Flash problem with Z2
tugares34
Hey;
When I take a picture my flash is working but with lamp apps or video ( it's on position) don't work. Guys do you have any idea to solve it?
Tags (1)
11 REPLIES 11
HrithikSmarty
try clearing cache of camera app and try keeping flash to ON not in Auto mode
tugares34
How can I clear it? Could you please explain me?
Hampus
If you have updated your Xperia Z2 to the latest software, you can add "Flash light" to your quick settings. Drag down the notification field > Go to Quick settings > Edit > Flash light. Does this function work?
HrithikSmarty
go to settings>apps>all apps>camera>open that and clear data/cache
tugares34
There's no solution I did flashlight but no solution Winking_Face @Hampus and I cleared whole data's about camera but no solution. The interesting thing is my flashlight is working when I take photos
HrithikSmarty
just try repairing with pcc
tugares34
Ok if it's not solve do you have any other idea?
profile.country.RO.title
_alexdon_
You may need to perform a software repair using PC companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
alexdon
HrithikSmarty
it solves ..if not take it to a nearest service centre amd they will update your phone and solve the issue
