Front cam problem
Aboutaha
Front cam problem
I have a Z2 with 5.1.1 lollipop version updated since 3 weeks yesterday I want take a selfi but the won't "camera not available. I hard reset my phone but they problem persist. Can you support me
8 REPLIES 8
Phy
Legend
Legend
Try booting on safe mode and check if you can use the camera.
How to boot on safe mode on Lolipop
1. press and hold the power key
2. once you get the pop up menu
3. press and hold "power off"
4. Boot on safe mode should become available
Hampus
Did you restore any backup/installed any applications after you did the factory reset? Follow Phys advice to boot into safe mode to see if same behaviour appears. Otherwise, does the front camera work in other applications?
Aboutaha
Thank you i will try soon
Aboutaha
i try even the instagram camera didn't work !
Aboutaha
Result
Aboutaha
i talk about the 2mp and not the 20mp the secondery one
Hampus
I suggest that you perform a software repair using PC Companion to see if this can help. If same error message appears after you have reinstalled the software, you would do best by visiting nearest service center to have your phone examined by a technician. You can contact your Local support for information about nearest service center and/or how to proceed with this in the best possible way.
Aboutaha
Ok I try
Thank you again for your support
