try clearing cache of camera app and try keeping flash to ON not in Auto mode
If you have updated your Xperia Z2 to the latest software, you can add "Flash light" to your quick settings. Drag down the notification field > Go to Quick settings > Edit > Flash light. Does this function work?
go to settings>apps>all apps>camera>open that and clear data/cache
@Hampus and I cleared whole data's about camera but no solution. The interesting thing is my flashlight is working when I take photos
just try repairing with pcc
You may need to perform a software repair using PC companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
it solves ..if not take it to a nearest service centre amd they will update your phone and solve the issue
