flash problem
RasukiZ3
flash problem
Hi , I take pictures with flash out a spot on the side of the more illuminated image Como. It occurs only flash more photos go well . I tried putting all modes and SETTINGS Possible In automatic and manual mode and always comes out. Someone 's been something similar ? because I happen?
7 REPLIES 7
I can't see the pictures, could you upload them to box or dropbox? and post the links here
Does your phone has a protective case and/or film?
Sam
Legend
Legend
Do you have a case or cover on your handset that could interfering with this?
RasukiZ3
No. It has no cover and no plastic protector.
Is there anything near the camera lens and/or flash?
Check if there are any scratches on the lens
stockyvillage
@Rasuk try with a different camera app.eg google camera and see if results are the same.Let us know
If nothing work, contact your local Xperia Care
JacekWarchol
Hey, any solution?
I have then same issue, and I see that many Z3s make pics like this.
http://forum.xda-developers.com/z3/help/sony-z3-camera-issue-related-to-flash-t2940556
Did you find a solution to this problem?
