Hi i just change my screen lock to pin lock and saved 4567 as password bt soon after lock when i entered it shows incorrect
i tried so many times its just shows wait for 30 sec and never prompt me for google account verification if someone has solution please help me
The only thing you can do is run a repair as this will reset your phone back to factory setting thus removing the pin lock however this will also delete your data on the phone
Try using PCC or SUS found here http://www.sonymobile.com/global-en/tools/update-service/
xperia s dont have any slot for memory card it has in built memory and when i connect to pc companion its cant access memory due to screen unlock
Use SUS instead of PCC
i dont want to lose any date in my phone can you guys please tell me how to recover from google account ( its not prompt me for google account ) and if you guys know after how many attempt it wil prompt me i already tried 150+ more times
According to a Google group for Googles own products they say you don't get a Google prompt for forgetting your pin - You would only get the Google recovery prompt if using Face or Pattern lock - They also advise that the only way to combat this is to do a full reset - I must say if you have entered your pin 150+ times as you say then I'm surprised your phone hasn't locked you out and the pin it's asking for is your PUK code
thx u for your answer but i m looking method by which i can save my mails and data i cant even back up now is there any method so i can get google prompt or bypass screen lock pin
There is no bypass that I'm aware of and none that Google know of or have made public,
The repair might (Note the word might) not delete everything ie: Photo's, Music etc, The things it will delete is your Settings, Contacts unless saved to sim and Apps
There is no bypass method sorry, this is for privacy reasons so that if someone else got hold of your phone they would be able to remove the lock but would not have access to your personal data.
yes but that will be better if i can get google prompt to unlock my device but there is no option other than emergency calls please help
