 1973): Setting android_id has moved from android.provider.Settings.System to android.provider.Settings.Secure, returning read-only value.
04-01 18:51:29.203 I/FlurryAgent( 1973): loading persistent data: /data/data/com.surpax.ledflashlight.panel/files/.flurryagent.-b2b74f8
04-01 18:51:29.203 D/FlurryAgent( 1973): Loading API key: ****************NY5S
04-01 18:51:29.203 D/FlurryAgent( 1973): Loading session reports
04-01 18:51:29.203 D/FlurryAgent( 1973): Session report added: 1
04-01 18:51:29.203 D/FlurryAgent( 1973): Persistent file loaded
04-01 18:51:29.213 I/FlurryAgent( 1973): Fetching IMEI: [B@2bde0500
04-01 18:51:29.213 D/FlurryAgent( 1973): generating report
04-01 18:51:29.213 I/FlurryAgent( 1973): Sent IMEI: [118, 33, 32, -76, 115, 63, 16, -37, 33, -116, -49, -44, -33, -99, 77, 62, -49, -118, -68, 98]
04-01 18:51:29.213 D/FlurryAgent( 1973): Sending report to: http://data.flurry.com/aap.do
04-01 18:51:29.343 D/FlurryAgent( 1973): Event count incremented: App_Opened
04-01 18:51:29.343 D/FlurryAgent( 1973): Logged event: App_Opened
04-01 18:51:29.343 I/TapjoyLog( 1973): enableLogging: true
04-01 18:51:29.343 I/TapjoyConnect( 1973): deviceID: 358343044968628
04-01 18:51:29.343 I/TapjoyConnect( 1973): ANDROID SDK VERSION: 15
04-01 18:51:29.353 I/TapjoyConnect( 1973): Metadata successfully loaded
04-01 18:51:29.353 I/TapjoyConnect( 1973): APP_ID = [ef0eb7cf-3a72-419f-9b59-bcfbbad427dc]
04-01 18:51:29.353 I/TapjoyConnect( 1973): ANDROID_ID: [741c9889fa4bb846]
04-01 18:51:29.353 I/TapjoyConnect( 1973): CLIENT_PACKAGE = [com.surpax.ledflashlight.panel]
04-01 18:51:29.353 I/TapjoyConnect( 1973): deviceID: [358343044968628]
04-01 18:51:29.353 I/TapjoyConnect( 1973): deviceName: [ST18i]
04-01 18:51:29.353 I/TapjoyConnect( 1973): deviceManufacturer: [Sony Ericsson]
04-01 18:51:29.353 I/TapjoyConnect( 1973): deviceType: [android]
04-01 18:51:29.353 I/TapjoyConnect( 1973): libraryVersion: [8.1.2]
04-01 18:51:29.353 I/TapjoyConnect( 1973): deviceOSVersion: [4.0.4]
04-01 18:51:29.353 I/TapjoyConnect( 1973): COUNTRY_CODE: [IN]
04-01 18:51:29.353 I/TapjoyConnect( 1973): LANGUAGE_CODE: [en]
04-01 18:51:29.353 I/TapjoyConnect( 1973): density: [240]
04-01 18:51:29.353 I/TapjoyConnect( 1973): screen_layout: [2]
04-01 18:51:29.353 I/TapjoyConnect( 1973): carrier_name: [IDEA]
04-01 18:51:29.353 I/TapjoyConnect( 1973): carrier_country_code: [in]
04-01 18:51:29.353 I/TapjoyConnect( 1973): mobile_country_code: [40424]
04-01 18:51:29.353 I/TapjoyConnect( 1973): referralURL: []
04-01 18:51:29.353 I/TapjoyConnect( 1973): connectivity: 0
04-01 18:51:29.353 I/TapjoyConnect( 1973): connection_type: mobile
04-01 18:51:29.363 D/dalvikvm( 1973): GC_CONCURRENT freed 454K, 6% free 9052K/9543K, paused 2ms+3ms
04-01 18:51:29.363 I/TapjoyUtil( 1973): SHA256: ef0eb7cf-3a72-419f-9b59-bcfbbad427dc:358343044968628:1364822489:V2oURbIVB5j1Nv9R3l94
04-01 18:51:29.363 I/TapjoyConnect( 1973): URL parameters: app_id=ef0eb7cf-3a72-419f-9b59-bcfbbad427dc&android_id=741c9889fa4bb846&udid=358343044968628&device_name=ST18i&device_manufacturer=Sony%20Ericsson&device_type=android&os_version=4.0.4&country_code=IN&language_code=en&app_version=1.0.2&library_version=8.1.2&platform=android&display_multiplier=1.0&carrier_name=IDEA&carrier_country_code=in&mobile_country_code=40424&screen_density=240&screen_layout_size=2&connection_type=mobile×tamp=1364822489&verifier=16eb58a9c3777070410582cb5462fb275a8b38d8b791421a8e129884a6694272
04-01 18:51:29.373 I/TapjoyConnect( 1973): starting connect call...
04-01 18:51:29.373 I/TapjoyConnect( 1973): connectivity: 0
04-01 18:51:29.373 I/TapjoyConnect( 1973): connection_type: mobile
04-01 18:51:29.373 I/TapjoyUtil( 1973): SHA256: ef0eb7cf-3a72-419f-9b59-bcfbbad427dc:358343044968628:1364822489:V2oURbIVB5j1Nv9R3l94
04-01 18:51:29.373 I/TapjoyURLConnection( 1973): baseURL: https://ws.tapjoyads.com/connect?
04-01 18:51:29.373 I/TapjoyURLConnection( 1973): requestURL: https://ws.tapjoyads.com/connect?app_id=ef0eb7cf-3a72-419f-9b59-bcfbbad427dc&android_id=741c9889fa4b...
04-01 18:51:29.383 D/SurfaceFlinger( 135): Release buffer at 0x70148
04-01 18:51:29.393 D/Surpax App( 1973): soundManager constructor
04-01 18:51:29.393 D/flashlightactivity( 1973): load sound resource now.....
04-01 18:51:29.403 E/CMarlinMediator( 137): Error : MarlinMediator Failed to get TrustedTime
04-01 18:51:29.413 D/Surpax App( 1973): screen height is:854, width is:480
04-01 18:51:29.463 E/CMarlinMediator( 137): Error : MarlinMediator Failed to get TrustedTime
04-01 18:51:29.463 D/dalvikvm( 1973): GC_FOR_ALLOC freed 127K, 5% free 9130K/9543K, paused 27ms
04-01 18:51:29.473 I/dalvikvm-heap( 1973): Grow heap (frag case) to 10.515MB for 1639696-byte allocation
04-01 18:51:29.523 E/CMarlinMediator( 137): Error : MarlinMediator Failed to get TrustedTime
04-01 18:51:29.533 D/dalvikvm( 1973): GC_FOR_ALLOC freed 2K, 5% free 10729K/11207K, paused 28ms
04-01 18:51:29.593 D/FlashLightActivity_Test( 1973): background bmps's width is:480, height is:854
04-01 18:51:29.623 D/dalvikvm( 1973): GC_CONCURRENT freed 5K, 4% free 10859K/11207K, paused 2ms+12ms
04-01 18:51:29.653 D/dalvikvm( 1973): GC_FOR_ALLOC freed 2K, 3% free 11095K/11399K, paused 17ms
04-01 18:51:29.653 I/dalvikvm-heap( 1973): Grow heap (frag case) to 11.791MB for 966416-byte allocation
04-01 18:51:29.703 D/dalvikvm( 1973): GC_CONCURRENT freed <1K, 3% free 12038K/12359K, paused 2ms+3ms
04-01 18:51:29.713 D/flashlight manager( 1973): system sdk version is:15
04-01 18:51:29.713 D/flashlight manager( 1973): mobile manufacture is:Sony Ericsson
04-01 18:51:29.713 D/flashlight manager( 1973): mobile brand is:SEMC
04-01 18:51:29.713 D/flashlight manager( 1973): mobile model is:ST18i
04-01 18:51:29.713 D/flashlight manager( 1973): loadDevice index is 0
04-01 18:51:29.713 W/System.err( 1973): java.lang.NullPointerException
04-01 18:51:29.713 W/System.err( 1973): at com.ihs.c.a.h.f(Unknown Source)
04-01 18:51:29.713 W/System.err( 1973): at com.ihs.c.a.h.a(Unknown Source)
04-01 18:51:29.713 W/System.err( 1973): at com.ihs.c.a.d.b(Unknown Source)
04-01 18:51:29.713 W/System.err( 1973): at com.surpax.b.a.c.a(Unknown Source)
04-01 18:51:29.713 W/System.err( 1973): at com.surpax.ledflashlight.FlashlightActivity.onStart(Unknown Source)
04-01 18:51:29.713 W/System.err( 1973): at android.app.Instrumentation.callActivityOnStart(Instrumentation.java:1133)
04-01 18:51:29.713 W/System.err( 1973): at android.app.Activity.performStart(Activity.java:4475)
04-01 18:51:29.713 W/System.err( 1973): at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:1940)
04-01 18:51:29.713 W/System.err( 1973): at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:1992)
04-01 18:51:29.713 W/System.err( 1973): at android.app.ActivityThread.access$600(ActivityThread.java:127)
04-01 18:51:29.713 W/System.err( 1973): at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1158)
04-01 18:51:29.713 W/System.err( 1973): at android.os.Handler.dispatchMessage(Handler.java:99)
04-01 18:51:29.713 W/System.err( 1973): at android.os.Looper.loop(Looper.java:137)
04-01 18:51:29.713 W/System.err( 1973): at android.app.ActivityThread.main(ActivityThread.java:4441)
04-01 18:51:29.713 W/System.err( 1973): at java.lang.reflect.Method.invokeNative(Native Method)
04-01 18:51:29.713 W/System.err( 1973): at java.lang.reflect.Method.invoke(Method.java:511)
04-01 18:51:29.713 W/System.err( 1973): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:784)
04-01 18:51:29.713 W/System.err( 1973): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:551)
04-01 18:51:29.713 W/System.err( 1973): at dalvik.system.NativeStart.main(Native Method)
04-01 18:51:29.713 D/flashlight manager( 1973): try to use flash_mode_on mark
04-01 18:51:29.713 D/AndroidRuntime( 1973): Shutting down VM
04-01 18:51:29.713 W/dalvikvm( 1973): threadid=1: thread exiting with uncaught exception (group=0x2b542210)
04-01 18:51:29.713 W/System.err( 1973): java.lang.RuntimeException: Unable to start activity ComponentInfo{com.surpax.ledflashlight.panel/com.surpax.ledflashlight.FlashlightActivity}: java.lang.NullPointerException
04-01 18:51:29.713 W/System.err( 1973): at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:1967)
04-01 18:51:29.713 W/System.err( 1973): Caused by: java.lang.NullPointerException
04-01 18:51:29.713 W/System.err( 1973): at com.ihs.c.a.f.f(Unknown Source)
04-01 18:51:29.713 W/System.err( 1973): at com.ihs.c.a.f.a(Unknown Source)
04-01 18:51:29.713 W/System.err( 1973): ... 11 more
04-01 18:51:29.713 D/FlurryAgent( 1973): Error logged: uncaught
04-01 18:51:29.713 D/FlurryAgent( 1973): Ending session
04-01 18:51:29.713 E/AndroidRuntime( 1973): FATAL EXCEPTION: main
04-01 18:51:29.713 E/AndroidRuntime( 1973): java.lang.RuntimeException: Unable to start activity ComponentInfo{com.surpax.ledflashlight.panel/com.surpax.ledflashlight.FlashlightActivity}: java.lang.NullPointerException
04-01 18:51:29.713 E/AndroidRuntime( 1973): at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:1967)
04-01 18:51:29.713 E/AndroidRuntime( 1973): at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:1992)
04-01 18:51:29.713 E/AndroidRuntime( 1973): at android.app.ActivityThread.access$600(ActivityThread.java:127)
04-01 18:51:29.713 E/AndroidRuntime( 1973): at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1158)
04-01 18:51:29.713 E/AndroidRuntime( 1973): at android.os.Handler.dispatchMessage(Handler.java:99)
04-01 18:51:29.713 E/AndroidRuntime( 1973): at android.os.Looper.loop(Looper.java:137)
04-01 18:51:29.713 E/AndroidRuntime( 1973): at android.app.ActivityThread.main(ActivityThread.java:4441)
04-01 18:51:29.713 E/AndroidRuntime( 1973): at java.lang.reflect.Method.invokeNative(Native Method)
04-01 18:51:29.713 E/AndroidRuntime( 1973): at java.lang.reflect.Method.invoke(Method.java:511)
04-01 18:51:29.713 E/AndroidRuntime( 1973): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:784)
04-01 18:51:29.713 E/AndroidRuntime( 1973): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:551)
04-01 18:51:29.713 E/AndroidRuntime( 1973): at dalvik.system.NativeStart.main(Native Method)
04-01 18:51:29.713 E/AndroidRuntime( 1973): Caused by: java.lang.NullPointerException
04-01 18:51:29.713 E/AndroidRuntime( 1973): at com.ihs.c.a.f.f(Unknown Source)
04-01 18:51:29.713 E/AndroidRuntime( 1973): at com.ihs.c.a.f.a(Unknown Source)
04-01 18:51:29.713 E/AndroidRuntime( 1973): at com.ihs.c.a.d.b(Unknown Source)
04-01 18:51:29.713 E/AndroidRuntime( 1973): at com.surpax.b.a.c.a(Unknown Source)
04-01 18:51:29.713 E/AndroidRuntime( 1973): at com.surpax.ledflashlight.FlashlightActivity.onStart(Unknown Source)
04-01 18:51:29.713 E/AndroidRuntime( 1973): at android.app.Instrumentation.callActivityOnStart(Instrumentation.java:1133)
04-01 18:51:29.713 E/AndroidRuntime( 1973): at android.app.Activity.performStart(Activity.java:4475)
04-01 18:51:29.713 E/AndroidRuntime( 1973): at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:1940)
04-01 18:51:29.713 E/AndroidRuntime( 1973): ... 11 more
04-01 18:51:29.723 W/ActivityManager( 289): Force finishing activity com.surpax.ledflashlight.panel/com.surpax.ledflashlight.FlashlightActivity
04-01 18:51:29.933 D/dalvikvm( 289): GC_CONCURRENT freed 776K, 16% free 14489K/17159K, paused 2ms+7ms
04-01 18:51:30.263 W/ActivityManager( 289): Activity pause timeout for ActivityRecord{2c3a05b0 com.surpax.ledflashlight.panel/com.surpax.ledflashlight.FlashlightActivity}
04-01 18:51:30.333 I/ActivityManager( 289): No longer want com.android.gallery3d (pid 1365): hidden #16
04-01 18:51:30.353 D/FlurryAgent( 1973): Report successful
04-01 18:51:30.353 D/FlurryAgent( 1973): Processing report response
04-01 18:51:30.353 D/FlurryAgent( 1973): Done sending agent report
04-01 18:51:30.453 D/dalvikvm( 498): GC_CONCURRENT freed 314K, 7% free 9508K/10183K, paused 4ms+3ms
04-01 18:51:30.453 W/System.err( 1973): java.io.FileNotFoundException: /data/data/com.surpax.ledflashlight.panel/files/HSMessageAlerts.plist: open failed: ENOENT (No such file or directory)
04-01 18:51:30.453 W/System.err( 1973): at libcore.io.IoBridge.open(IoBridge.java:419)
04-01 18:51:30.453 W/System.err( 1973): at java.io.FileInputStream.
04-01 18:51:30.453 W/System.err( 1973): at android.app.ContextImpl.openFileInput(ContextImpl.java:610)
04-01 18:51:30.453 W/System.err( 1973): at android.content.ContextWrapper.openFileInput(ContextWrapper.java:159)
04-01 18:51:30.453 W/System.err( 1973): at com.ihs.f.d.b(Unknown Source)
04-01 18:51:30.453 W/System.err( 1973): at com.ihs.alerts.f.a(Unknown Source)
04-01 18:51:30.453 W/System.err( 1973): at com.ihs.alerts.a.a(Unknown Source)
04-01 18:51:30.453 W/System.err( 1973): at com.ihs.e.a.a.a(Unknown Source)
04-01 18:51:30.453 W/System.err( 1973): at com.ihs.e.a.h.run(Unknown Source)
04-01 18:51:30.453 W/System.err( 1973): Caused by: libcore.io.ErrnoException: open failed: ENOENT (No such file or directory)
04-01 18:51:30.453 W/System.err( 1973): at libcore.io.Posix.open(Native Method)
04-01 18:51:30.453 W/System.err( 1973): at libcore.io.BlockGuardOs.open(BlockGuardOs.java:110)
04-01 18:51:30.453 W/System.err( 1973): at libcore.io.IoBridge.open(IoBridge.java:403)
04-01 18:51:30.453 W/System.err( 1973): ... 9 more
04-01 18:51:30.453 W/System.err( 1973): java.io.FileNotFoundException: HSMessageAlerts.plist
04-01 18:51:30.453 W/System.err( 1973): at android.content.res.AssetManager.openAsset(Native Method)
04-01 18:51:30.453 W/System.err( 1973): at android.content.res.AssetManager.open(AssetManager.java:315)
04-01 18:51:30.453 W/System.err( 1973): at android.content.res.AssetManager.open(AssetManager.java:289)
04-01 18:51:31.273 D/dalvikvm( 1973): GC_CONCURRENT freed 689K, 6% free 12455K/13191K, paused 2ms+3ms
04-01 18:51:31.763 I/AudioHardwareMSM7X30( 152): Routing audio to Speakerphone
04-01 18:51:31.763 I/AudioHardwareMSM7X30( 152): Change routing audio to speaker for xLOUD
04-01 18:51:31.773 I/ActivityManager( 289): START {act=android.intent.action.APP_ERROR flg=0x10000000 cmp=com.android.vending/com.google.android.finsky.activities.AppCrashProxy (has extras)} from pid 289
04-01 18:51:31.783 W/InputManagerService( 289): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@2c1fa790
04-01 18:51:31.813 I/Process ( 1973): Sending signal. PID: 1973 SIG: 9
04-01 18:51:31.823 I/ActivityManager( 289): START {act=android.intent.action.APP_ERROR flg=0x10000000 pkg=com.google.android.feedback cmp=com.google.android.feedback/.FeedbackActivity (has extras)} from pid 1139
04-01 18:51:31.843 I/ActivityManager( 289): Process com.surpax.ledflashlight.panel (pid 1973) has died.
04-01 18:51:31.873 I/ActivityManager( 289): Start proc com.google.android.feedback for activity com.google.android.feedback/.FeedbackActivity: pid=2031 uid=10126 gids={1007, 3003}
04-01 18:51:32.033 D/SurfaceFlinger( 135): Release buffer at 0x70148
04-01 18:51:32.093 I/ActivityManager( 289): START {cmp=com.google.android.feedback/.ShowTosActivity} from pid 2031
04-01 18:51:32.193 D/SurfaceFlinger( 135): Release buffer at 0x8b9c0
04-01 18:51:32.223 D/dalvikvm( 2031): GC_CONCURRENT freed 249K, 4% free 9065K/9351K, paused 3ms+3ms
04-01 18:51:32.323 D/dalvikvm( 2031): GC_FOR_ALLOC freed 255K, 5% free 9157K/9607K, paused 20ms
04-01 18:51:32.333 I/dalvikvm-heap( 2031): Grow heap (frag case) to 9.115MB for 143930-byte allocation
04-01 18:51:32.363 D/dalvikvm( 2031): GC_FOR_ALLOC freed 93K, 7% free 9204K/9799K, paused 19ms
04-01 18:51:32.413 D/dalvikvm( 2031): GC_FOR_ALLOC freed 153K, 6% free 9220K/9799K, paused 27ms
04-01 18:51:32.413 I/dalvikvm-heap( 2031): Grow heap (frag case) to 9.245MB for 215890-byte allocation
04-01 18:51:32.453 D/dalvikvm( 2031): GC_FOR_ALLOC freed 141K, 8% free 9289K/10055K, paused 24ms
04-01 18:51:32.563 D/dalvikvm( 2031): GC_CONCURRENT freed 370K, 7% free 9430K/10055K, paused 2ms+7ms
04-01 18:51:32.563 D/TextLayoutCache( 2031): Using debug level: 0 - Debug Enabled: 0
04-01 18:51:32.603 D/libEGL ( 2031): loaded /system/lib/egl/libGLES_android.so
04-01 18:51:32.633 D/libEGL ( 2031): loaded /system/lib/egl/libEGL_adreno200.so
04-01 18:51:32.643 D/libEGL ( 2031): loaded /system/lib/egl/libGLESv1_CM_adreno200.so
04-01 18:51:32.653 D/libEGL ( 2031): loaded /system/lib/egl/libGLESv2_adreno200.so
04-01 18:51:32.733 D/dalvikvm( 2031): GC_CONCURRENT freed 480K, 7% free 9437K/10055K, paused 2ms+4ms
04-01 18:51:32.803 D/dalvikvm( 2031): GC_FOR_ALLOC freed 231K, 6% free 9468K/10055K, paused 38ms
04-01 18:51:32.803 I/dalvikvm-heap( 2031): Grow heap (frag case) to 9.439MB for 166076-byte allocation
04-01 18:51:32.833 D/dalvikvm( 2031): GC_FOR_ALLOC freed 108K, 8% free 9522K/10247K, paused 18ms
04-01 18:51:32.843 D/OpenGLRenderer( 2031): Enabling debug mode 0
04-01 18:51:32.903 D/dalvikvm( 2031): GC_FOR_ALLOC freed 299K, 7% free 9606K/10247K, paused 31ms
04-01 18:51:33.023 I/ActivityManager( 289): Displayed com.google.android.feedback/.ShowTosActivity: +904ms (total +29s844ms)
04-01 18:51:33.123 E/JavaBinder( 2031): !!! FAILED BINDER TRANSACTION !!!
04-01 18:51:33.133 D/kernel ( 144): [ 134.557312] binder: 2031:2031 transaction failed 29201, size 940968-4
04-01 18:51:33.173 E/SemcSettingsParser( 1809): key not found. key=[brand]
04-01 18:51:33.173 E/SemcSettingsParser( 1809): key not found. key=[group-visible]
04-01 18:51:33.183 E/SemcSettingsParser( 1809): key not found. key=[brand]
04-01 18:51:33.183 E/SemcSettingsParser( 1809): key not found. key=[group-visible]
04-01 18:51:33.193 E/SemcSettingsParser( 1809): key not found. key=[brand]
04-01 18:51:33.193 E/SemcSettingsParser( 1809): key not found. key=[group-visible]
04-01 18:51:33.203 E/SemcSettingsParser( 1809): key not found. key=[brand]
04-01 18:51:33.203 E/SemcSettingsParser( 1809): key not found. key=[group-visible]
04-01 18:51:33.213 E/SemcSettingsParser( 1809): key not found. key=[brand]
04-01 18:51:33.213 E/SemcSettingsParser( 1809): key not found. key=[group-visible]
04-01 18:51:33.233 D/SurfaceFlinger( 135): Release buffer at 0x8f110
04-01 18:51:33.793 D/dalvikvm( 2031): GC_CONCURRENT freed 397K, 7% free 9610K/10247K, paused 2ms+2ms
04-01 18:51:34.023 W/chromium( 2031): external/chromium/net/spdy/spdy_session.cc:1058: [0401/185134:WARNING:spdy_session.cc(1058)] Received data frame for invalid stream 1
04-01 18:51:34.423 D/SurfaceFlinger( 135): Release buffer at 0x8edf0
04-01 18:51:34.423 W/ActivityManager( 289): Activity destroy timeout for ActivityRecord{2c1ea0a0 com.surpax.ledflashlight.panel/com.surpax.ledflashlight.FlashlightActivity}
04-01 18:51:34.863 D/AudioHardwareMSM7X30( 152): AudioStreamOutMSM72xx::standby()
04-01 18:51:34.863 D/AudioHardwareMSM7X30( 152): updateDeviceInfo: E rx_device 32 and tx_device 13
04-01 18:51:34.863 D/AudioHardwareMSM7X30( 152): No active voicecall/playback, disabling cur_rx 32
04-01 18:51:34.863 D/AudioHardwareMSM7X30( 152): value of device and enable is 32 0
04-01 18:51:34.863 D/AudioHardwareMSM7X30( 152): No active voicecall/recording, disabling cur_tx 13
04-01 18:51:34.863 D/AudioHardwareMSM7X30( 152): value of device and enable is 13 0
04-01 18:51:34.863 D/AudioHardwareMSM7X30( 152): updateDeviceInfo: X cur_rx 32 cur_tx 13
04-01 18:51:34.873 D/kernel ( 144): [ 136.298828] [msm7x30.c:msm_device_put] device xloud_speaker_stereo_rx set 0
04-01 18:51:34.873 D/kernel ( 144): [ 136.299468] msm_snddev_poweramp_off: power off amplifier
04-01 18:51:34.873 D/kernel ( 144): [ 136.301940] [adsp.c:msm_adsp_put] closing module AFETASK
04-01 18:51:34.873 D/kernel ( 144): [ 136.302154] [msm7x30.c:msm_device_put] device speaker_mono_tx set 0
04-01 18:51:34.873 D/kernel ( 144): [ 136.302246] [audpp.c:audpp_dsp_event] DISABLE
04-01 18:51:34.873 D/kernel ( 144): [ 136.302276] [audpp.c:audpp_disable] Received CFG_MSG_DISABLE from ADSP
04-01 18:51:34.873 D/kernel ( 144): [ 136.302307] [adsp.c:msm_adsp_disable] disable interrupt
04-01 18:51:34.873 D/kernel ( 144): [ 136.302307] [adsp.c:msm_adsp_put] closing module AUDPPTASK
04-01 18:51:36.253 I/AudioHardwareMSM7X30( 152): Routing audio to Speakerphone
04-01 18:51:36.253 I/AudioHardwareMSM7X30( 152): Change routing audio to speaker for xLOUD
04-01 18:51:36.273 D/AudioHardwareMSM7X30( 152): value of device and enable is 32 1
04-01 18:51:36.283 D/kernel ( 144): [ 137.706268] [msm7x30.c:msm_device_put] device xloud_speaker_stereo_rx set 1
04-01 18:51:36.283 D/kernel ( 144): [ 137.706298] [msm7x30.c:msm_device_put] device freq =48000
04-01 18:51:36.283 D/kernel ( 144): [ 137.709808] [adsp.c:msm_adsp_get] module AFETASK has been registered
04-01 18:51:36.283 D/kernel ( 144): [ 137.709838] [adsp.c:msm_adsp_enable] enable 'AFETASK'state[0] id[17227119]
04-01 18:51:36.293 D/kernel ( 144): [ 137.715423] [adsp.c:adsp_rtos_mtoa_cb] rpc event=0, proc_id=2, module=17227119, image=0
04-01 18:51:36.293 D/kernel ( 144): [ 137.715454] [adsp.c:adsp_rtos_mtoa_cb] module AFETASK: READY
04-01 18:51:36.343 D/kernel ( 144): [ 137.763946] msm_snddev_poweramp_on: power on amplifier
04-01 18:51:36.343 D/kernel ( 144): [ 137.764038] [adsp.c:msm_adsp_get] module AUDPPTASK has been registered
04-01 18:51:36.343 D/kernel ( 144): [ 137.764038] [adsp.c:msm_adsp_enable] enable 'AUDPPTASK'state[0] id[17227122]
04-01 18:51:36.343 D/kernel ( 144): [ 137.765136] [adsp.c:adsp_rtos_mtoa_cb] rpc event=0, proc_id=2, module=17227122, image=0
04-01 18:51:36.343 D/kernel ( 144): [ 137.765167] [adsp.c:adsp_rtos_mtoa_cb] module AUDPPTASK: READY
04-01 18:51:36.343 D/kernel ( 144): [ 137.769256] [audpp.c:audpp_dsp_event] ENABLE
04-01 18:51:36.353 D/kernel ( 144): [ 137.777221] [adsp.c:msm_adsp_write] AUDPPTASK command took 69 attempts: rc 0
04-01 18:51:36.353 D/dalvikvm( 289): GC_FOR_ALLOC freed 605K, 17% free 14302K/17159K, paused 83ms
04-01 18:51:36.533 I/ActivityManager( 289): Displayed com.google.android.feedback/.FeedbackActivity: +4s681ms
04-01 18:51:36.603 D/OpenGLRenderer( 2031): Flushing caches (mode 0)
04-01 18:51:36.763 D/SurfaceFlinger( 135): Release buffer at 0x70148
04-01 18:51:39.363 D/AudioHardwareMSM7X30( 152): AudioStreamOutMSM72xx::standby()
04-01 18:51:39.363 D/AudioHardwareMSM7X30( 152): updateDeviceInfo: E rx_device 32 and tx_device 13
04-01 18:51:39.363 D/AudioHardwareMSM7X30( 152): No active voicecall/playback, disabling cur_rx 32
04-01 18:51:39.363 D/AudioHardwareMSM7X30( 152): value of device and enable is 32 0
04-01 18:51:39.373 D/kernel ( 144): [ 140.798919] [msm7x30.c:msm_device_put] device xloud_speaker_stereo_rx set 0
04-01 18:51:39.373 D/kernel ( 144): [ 140.801544] msm_snddev_poweramp_off: power off amplifier
04-01 18:51:39.373 D/AudioHardwareMSM7X30( 152): No active voicecall/recording, disabling cur_tx 13
04-01 18:51:39.373 D/AudioHardwareMSM7X30( 152): value of device and enable is 13 0
04-01 18:51:39.373 D/AudioHardwareMSM7X30( 152): updateDeviceInfo: X cur_rx 32 cur_tx 13
04-01 18:51:39.383 D/kernel ( 144): [ 140.804870] [adsp.c:msm_adsp_put] closing module AFETASK
04-01 18:51:39.383 D/kernel ( 144): [ 140.805206] [msm7x30.c:msm_device_put] device speaker_mono_tx set 0
04-01 18:51:39.383 D/kernel ( 144): [ 140.805419] [audpp.c:audpp_dsp_event] DISABLE
04-01 18:51:39.383 D/kernel ( 144): [ 140.805480] [audpp.c:audpp_disable] Received CFG_MSG_DISABLE from ADSP
04-01 18:51:39.383 D/kernel ( 144): [ 140.805541] [adsp.c:msm_adsp_disable] disable interrupt
04-01 18:51:39.383 D/kernel ( 144): [ 140.805572] [adsp.c:msm_adsp_put] closing module AUDPPTASK
04-01 18:51:40.333 D/SurfaceFlinger( 135): Release buffer at 0x78b30
04-01 18:51:40.333 W/ActivityManager( 289): Activity destroy timeout for ActivityRecord{2c3a05b0 com.surpax.ledflashlight.panel/com.surpax.ledflashlight.FlashlightActivity}
04-01 18:51:42.493 D/dalvikvm( 442): GC_CONCURRENT freed 357K, 5% free 9247K/9671K, paused 2ms+3ms
04-01 18:51:42.503 D/CustomizationProvider( 467): openFile -- START uri=content://com.sonyericsson.provider.customization/settings/com.sonyericsson.textinput.uxp
04-01 18:51:42.503 I/CustomizationProvider( 467): No configuration file: /system/etc/customization/settings/com/sonyericsson/textinput/uxp/custom_settings.xml
04-01 18:51:42.603 D/dalvikvm( 442): GC_FOR_ALLOC freed 53K, 4% free 9469K/9799K, paused 18ms
04-01 18:51:42.823 D/dalvikvm( 289): GC_EXPLICIT freed 244K, 17% free 14254K/17159K, paused 6ms+6ms
04-01 18:51:42.963 D/dalvikvm( 442): GC_FOR_ALLOC freed 55K, 3% free 9631K/9927K, paused 72ms
04-01 18:51:42.993 I/dalvikvm-heap( 442): Grow heap (frag case) to 10.052MB for 645136-byte allocation
04-01 18:51:43.023 D/dalvikvm( 366): GC_CONCURRENT freed 429K, 29% free 10109K/14087K, paused 2ms+13ms
04-01 18:51:43.073 D/dalvikvm( 442): GC_CONCURRENT freed 5K, 3% free 10255K/10567K, paused 2ms+2ms
04-01 18:51:43.213 D/dalvikvm( 366): GC_FOR_ALLOC freed 535K, 30% free 9911K/14087K, paused 53ms
04-01 18:51:44.773 D/SurfaceFlinger( 135): Release buffer at 0x78b30
04-01 18:51:48.873 D/SurfaceFlinger( 135): Release buffer at 0x78b30
04-01 18:51:50.673 D/SurfaceFlinger( 135): Release buffer at 0x78b30
04-01 18:51:52.533 D/dalvikvm( 442): GC_CONCURRENT freed 104K, 3% free 10567K/10823K, paused 2ms+2ms
04-01 18:51:52.673 D/dalvikvm( 442): GC_FOR_ALLOC freed 12K, 3% free 10857K/11079K, paused 18ms
04-01 18:51:52.713 I/dalvikvm-heap( 442): Grow heap (frag case) to 11.943MB for 1372016-byte allocation
04-01 18:51:52.753 D/dalvikvm( 442): GC_CONCURRENT freed 1K, 2% free 12196K/12423K, paused 2ms+2ms
04-01 18:51:54.293 D/SurfaceFlinger( 135): Release buffer at 0x78b30
04-01 18:51:55.393 I/ActivityManager( 289): Start proc com.sonyericsson.secureclockservice for service com.sonyericsson.secureclockservice/.SecureClockEventListenerService: pid=2071 uid=10024 gids={3003}
04-01 18:51:55.423 I/SecureClock( 2071): The listener for network connectivity is set up
04-01 18:51:55.423 I/SecureClock( 2071): Generate an initial secure clock value.
04-01 18:51:55.423 I/SecureClock( 2071): Network not connected
04-01 18:51:55.423 I/JNI ( 2071): Trying to load libJNISecureClock.so
04-01 18:51:55.423 D/dalvikvm( 2071): Trying to load lib /data/data/com.sonyericsson.secureclockservice/lib/libJNISecureClock.so 0x2bde3dd8
04-01 18:51:55.423 D/dalvikvm( 2071): Added shared lib /data/data/com.sonyericsson.secureclockservice/lib/libJNISecureClock.so 0x2bde3dd8
04-01 18:51:55.423 D/dalvikvm( 2071): No JNI_OnLoad found in /data/data/com.sonyericsson.secureclockservice/lib/libJNISecureClock.so 0x2bde3dd8, skipping init
04-01 18:51:55.433 I/SecureClock( 2071): network state changed
04-01 18:51:55.433 I/SecureClock( 2071): The phone is now connected with the network again!
04-01 18:51:55.433 I/SecureClock( 2071): fetchNTPTime started
04-01 18:51:55.433 I/SecureClock( 2071): Enter NTP request guard
04-01 18:51:55.433 I/SecureClock( 2071): Ntp time fetching triggered.
04-01 18:51:55.443 I/SecureClock( 2071): Trying to fetch NTP time from the server: xtra1.gpsonextra.net
04-01 18:51:56.023 D/dalvikvm( 442): GC_FOR_ALLOC freed 1404K, 14% free 10862K/12487K, paused 19ms
04-01 18:51:56.023 I/dalvikvm-heap( 442): Grow heap (frag case) to 11.947MB for 1372016-byte allocation
04-01 18:51:56.063 D/dalvikvm( 442): GC_CONCURRENT freed 1K, 3% free 12200K/12487K, paused 3ms+2ms
04-01 18:51:56.233 I/SecureClock( 2071): Retrieved Ntp time:1364822516
04-01 18:51:56.233 I/SecureClock( 2071): Stopping parent service
04-01 18:51:56.233 I/ActivityManager( 289): No longer want com.google.android.partnersetup (pid 1696): hidden #16
04-01 18:51:56.243 I/SecureClock( 2071): Exit NTP request guard
04-01 18:52:00.693 D/SurfaceFlinger( 135): Release buffer at 0x78b30
04-01 18:52:04.203 D/SurfaceFlinger( 135): Release buffer at 0x78b30
04-01 18:52:08.403 D/SurfaceFlinger( 135): Release buffer at 0x78b30
04-01 18:52:11.153 D/SurfaceFlinger( 135): Release buffer at 0x78b30
04-01 18:52:13.463 D/SurfaceFlinger( 135): Release buffer at 0x78b30
04-01 18:52:15.213 D/SurfaceFlinger( 135): Release buffer at 0x78b30
04-01 18:52:17.803 D/SurfaceFlinger( 135): Release buffer at 0x78b30
04-01 18:52:18.433 D/dalvikvm( 442): GC_FOR_ALLOC freed 1583K, 14% free 10862K/12487K, paused 20ms
04-01 18:52:18.433 I/dalvikvm-heap( 442): Grow heap (frag case) to 11.948MB for 1372016-byte allocation
04-01 18:52:18.473 D/dalvikvm( 442): GC_CONCURRENT freed 1K, 3% free 12201K/12487K, paused 2ms+2ms
04-01 18:52:20.593 D/SurfaceFlinger( 135): Release buffer at 0x78b30
04-01 18:52:24.763 D/SurfaceFlinger( 135): Release buffer at 0x78b30
04-01 18:52:27.023 D/SurfaceFlinger( 135): Release buffer at 0x78b30
04-01 18:52:29.953 D/SurfaceFlinger( 135): Release buffer at 0x78b30
04-01 18:52:31.313 D/SurfaceFlinger( 135): Release buffer at 0x78b30
04-01 18:52:31.683 D/dalvikvm( 1003): GC_CONCURRENT freed 423K, 6% free 9153K/9671K, paused 2ms+4ms
04-01 18:52:33.173 D/SurfaceFlinger( 135): Release buffer at 0x78b30
04-01 18:52:36.313 D/SurfaceFlinger( 135): Release buffer at 0x78b30
04-01 18:52:40.033 D/SurfaceFlinger( 135): Release buffer at 0x78b30
04-01 18:52:40.543 I/dalvikvm( 289): Jit: resizing JitTable from 8192 to 16384
04-01 18:52:41.873 D/SurfaceFlinger( 135): Release buffer at 0x78b30
04-01 18:52:47.233 D/SurfaceFlinger( 135): Release buffer at 0x78b30
04-01 18:52:49.663 D/SurfaceFlinger( 135): Release buffer at 0x78b30
04-01 18:52:51.853 D/SurfaceFlinger( 135): Release buffer at 0x78b30
04-01 18:52:53.033 D/SurfaceFlinger( 135): Release buffer at 0x78b30
04-01 18:52:55.233 D/SurfaceFlinger( 135): Release buffer at 0x78b30
04-01 18:52:56.493 D/SurfaceFlinger( 135): Release buffer at 0x78b30
04-01 18:52:58.813 D/SurfaceFlinger( 135): Release buffer at 0x78b30
04-01 18:53:06.613 D/SurfaceFlinger( 135): Release buffer at 0x78b30
04-01 18:53:08.823 D/SurfaceFlinger( 135): Release buffer at 0x78b30
04-01 18:53:10.293 D/SurfaceFlinger( 135): Release buffer at 0x78b30
04-01 18:53:12.563 D/SurfaceFlinger( 135): Release buffer at 0x78b30
04-01 18:53:12.693 I/AudioHardwareMSM7X30( 152): Routing audio to Speakerphone
04-01 18:53:12.693 I/AudioHardwareMSM7X30( 152): Change routing audio to speaker for xLOUD
04-01 18:53:12.703 D/AudioHardwareMSM7X30( 152): value of device and enable is 32 1
04-01 18:53:12.713 D/kernel ( 144): [ 234.142333] [msm7x30.c:msm_device_put] device xloud_speaker_stereo_rx set 1
04-01 18:53:12.713 D/kernel ( 144): [ 234.142364] [msm7x30.c:msm_device_put] device freq =48000
04-01 18:53:12.723 D/kernel ( 144): [ 234.145935] [adsp.c:msm_adsp_get] module AFETASK has been registered
04-01 18:53:12.723 D/kernel ( 144): [ 234.145935] [adsp.c:msm_adsp_enable] enable 'AFETASK'state[0] id[17227119]
04-01 18:53:12.723 D/kernel ( 144): [ 234.152313] [adsp.c:adsp_rtos_mtoa_cb] rpc event=0, proc_id=2, module=17227119, image=0
04-01 18:53:12.723 D/kernel ( 144): [ 234.152313] [adsp.c:adsp_rtos_mtoa_cb] module AFETASK: READY
04-01 18:53:12.793 D/kernel ( 144): [ 234.214019] msm_snddev_poweramp_on: power on amplifier
04-01 18:53:12.793 D/kernel ( 144): [ 234.214080] [adsp.c:msm_adsp_get] module AUDPPTASK has been registered
04-01 18:53:12.793 D/kernel ( 144): [ 234.214080] [adsp.c:msm_adsp_enable] enable 'AUDPPTASK'state[0] id[17227122]
04-01 18:53:12.793 D/kernel ( 144): [ 234.215606] [adsp.c:adsp_rtos_mtoa_cb] rpc event=0, proc_id=2, module=17227122, image=0
04-01 18:53:12.793 D/kernel ( 144): [ 234.215637] [adsp.c:adsp_rtos_mtoa_cb] module AUDPPTASK: READY
04-01 18:53:12.793 D/kernel ( 144): [ 234.219757] [audpp.c:audpp_dsp_event] ENABLE
04-01 18:53:12.803 W/InputManagerService( 289): Starting input on non-focused client com.android.internal.view.IInputMethodClient$Stub$Proxy@2c050008 (uid=10126 pid=2031)
04-01 18:53:12.813 D/kernel ( 144): [ 234.241912] [adsp.c:msm_adsp_write] AUDPPTASK command took 59 attempts: rc 0
04-01 18:53:12.833 W/IInputConnectionWrapper( 2031): showStatusIcon on inactive InputConnection
04-01 18:53:12.883 D/OpenGLRenderer( 2031): Flushing caches (mode 0)
04-01 18:53:12.923 I/ActivityManager( 289): No longer want com.google.android.apps.maps (pid 1777): hidden #16
04-01 18:53:12.943 D/OpenGLRenderer( 2031): Flushing caches (mode 1)
04-01 18:53:12.983 D/SurfaceFlinger( 135): Release buffer at 0x70148
04-01 18:53:13.023 D/dalvikvm( 366): GC_CONCURRENT freed 284K, 29% free 10072K/14087K, paused 3ms+13ms
04-01 18:53:13.143 D/dalvikvm( 2031): GC_CONCURRENT freed 352K, 5% free 9747K/10247K, paused 2ms+15ms
04-01 18:53:13.163 D/SurfaceFlinger( 135): Release buffer at 0x8edf0
04-01 18:53:13.193 D/dalvikvm( 289): GC_CONCURRENT freed 1136K, 17% free 14399K/17159K, paused 6ms+45ms
04-01 18:53:13.263 D/GoogleFeedbackSendService( 2031): starting report scan
04-01 18:53:14.813 D/dalvikvm( 458): GC_CONCURRENT freed 1531K, 10% free 15688K/17287K, paused 2ms+5ms
04-01 18:53:15.503 D/dalvikvm( 2031): GC_CONCURRENT freed 929K, 10% free 9242K/10247K, paused 3ms+4ms
04-01 18:53:15.803 D/SurfaceFlinger( 135): Release buffer at 0x70148
04-01 18:53:15.813 D/AudioHardwareMSM7X30( 152): AudioStreamOutMSM72xx::standby()
04-01 18:53:15.813 D/AudioHardwareMSM7X30( 152): updateDeviceInfo: E rx_device 32 and tx_device 13
04-01 18:53:15.813 D/AudioHardwareMSM7X30( 152): No active voicecall/playback, disabling cur_rx 32
04-01 18:53:15.813 D/AudioHardwareMSM7X30( 152): value of device and enable is 32 0
04-01 18:53:15.813 D/AudioHardwareMSM7X30( 152): No active voicecall/recording, disabling cur_tx 13
04-01 18:53:15.813 D/AudioHardwareMSM7X30( 152): value of device and enable is 13 0
04-01 18:53:15.813 D/AudioHardwareMSM7X30( 152): updateDeviceInfo: X cur_rx 32 cur_tx 13
04-01 18:53:15.823 D/kernel ( 144): [ 237.249114] [msm7x30.c:msm_device_put] device xloud_speaker_stereo_rx set 0
04-01 18:53:15.823 D/kernel ( 144): [ 237.250000] msm_snddev_poweramp_off: power off amplifier
04-01 18:53:15.823 D/kernel ( 144): [ 237.252563] [adsp.c:msm_adsp_put] closing module AFETASK
04-01 18:53:15.823 D/kernel ( 144): [ 237.252746] [msm7x30.c:msm_device_put] device speaker_mono_tx set 0
04-01 18:53:15.823 D/kernel ( 144): [ 237.252838] [audpp.c:audpp_dsp_event] DISABLE
04-01 18:53:15.823 D/kernel ( 144): [ 237.252838] [audpp.c:audpp_disable] Received CFG_MSG_DISABLE from ADSP
04-01 18:53:15.823 D/kernel ( 144): [ 237.252868] [adsp.c:msm_adsp_disable] disable interrupt
04-01 18:53:15.823 D/kernel ( 144): [ 237.252868] [adsp.c:msm_adsp_put] closing module AUDPPTASK
04-01 18:53:26.273 I/AudioHardwareMSM7X30( 152): Routing audio to Speakerphone
04-01 18:53:26.273 I/AudioHardwareMSM7X30( 152): Change routing audio to speaker for xLOUD
04-01 18:53:26.273 I/ActivityManager( 289): START {act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 cmp=vStudio.Android.Camera360/.GPhotoMain bnds=[238,274][351,433]} from pid 556
04-01 18:53:26.283 D/AudioHardwareMSM7X30( 152): value of device and enable is 32 1
04-01 18:53:26.293 D/kernel ( 144): [ 247.721252] [msm7x30.c:msm_device_put] device xloud_speaker_stereo_rx set 1
04-01 18:53:26.293 D/kernel ( 144): [ 247.721252] [msm7x30.c:msm_device_put] device freq =48000
04-01 18:53:26.303 D/kernel ( 144): [ 247.724304] [adsp.c:msm_adsp_get] module AFETASK has been registered
04-01 18:53:26.303 D/kernel ( 144): [ 247.724334] [adsp.c:msm_adsp_enable] enable 'AFETASK'state[0] id[17227119]
04-01 18:53:26.303 D/kernel ( 144): [ 247.728790] [adsp.c:adsp_rtos_mtoa_cb] rpc event=0, proc_id=2, module=17227119, image=0
04-01 18:53:26.303 D/kernel ( 144): [ 247.728790] [adsp.c:adsp_rtos_mtoa_cb] module AFETASK: READY
04-01 18:53:26.353 D/dalvikvm( 1622): Trying to load lib /data/data/vStudio.Android.Camera360/lib/libgphoto.so 0x2bddf340
04-01 18:53:26.363 W/ResourceType( 289): Skipping entry 0x7f04002a in package table 0 because it is not complex!
04-01 18:53:26.373 D/kernel ( 144): [ 247.793975] msm_snddev_poweramp_on: power on amplifier
04-01 18:53:26.373 D/kernel ( 144): [ 247.794067] [adsp.c:msm_adsp_get] module AUDPPTASK has been registered
04-01 18:53:26.373 D/kernel ( 144): [ 247.794067] [adsp.c:msm_adsp_enable] enable 'AUDPPTASK'state[0] id[17227122]
04-01 18:53:26.373 D/kernel ( 144): [ 247.795043] [adsp.c:adsp_rtos_mtoa_cb] rpc event=0, proc_id=2, module=17227122, image=0
04-01 18:53:26.373 D/kernel ( 144): [ 247.795074] [adsp.c:adsp_rtos_mtoa_cb] module AUDPPTASK: READY
04-01 18:53:26.373 D/kernel ( 144): [ 247.799194] [audpp.c:audpp_dsp_event] ENABLE
04-01 18:53:26.373 W/ResourceType( 289): Skipping entry 0x7f04003d in package table 0 because it is not complex!
04-01 18:53:26.373 D/dalvikvm( 1622): Added shared lib /data/data/vStudio.Android.Camera360/lib/libgphoto.so 0x2bddf340
04-01 18:53:26.373 I/GPhoto ( 1622): GPhoto JNI_OnLoad!
04-01 18:53:26.383 D/kernel ( 144): [ 247.810852] [adsp.c:msm_adsp_write] AUDPPTASK command took 69 attempts: rc 0
04-01 18:53:26.403 E/Command ( 939): Start Command
04-01 18:53:26.423 I/camera-360( 1622): cost enter load
04-01 18:53:26.453 D/dalvikvm( 1622): GC_FOR_ALLOC freed 183K, 3% free 9230K/9479K, paused 24ms
04-01 18:53:26.463 I/dalvikvm-heap( 1622): Grow heap (frag case) to 10.513MB for 1536016-byte allocation
04-01 18:53:26.483 W/GoogleFeedbackSendService( 2031): sending report status: 204
04-01 18:53:26.503 D/GoogleFeedbackSendService( 2031): finished report scan: scanAgain: false networkError: false
04-01 18:53:26.533 D/dalvikvm( 1622): GC_CONCURRENT freed 1K, 3% free 10728K/11015K, paused 2ms+2ms
04-01 18:53:26.573 I/GSceneInstall( 1622): read xml
04-01 18:53:26.573 I/GSceneInstall( 1622): name:Default Template
04-01 18:53:26.573 I/GSceneInstall( 1622): name_cn:默认模版
04-01 18:53:26.573 I/GSceneInstall( 1622): path:defaultTemplate
04-01 18:53:26.573 I/GSceneInstall( 1622): ver:1.0
04-01 18:53:26.713 D/SurfaceFlinger( 135): Release buffer at 0x78b30
04-01 18:53:26.803 I/GSceneInstall( 1622): test_template
04-01 18:53:26.913 I/GPhoto ( 1622): GPhoto onResume
04-01 18:53:26.913 D/dalvikvm( 1622): Trying to load lib /data/data/vStudio.Android.Camera360/lib/libgphoto.so 0x2bddf340
04-01 18:53:26.913 D/dalvikvm( 1622): Shared lib '/data/data/vStudio.Android.Camera360/lib/libgphoto.so' already loaded in same CL 0x2bddf340
04-01 18:53:26.963 I/MobclickAgent( 1622): Could not get location from GPS or Cell-id, lack ACCESS_COARSE_LOCATION or ACCESS_COARSE_LOCATION permission?
04-01 18:53:26.983 I/MobclickAgent( 1622): Start new session: c9a1ff8860482dc39f1eb1d67998de7b
04-01 18:53:26.993 D/dalvikvm( 1622): GC_EXPLICIT freed 370K, 5% free 10874K/11335K, paused 6ms+5ms
04-01 18:53:27.063 I/MobclickAgent( 1622): Could not get location from GPS or Cell-id, lack ACCESS_COARSE_LOCATION or ACCESS_COARSE_LOCATION permission?
04-01 18:53:27.083 D/dalvikvm( 1622): GC_EXPLICIT freed 148K, 5% free 10842K/11335K, paused 2ms+4ms
04-01 18:53:27.123 V/PhoneStatusBar( 366): setLightsOn(true)
04-01 18:53:27.143 I/MobclickAgent( 1622): Could not get location from GPS or Cell-id, lack ACCESS_COARSE_LOCATION or ACCESS_COARSE_LOCATION permission?
04-01 18:53:27.193 I/TAG ( 1622): net type:internet
04-01 18:53:27.203 I/MobclickAgent( 1622): {"body":{"launch":[{"date":"2013-04-01","session_id":"24918c8d5ad2233aeef6ca0371249c73","time":"18:50:02"},{"date":"2013-04-01","session_id":"a5fd3859d1c28d8e9e5c2fde8c5d1ae4","time":"18:50:02"},{"date":"2013-04-01","time":"18:53:26","session_id":"c9a1ff8860482dc39f1eb1d67998de7b"}],"terminate":[{"date":"2013-04-01","duration":"0","time":"18:47:44","session_id":"275886a044ff64e1f4f1365729f35e57"},{"date":"2013-04-01","duration":"0","time":"18:50:02","session_id":"be40e063ced7b8e64a9fe63819b2da89"},{"date":"2013-04-01","duration":"0","time":"18:50:02","session_id":"24918c8d5ad2233aeef6ca0371249c73"},{"date":"2013-04-01","session_id":"a5fd3859d1c28d8e9e5c2fde8c5d1ae4","time":"18:53:26","duration":"0"}],"event":[{"time":"18:30:58","session_id":"","date":"2013-04-01","acc":1,"tag":"a1000"},{"session_id":"275886a044ff64e1f4f1365729f35e57","time":"18:47:44","date":"2013-04-01","tag":"a1000","acc":1},{"session_id":"be40e063ced7b8e64a9fe63819b2da89","time":"18:50:02","date":"2013-04-01","tag":"a1000","acc":1},{"time":"18:53:26","session_id":"a5fd3859d1c28d8e9e5c2fde8c5d1ae4","date":"2013-04-01","acc":1,"tag":"a1000"}]},"header":{"os":"Android","access_subtype":"HSPA","package":"vStudio.Android.Camera360","cpu":"ARMv7 Processor rev 2 (v7l)","appkey":"4c528da01d41c85ecf000211","sdk_version":"3.3","app_version":"3.9","lng":0,"device_id":"358343044968628","resolution":"854*480","access":"2G\/3G","country":"IN","os_version":"4.0.4","version_code":207,"idmd5":"a7b59e2f2153de9b73c6436412dd776","device_model":"ST18i","timezone":5,"sdk_type":"Android","carrier":"IDEA","language":"en","channel":"GoogleMarket","lat":0}}
04-01 18:53:27.213 I/ActivityManager( 289): Displayed vStudio.Android.Camera360/.GPhotoMain: +876ms
04-01 18:53:27.263 D/dalvikvm( 1622): GC_EXPLICIT freed 141K, 5% free 10873K/11335K, paused 2ms+8ms
04-01 18:53:27.283 I/camera-360( 1622): ---- load : CameraDeltaDegree = 0
04-01 18:53:27.283 I/GPhoto ( 1622): set orientation ..
04-01 18:53:27.283 I/camera-360( 1622): screen rotation : 0
04-01 18:53:27.283 W/System.err( 1622): java.lang.RuntimeException: Fail to get camera info
04-01 18:53:27.283 W/System.err( 1622): at android.hardware.Camera.getCameraInfo(Native Method)
04-01 18:53:27.283 W/System.err( 1622): at vStudio.Android.Camera360.Tools.CameraTools.setCameraDisplayOrientation(CameraTools.java:144)
04-01 18:53:27.283 W/System.err( 1622): at vStudio.Android.Camera360.AbsGPhotoCamera.proxyOpenCamera(AbsGPhotoCamera.java:4738)
04-01 18:53:27.283 W/System.err( 1622): at vStudio.Android.Camera360.AbsGPhotoCamera.access$79(AbsGPhotoCamera.java:4732)
04-01 18:53:27.283 W/System.err( 1622): at vStudio.Android.Camera360.AbsGPhotoCamera$17.run(AbsGPhotoCamera.java:1480)
04-01 18:53:27.283 W/System.err( 1622): at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1076)
04-01 18:53:27.283 W/System.err( 1622): at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:569)
04-01 18:53:27.283 W/System.err( 1622): at java.lang.Thread.run(Thread.java:856)
04-01 18:53:27.283 I/camera-360( 1622): show camera connected fail dialog ..
04-01 18:53:27.303 E/CMarlinMediator( 137): Error : MarlinMediator Failed to get TrustedTime
04-01 18:53:27.403 D/SurfaceFlinger( 135): Release buffer at 0x70148
04-01 18:53:27.423 E/CMarlinMediator( 137): Error : MarlinMediator Failed to get TrustedTime
04-01 18:53:27.473 D/TextLayoutCache( 1622): Using debug level: 0 - Debug Enabled: 0
