FlashTool Error AGAIN!
Rayday
Hey guys, I tried flashing my SP back to 4.1.2 but it still has the silly error on Flash tool something about SEMC flash device or something even though I already downloaded ALL the drivers from the program's file it self. Please help!
12 REPLIES 12
Thommo
Genius
Is your phone fully switched off and when prompted are you holding Volume down NOT up or both - Just Volume down then connecting your USB cable
Rayday
Yep, Fully switched off and only volume down is being pressed. It just keeps coming up with that error. UGHHH
Thommo
Genius
Are you running windows 8 /8.1 or a 64bit system
Rayday
No. Windows Vista. :?
Thommo
Genius
Interesting - What version of Flashtools are you using, I know earlier version are now giving errors with new firmware, Also before downgrading were you rooted and was there a issue with your phone ie:Bad kernal or boot sector corrupt as the part which allows Flashing may be corrupted - Try Fastboot and if it boots into fastboot then consider using a img not .ftf to flash your phone
Rayday
Un-rooted and I am not sure what version it is. Pretty sure it is the newer one of Flashtool. I'll have to try that fastboot method.
Rayday
Someone, please help.
blackbox
Do you have Sony PC Companion or SUS installed? If not, then do. A reboot might be in order afterwards.
Sounds like you're maybe missing the USB drivers.
Rayday
Yeah, I have Sony update thingy installed and yeah, I have a hunch that I need boot-up files for Xperia SP. SEMC flash device, what does that mean?!
